查看: 672|回复: 0
youyeetoo x1s的com1串口的实际物理地址是多少?
发表于 2026-3-2 17:41:00 | 显示全部楼层 |阅读模式
硬件主板型号:youyeetoo x1s
我的程序在qemu上有打印:Z1:Start
*** yyZephyr EFI Loader ***
RSDP found at 0x1fb7e014
Zeroing 499408 bytes of memory at 0x106000
Copying 20480 data bytes to 0x1000 from image offset
Copying 24576 data bytes to 0x100000 from image offset 20480
Copying 33056 data bytes to 0x17fee0 from image offset 45056
Jumping to Entry Point: 0x1137 (66 ba fb 3 b0 80 ee)
Z1:Start
但是在youyeetoo x1s板子上,只打印到了Jumping
用的是标准的 x86_64 UEFI 环境 + COM1 串口(0x3F8)去打印的Z1:Start
附打印代码:
# --- 串口打印测试代码开始(x86_64标准格式,无编译错误)---
    # 初始化COM1串口(0x3F8),波特率115200 8N1
    movw $0x3FB, %dx        # Line Control Register (0x3F8+3)
    movb $0x80, %al         # 设置DLAB位,允许修改波特率
    outb %al, %dx           # 写入线路控制寄存器
    movw $0x3F8, %dx        # Divisor Latch Low (0x3F8)
    movb $0x01, %al         # 波特率除数=1 (115200)
    outb %al, %dx
    movw $0x3F9, %dx        # Divisor Latch High (0x3F8+1)
    movb $0x00, %al         # 除数高字节=0
    outb %al, %dx
    movb $0x03, %al         # 8N1模式,清除DLAB位
    outb %al, %dx
    movw $0x3FC, %dx        # Modem Control Register (0x3F8+4)
    movb $0x0B, %al         # 启用DTR/RTS,禁用中断
    outb %al, %dx
    # 发送测试字符串:"Z1:Start\n\r"(Youyeetoo X1启动标记)
    # 发送 'Z'
send_z:
    movw $0x3FD, %dx        # Line Status Register (0x3F8+5)
    inb %dx, %al            # 读取线路状态
    testb $0x20, %al        # 检查TX Empty位(bit5)
    jz send_z               # 串口忙则等待
    movw $0x3F8, %dx        # Transmit Data Register
    movb $0x5A, %al         # 'Z'
    outb %al, %dx
    # 发送 '1'
send_1:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_1
    movw $0x3F8, %dx
    movb $0x31, %al         # '1'
    outb %al, %dx
    # 发送 ':'
send_colon:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_colon
    movw $0x3F8, %dx
    movb $0x3A, %al         # ':'
    outb %al, %dx
    # 发送 'S'
send_s:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_s
    movw $0x3F8, %dx
    movb $0x53, %al         # 'S'
    outb %al, %dx
    # 发送 't'
send_t:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_t
    movw $0x3F8, %dx
    movb $0x74, %al         # 't'
    outb %al, %dx
    # 发送 'a'
send_a:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_a
    movw $0x3F8, %dx
    movb $0x61, %al         # 'a'
    outb %al, %dx
    # 发送 'r'
send_r:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_r
    movw $0x3F8, %dx
    movb $0x72, %al         # 'r'
    outb %al, %dx
    # 发送 't'
send_t2:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_t2
    movw $0x3F8, %dx
    outb %al, %dx
    # 发送换行+回车
send_nl:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_nl
    movw $0x3F8, %dx
    movb $0x0A, %al         # '\n'
    outb %al, %dx
send_cr:
    movw $0x3FD, %dx
    inb %dx, %al
    testb $0x20, %al
    jz send_cr
    movw $0x3F8, %dx
    movb $0x0D, %al         # '\r'
    outb %al, %dx
GMT+8, 2026-11-29 15:32 , Processed in 0.067937 second(s), 20 queries .
