查看: 6590|回复: 0
BPI-R3 烧写SD卡 启动报jffs2_scan_eraseblock(): Magic bitmask 0x1985
发表于 2023-2-23 10:40:36 | 显示全部楼层 |阅读模式
烧入SD卡命令
sudo dd if=./mtk-bpi-r3-SD-WAN1-SFP1-20220928-single-image.img of=/dev/disk5 bs=1m
68+1 records in
68+1 records out
71791899 bytes transferred in 6.429042 secs (11166811 bytes/sec)
启动后刷屏
[  374.182371] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0bb90024: 0xead6 instead
中间偶尔有
[  374.191826] jffs2: Further such events for this erase block will not be printed
[  374.210353] jffs2: Old JFFS2 bitmask found at 0x0bb9c81c
[  374.215651] jffs2: You cannot use older JFFS2 filesystems with newer kernels
GMT+8, 2026-11-1 08:54 , Processed in 0.069668 second(s), 20 queries .
