查看: 18649|回复: 0
修改script.bin(适用于Banana pi M2U M3等全志芯片的板子)
发表于 2018-7-2 14:41:35 | 显示全部楼层 |阅读模式
原文:http://forum.banana-pi.org/t/how ... put-resolution/1442
1,install compile sunxi-tools depended-upon packages
  1. sudo apt-get install libusb-1.0-0-dev
2,get sunxi-tools new code from github:
  1. git clone https://github.com/linux-sunxi/sunxi-tools.git
3,compile sunxi-tools
  1. cd sunxi-tools
  2. make
4,backup script.bin
  1. sudo cp /boot/bananapi/script.bin /boot/bananapi/script.bak
5,copy script.bin to current dir
  1. cp /boot/bananapi/script.bin ./
6,use bin2fex change bin to fex
  1. bin2fex ./script.bin ./script.fex
7,edit script.fex file:
  1. nano script.fex
可以看到平台配制文件,编译过这个固件的人就知道它有什么用:
  1. [disp_init]
  2. disp_init_enable = 1
  3. disp_mode = 0
  4. screen0_output_type = 3
  5. screen0_output_mode = 5
  6. screen1_output_type = 2
  7. screen1_output_mode = 11
  8. fb0_framebuffer_num = 2
  9. fb0_format = 10
  10. fb0_pixel_sequence = 0
  11. fb0_scaler_mode_enable = 1
  12. fb1_framebuffer_num = 2
  13. fb1_format = 10
  14. fb1_pixel_sequence = 0
  15. fb1_scaler_mode_enable = 0
  16. lcd0_backlight = 197
  17. lcd1_backlight = 197
  18. lcd0_bright = 50
  19. lcd0_contrast = 50
  20. lcd0_saturation = 57
  21. lcd0_hue = 50
  22. lcd1_bright = 50
  23. lcd1_contrast = 50
  24. lcd1_saturation = 57
  25. lcd1_hue = 50
  26. just change screen0_output_mode = 5, note , other not do any change.
  27. A20 support as below:
  28. HDMI/TV mode numbers:
  29. 0      480i
  30. 1      576i
  31. 2      480p
  32. 3      576p
  33. 4      720p 50Hz
  34. 5      720p 60Hz
  35. 6      1080i 50 Hz
  36. 7      1080i 60 Hz
  37. 8      1080p 24 Hz
  38. 9      1080p 50 Hz
  39. 10      1080p 60 Hz
  40. 11      PAL
  41. 12      PAL SVIDEO
  42. 14      NTSC
  43. 15      NTSC SVIDEO
  44. 17      PAL_M
  45. 18      PAL_M SVIDEO
  46. 20      PAL_NC
  47. 21      PAL_NC SVIDEO
  48. 23      1080p 24 Hz 3D
  49. 24      720p 50 Hz 3D
  50. 25      720p 60 Hz 3D
  51. 26      1360x768 60 Hz
  52. 27      1280x1024 60 Hz
Press Ctrl + x , Y ,Enter save and exit edit:
8,use fex2bin change fex to bin
  1. fex2bin ./script.fex ./script.bin
copy script.bin to /boot
  1. sudo cp ./script.bin /boot/bananapi/
9,reboot and make a try
  1. sudo reboot
更简单的改变设置变量的方法:
just edit uEnv.txt file to change it:
  1. bootargs=enforcing=1 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootwait init=/init vmalloc=384M ion_c ma_list=“120m,176m,512m” loglevel=8 bootmenutimeout=10 datadev=mmcblk0p2 disp.screen0_output_type=3 disp.screen0_o utput_mode=10 disp.screen1_output_type=3 disp.screen1_output_mode=10
GMT+8, 2026-11-15 13:13 , Processed in 0.072559 second(s), 20 queries .
