查看: 26801|回复: 0
hikey970 opencl可以正常使用工作吗
发表于 2018-11-21 14:33:20 | 显示全部楼层 |阅读模式
target system:hikey970 debian 9
I now use hikey 970 board when need opencl spir.
but show mali G72 not support spir?
Looking forward to your reply.
thanks.
root@hikey970:/home/shunya/ComputeCpp-CE-1.0.0-Ubuntu-16.04-ARM_64/bin# ./computecpp_info
ComputeCpp Info (CE 1.0.0)
SYCL 1.2.1 revision 3
Toolchain information:
GLIBC version: 2.24
GLIBCXX: 20160609
This version of libstdc++ is supported.
Device Info:
Discovered 1 devices matching:
platform : <any>
device type : <any>
Device 0:
Device is supported : NO - Device does not support SPIR
CL_DEVICE_NAME : Mali-G72
CL_DEVICE_VENDOR : ARM
CL_DRIVER_VERSION : 2.0
CL_DEVICE_TYPE : CL_DEVICE_TYPE_GPU
If you encounter problems when using any of these OpenCL devices, please consult
this website for known issues:
https://computecpp.codeplay.com/releases/v1.0.0/platform-support-notes
GMT+8, 2026-11-7 22:00 , Processed in 0.068661 second(s), 21 queries .
