查看: 32174|回复: 0
banana pi R2 安装ubuntu到EMMC
发表于 2018-4-17 16:21:39 | 显示全部楼层 |阅读模式
How to program Ubuntu image to EMMC
  • a. Program ubuntu image to SD card
    b. Install this SD to R2 board and boot from SD
    c. Enter the Uboot prompt, and run command emmc pconf 48 to change Partition config of EMMC
    d. And then run command reset, let it boot to OS
    e. Enter the system with username pi or root
    f. Run command
    echo 0 > /sys/block/mmcblk1boot0/force_ro  to enable /dev/mmcblk1boot0 write mode`
      g. To write preloader to EMMC by running command:
  1. bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0
      where BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz is the preloader for emmc,
      please download it from link https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
[size=0.7579em]69
     h. To copy ubuntu image to EMMC:
  1. unzip -p <font color="navy"><XXX.img.zip></font> | pv | dd of=<font color="navy"><device></font> bs=10M status=noxfer
  or
  1.    bpi-copy  <XXX.img.zip> <device>
  where the XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html
i. power off
j, remove SD & power on
GMT+8, 2026-11-6 02:48 , Processed in 0.067854 second(s), 20 queries .
