查看: 496|回复: 1
yy3568开发板, OpenHarmony4.1系统开发,环境搭建中遇到的问题
发表于 2026-5-6 18:30:20 | 显示全部楼层 |阅读模式
硬件主板型号:yy3568
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# sudo apt-get update && sudo apt-get install binutils git git-lfs gnupg flex bison gperf build-essential zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32ncurses5-dev x11proto-core-dev libx11-dev lib32z1-dev ccache libgl1-mesa-dev libxml2-utils xsltproc unzip m4 bc gnutls-bin python3.8 python3-pip ruby
Get:1 https://dl.google.com/linux/chrome/deb stable InRelease [1,825 B]
Hit:2 https://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal InRelease
Hit:3 http://oem.archive.canonical.com focal InRelease
Hit:4 http://dell.archive.canonical.com focal InRelease
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:7 https://packages.microsoft.com/repos/code stable InRelease
Hit:8 http://archive.canonical.com/ubuntu focal InRelease
Get:9 https://dl.google.com/linux/chrome/deb stable/main amd64 Packages [1,200 B]
Hit:10 https://linux.teamviewer.com/deb stable InRelease
Hit:11 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:5 https://developer.download.nvidi ... s/ubuntu2004/x86_64  InRelease
Hit:12 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:13 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Fetched 3,025 B in 4s (819 B/s)
Reading package lists... Done
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target Translations (main/i18n/Translation-zh_CN) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:51 and /etc/apt/sources.list.d/ros2.list:1
Building dependency tree
Reading state information... Done
Note, selecting 'lib32ncurses-dev' instead of 'lib32ncurses5-dev'
bc is already the newest version (1.07.1-2build1).
bison is already the newest version (2:3.5.1+dfsg-1).
ccache is already the newest version (3.7.7-1).
flex is already the newest version (2.6.4-6.2).
g++-multilib is already the newest version (4:9.3.0-1ubuntu2).
gcc-multilib is already the newest version (4:9.3.0-1ubuntu2).
m4 is already the newest version (1.4.18-4).
ruby is already the newest version (1:2.7+1).
x11proto-core-dev is already the newest version (2019.2-1ubuntu1).
zip is already the newest version (3.0-11build1).
git-lfs is already the newest version (2.9.2-1).
gperf is already the newest version (3.1-1build1).
binutils is already the newest version (2.34-6ubuntu1.11).
build-essential is already the newest version (12.8ubuntu1.1).
curl is already the newest version (7.68.0-1ubuntu2.25).
git is already the newest version (1:2.25.1-1ubuntu3.14).
gnupg is already the newest version (2.2.19-3ubuntu2.5).
lib32ncurses-dev is already the newest version (6.2-0ubuntu2.1).
lib32z1-dev is already the newest version (1:1.2.11.dfsg-2ubuntu1.5).
libc6-dev-i386 is already the newest version (2.31-0ubuntu9.18).
libgl1-mesa-dev is already the newest version (21.2.6-0ubuntu0.1~20.04.2).
libx11-dev is already the newest version (2:1.6.9-2ubuntu1.6).
libxml2-utils is already the newest version (2.9.10+dfsg-5ubuntu0.20.04.10).
python3.8 is already the newest version (3.8.10-0ubuntu1~20.04.18).
unzip is already the newest version (6.0-25ubuntu1.2).
xsltproc is already the newest version (1.1.34-4ubuntu0.20.04.3).
zlib1g-dev is already the newest version (1:1.2.11.dfsg-2ubuntu1.5).
gnutls-bin is already the newest version (3.6.13-2ubuntu1.12).
python3-pip is already the newest version (20.0.2-5ubuntu1.11).
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# git config --global user.name "niuhualing6"
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# git config --global user.email "niuhualing6@163.com"
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# git config --global credential.helper store
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# sudo curl -s https://gitee.com/oschina/repo/raw/fork_flow/repo-py3 -o /usr/local/bin/repo
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# sudo chmod a+x /usr/local/bin/repo
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# pip3 install -i https://repo.huaweicloud.com/repository/pypi/simple requests
Looking in indexes: https://repo.huaweicloud.com/repository/pypi/simple
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.22.0)
root@ubuntu2004-Precision-7920-Tower:/mnt/data/youyeetoo_harmony# repo init -u http://dd.youyeetoo.cn:8000/ohos_yy3568/manifest_yy3568 -b main -m default.xml
问题描述及复现步骤: 环境搭建时,repo执行获取源码操作步骤,没有反应。
发表于 2026-5-7 13:52:16 | 显示全部楼层
我看你的指令执行没有问题:
你确定一下,多执行几次看看
GMT+8, 2026-11-4 20:50 , Processed in 0.073298 second(s), 21 queries .
