查看: 21831|回复: 0
lattepanda熊猫板重刷bios教程
发表于 2018-11-29 13:01:02 | 显示全部楼层 |阅读模式
https://github.com/LattePandaTea ... re/tree/master/Bios
Contains the following:
  • LattePanda v1.0 default BIOS Beta
  • LattePanda v1.1 default BIOS Beta
  • LattePanda v1.2 default BIOS Beta
Note: LattePanda v1.1 default BIOS Beta can only use in LattePanda v1.1 which is using Z8350 CPU.And so on.
How to switch on/off the Auto-boot function in LP v1.1/v1.2:
1.Press [Esc] or [Del] once just boot up the system to enter the BIOS
2.Go into Boot->Machine Status AC/Battery In
3.Change it to Power On/Power Off
How to Figure out the verison of your lattePanda
You can distinguishing between both by the stick on the side of the board.
S70CR110/S70CR100 Z8300 -> V1.0
S70CR110 Z8350 -> V1.1
S70CR200 Z8350 -> V1.2
Disclaimer:
Please note that this is a beta version of the bios which is still undergoing final testing before its official release.
This version is test-only, so please confirm with us before you reflash the bios.
Reflashing without notifying us can put your board in a state of no return and void your warranty.
Ensure that you have saved the Windows product key code and you have an SPI chip programmer to reflash the bios at hardware level
How to refresh the LattePanda BIOS:
  • Format your USB disk to FAT32 and change the drive name to "WINPE"
  • Copy the right BIOS files directly to root of the USB flash disk
  • Plug the U-disk in USB host
  • Plugin the MicroUSB cable and power on the system
  • Wait the refreshing the BIOS automatically until returning "fs1:>" (Check the “”)
  • Unplug the U-disk!
  • Restart the system via pressing the reset button or "Ctrl+Alt+Del". Then finish refreshing. Note: make sure that remove the U-disk before restarting the system!
If you have any problem in the process please check this video from Raducki Frédéric https://youtu.be/du1BuDCn1WQThank Fred for the contribution of BIOS flashing tutorial video
GMT+8, 2026-11-4 14:27 , Processed in 0.068308 second(s), 20 queries .
