查看: 30840|回复: 4
hikey960 按照官方提供的镜像刷完机后无法启动
发表于 2018-6-8 15:39:41 | 显示全部楼层 |阅读模式
参考以下刷机不能启动 , 请大家帮忙看看问题
[hikey960]海力士flash版本(2018.5月后生产的) 编译补丁 [color=rgb(153, 153, 153) !important][color=rgb(153, 153, 153) !important][复制链接] http://smartfire.cn/thread-751-1-1.html
http://smartfire.cn/thread-692-1-1.html
下载镜像刷完开机重启一直卡着不能启动 ,log如下
  1. \0\0\0hikey960 boarid:5301 xloader use UART6
  2. scsysstat_value[0].
  3. clear reset source
  4. last_keypoint0,reboot_type0
  5. secdbg not DCU.
  6. SecDbgVer exit
  7. xloader chipid is: 0x36600110, start at 374ms.
  8. Build Date: Dec  6 2017, 15:31:59
  9. [clock_init] ++
  10. hikey960 [hikey960_clk_init]
  11. hi3660 [clk_setup]
  12. [clock_init] --
  13. storage type is UFS
  14. ufs retry: 6 count v_tx:0 v_rx:0
  15. ufs set v_tx:0 v_rx:0
  16. Hikey960[5301] no need avs_init.
  17. ddr ft:0xf20332a3,mode:1 target:4
  18. UceLdOk
  19. density: 0x08080808,0x08080808,0x08080808,0x08080808,0x08080808,0x08080808,0x08080808,0x08080808
  20. ddr info 0x000004ff
  21. 400M
  22. 685M
  23. 1067M
  24. C1R,V0x0000002f e:113
  25. C0R,V0x00000030 e:113
  26. C1R,V0x00000030 e:66
  27. C0R,V0x00000031 e:66
  28. C1R,V0x00000031 e:66
  29. C2R,V0x00000032 e:66
  30. C0R,V0x00000032 e:66
  31. C1R,V0x00000032 e:66
  32. C2R,V0x00000033 e:66
  33. C3R,V0x00000033 e:66
  34. C0R,V0x00000033 e:66
  35. C1R,V0x00000033 e:65
  36. C2R,V0x00000034 e:65
  37. C3R,V0x00000034 e:66
  38. C0R,V0x00000032 e:113
  39. C1R,V0x00000031 e:66
  40. C0R,V0x00000033 e:66
  41. C1R,V0x00000032 e:66
  42. C2R,V0x00000031 e:66
  43. C3R,V0x00000031 e:66
  44. C0R,V0x00000034 e:66
  45. C1R,V0x00000033 e:66
  46. C2R,V0x00000032 e:66
  47. C3R,V0x00000032 e:66
  48. C0R,V0x00000035 e:66
  49. C1R,V0x00000034 e:65
  50. C2R,V0x00000033 e:65
  51. C3R,V0x00000033 e:66
  52. 1244M
  53. 1866M
  54. C2R,V0x00000016 e:66
  55. C2R,V0x00000017 e:66
  56. pack0Idx0Dcc:0
  57. pack1Idx0Dcc:1
  58. pack2Idx0Dcc:0
  59. pack3Idx0Dcc:0
  60. iomcu_subsys_init
  61. boot_c0 PROFILE 4
  62. slave0 irq0:0x00000004
  63. slave1 irq0:0x00000004
  64. NOTICE:  BL2: v1.5(release):v1.5-47-g02f8c038
  65. NOTICE:  BL2: Built : 21:27:07, Mar 30 2018
  66. NOTICE:  ufs: H**** device must set VS_DebugSaveConfigTime 0x10
  67. NOTICE:  BL2: Booting BL31
  68. NOTICE:  BL31: v1.5(release):v1.5-47-g02f8c038
  69. NOTICE:  BL31: Built : 21:27:07, Mar 30 2018
  70. I/TC:
  71. I/TC:  OP-TEE version: 3.0.0 #1 Fri Mar 30 21:27:05 UTC 2018 aarch64
  72. I/TC:  Initialized
  73. UEFI firmware (version Alpha built at 21:26:36 on Mar 30 2018)
  74. [=3h[=3h[=3h[=3hPress ESCAPE for boot options .ERROR: Device Tree header not valid (err:-9)
  75. Android Fastboot mode - version 0.7.
  76. Press RETURN or SPACE key to quit.
发表于 2018-6-8 16:21:37 | 显示全部楼层
你烧录我们编译的固件,这样的验证你是否烧录正确了,还有就是板子是否有问题,
如果烧录我们编译好的固件是OK的,那就是你编译的时间引入的错误,慢慢找问题喽
直接烧录我们发布的固件:
链接:https://pan.baidu.com/s/1Lb4CrVX_s3_yqDqhiPf9gQ 密码:olmj
 楼主| 发表于 2018-6-8 16:33:04 | 显示全部楼层
如果烧录我们编译好的固件 ...
我是刷入你发的固件,仔细看刷机log提示writing 'fastboot'...FAILED (remote: No such partition.)
 楼主| 发表于 2018-6-8 16:58:44 | 显示全部楼层
如果烧录我们编译好的固件 ...
我在win10下刷同样的镜像,提示失败writing 'fastboot'... FAILED (remote: No such partition.)
  1. C:\Users\tooan\Desktop\share\hikey960\hikey960_hynix_fw\hikey960>fastboot flash xloader hisi-sec_xloader.img
  2. < waiting for device >
  3. target reported max download size of 134217728 bytes
  4. sending 'xloader' (151 KB)...
  5. OKAY [  0.009s]
  6. writing 'xloader'...
  7. OKAY [  0.284s]
  8. finished. total time: 0.293s
  9. C:\Users\tooan\Desktop\share\hikey960\hikey960_hynix_fw\hikey960>fastboot flash ptable hisi-ptable.img
  10. target reported max download size of 134217728 bytes
  11. sending 'ptable' (196 KB)...
  12. OKAY [  0.019s]
  13. writing 'ptable'...
  14. OKAY [  0.004s]
  15. finished. total time: 0.023s
  16. C:\Users\tooan\Desktop\share\hikey960\hikey960_hynix_fw\hikey960>fastboot flash fastboot hisi-fastboot.img
  17. target reported max download size of 134217728 bytes
  18. sending 'fastboot' (3346 KB)...
  19. OKAY [  0.081s]
  20. writing 'fastboot'...
  21. FAILED (remote: No such partition.)
  22. finished. total time: 0.083s
  23. "Update Failed!"
发表于 2018-9-14 14:50:22 | 显示全部楼层
https://pan.baidu.com/s/1Lb4CrVX_s3_yqDqhiPf9gQ <----- 鏈結不存在, 看能否重新發布....
GMT+8, 2026-11-7 21:59 , Processed in 0.077634 second(s), 24 queries .
