查看: 30499|回复: 2
电脑无法识别hikey970
发表于 2018-12-11 14:40:38 | 显示全部楼层 |阅读模式
外接设备:显示器,键盘,鼠标,串口(usart6)TXS0108E(8位双向电压转换器)用于与stm32的串口通信。
系统:lebain 9。
在lebain安装完QT,QTcreator后,接入串口(usart6),系统无法启动。
现在想重新烧写固件,电脑无法识别hikey970,ubuntu和windows下都不行,
用type-c线接debug口打印如下:
NOTICE:  Booting Trusted Firmware
NOTICE:  BL1: v1.4(release):ab30559
NOTICE:  BL1: Built : 10:45:11, Apr 27 2018
NOTICE:  [set_ics_power_up] done!
NOTICE:  BL1: Booting BL2
NOTICE:  BL2: v1.4(release):ab30559
NOTICE:  BL2: Built : 10:45:11, Apr 27 2018
NOTICE:  BL1: Booting BL31
NOTICE:  BL31: v1.4(release):ab30559
NOTICE:  BL31: Built : 10:45:11, Apr 27 20[MR BYPASS] 0x00000000
scsysstat_value[8].
last_keypoint0,reboot_type98
secdbg not DCU.
SecDbgVer exit
xloader chipid: 0x36701100, start: 562ms.
Build Date: Mar 16 2018, 11:00:12
iomcu_subsys_init
PLL Stat
PLL2 ctrl0[0x40231040]=0x04906404,ctrl1[0x40231044]=0x02000000
PLL2 acpu en_stat[0x40235008]:0x00000008, acpu gt_stat[0x40235468]0x00040000
PLL2 final reg[0x4023546c]:0x0037ffff, en_stat[0x4023546c]:0x00100000, final gt_stat[0x4023546c]:0x00020000
PLL3 ctrl0[0x40231048]=0x04903e04,ctrl1[0x40231048]=0x02800000
PLL3 acpu en_stat[0x40235008]=:0x08000000, acpu gt_stat[0x40235468]=:0x00100000
PLL3 final reg[0x4023546c]:0x0037ffff, en_stat[0x4023546c]:0x00200000, final gt_stat[0x4023546c]:0x00040000
PLL4 ctrl0[0x402310ec]=0x04a05d05,ctrl1[0x402310f0]=0x06c00000
PLL6 ctrl0[0x40231500]=0x00b03d04,ctrl1[0x40231504]=0x0270a3d7
PLL7 ctrl0[0x4023150c]=0x04905c05,ctrl1[0x40231510]=0x06d00000
stamp  reg[0x40235128]:0x7e6337fe
a53hpm reg[0x402350d8]:0x000067e3
krin970 [clk_setup]
clk init
StorType:UFS
UceLdOk
ReadtnIsNull
storagereadfail
head_check_fail
UseDefaultPara
ddr_low_temp_on exit temp 52
ReadtnIsNull
restore fail
v310 init!
6423V100 present
freq 55 vol 3:
ddr info 0x00000606
RankIs0x00000002
uce init entry
uce profile total is 0x00000308
u▒▒▒Ł415 vol 2:
freq 415 vol 3:
▒HVrefThres:8
freq 830 vol 2:
HVrefThres:8
freq 830 vol 3:
HVrefThres:8
res L&▒▒▒▒2:
HVrefThres:8
freq 1244 vol 3:
HVrefThres:8
freq 1866 vol 3:
HVrefThres:8
uce init entry
uce profile total is 0x00000274
uce init end
DDRInit 1930 ms
ReadtnIsNull
dfx_data_init():505:rd fail[-1]
C0
509:680
1018:764
1210:860
1402:860
1556:956
1690:956
1844:1052
C1
682:680
1018:780
1210:780
1364:780
1498:900
1652:900
1863:900
2093:950
2362:1050
C2
104:580
151:650
237:650
332:650
415:750
550:750
667:850
767:950
DIE_ID=0x230502237086060add8bfe9121e09800884201d3
再重启后,有时会打印:
hi6422 init fail
682:680
pmu dump slot full:1
SPMI: sid:0x00000001 transfer fail
S1WR000000ab,00000000,00000000,-2
S1WR000000ac,00000000,00000000,-2
S1WR000000ad,00000000,00000000,-2
[avs] 6422 Not 2+2
hi6422 init fail
1018:780
请问这是板子坏了还是系统有问题啊?
Thanks!
发表于 2018-12-11 14:56:11 | 显示全部楼层
你装回android看看能不能正常使用,先排除一下看是不是硬件问题
 楼主| 发表于 2018-12-11 15:26:58 | 显示全部楼层
现在就是把码拨到on off on off 下,电脑无法识别,ubuntu下也不行。
这种情况下该如何烧写android啊?
谢谢!!!
GMT+8, 2026-11-7 22:02 , Processed in 0.098699 second(s), 22 queries .
