查看: 11744|回复: 5
BPIR3烧录SD openWRT后启动报错
发表于 2023-2-21 09:55:14 | 显示全部楼层 |阅读模式
开发板链接:
https://item.taobao.com/item.htm ... amp;id=680603467314
根据指导准备一个SD卡,烧录 openwrt  的  mtk-bpi-r3-SD-WAN1-RJ45-20220928-single-image.img 包,启动后一直报以下错误:
[   44.538572] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02970028: 0x0201 instead
[   44.548027] jffs2: Further such events for this erase block will not be printed
[   44.566182] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980000: 0x72f9 instead
[   44.575641] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980004: 0x0022 instead
[   44.585099] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980008: 0x0331 instead
[   44.594559] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0298000c: 0xff21 instead
[   44.604018] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980010: 0x0023 instead
[   44.613475] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980014: 0x0063 instead
[   44.622931] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980018: 0x7f22 instead
[   44.632387] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0298001c: 0xff83 instead
[   44.641844] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980020: 0x11a1 instead
[   44.651302] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02980024: 0x0b40 instead
[   44.660757] jffs2: Further such events for this erase block will not be printed
[   44.678864] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990000: 0x1058 instead
[   44.688324] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990004: 0xffc0 instead
[   44.697783] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990008: 0x0009 instead
[   44.707243] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0299000c: 0x0080 instead
[   44.716701] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990010: 0x8218 instead
[   44.726159] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990014: 0xffc0 instead
[   44.735614] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990018: 0x1058 instead
[   44.745072] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0299001c: 0xffc0 instead
[   44.754527] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02990020: 0x0009 instead
 楼主| 发表于 2023-2-21 09:58:43 | 显示全部楼层
补上串口日志
串口 - _2023-02-21_09-49-44.zip
53.32 KB, 下载次数: 1590
串口日志
发表于 2023-2-21 11:46:08 | 显示全部楼层
启动方式改了吗
 楼主| 发表于 2023-2-22 09:01:12 | 显示全部楼层
启动方式是全high 的 SD启动方式
发表于 2023-2-22 15:29:39 | 显示全部楼层
覆盖格式化 SD卡
发表于 2023-2-23 11:22:06 | 显示全部楼层
请问楼主问题解决了吗?我遇到跟你相同的问题。
https://youyeetoo.cn/thread-6062-1-1.html
GMT+8, 2026-11-2 09:18 , Processed in 0.080857 second(s), 28 queries .
