查看: 1084|回复: 6
firefly7寸屏幕问题
发表于 2025-9-17 19:39:32 | 显示全部楼层 |阅读模式
硬件主板型号:   firefly   ROS-RKK3588S-PC
固件名称/系统版本:ROC-RK3588S-PC_Ubuntu22.04-Xfce-r31153_v1.4.0g_250114.img
Log日志:
  1. firefly@firefly:~$ git apply 0002-YYT-MIPI7LCD-3588-linux.patch
  2. 0002-YYT-MIPI7LCD-3588-linux.patch:33: trailing whitespace.
  3. //#if WHICHDSI
  4. 0002-YYT-MIPI7LCD-3588-linux.patch:55: trailing whitespace.
  5. //#if WHICHDSI
  6. 0002-YYT-MIPI7LCD-3588-linux.patch:140: trailing whitespace.
  7.         status = "okay";
  8. 0002-YYT-MIPI7LCD-3588-linux.patch:245: trailing whitespace.
  9.        status = "okay";
  10. 0002-YYT-MIPI7LCD-3588-linux.patch:269: trailing whitespace.
  11. //#if WHICHDSI
  12. error: kernel/arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1.dts: No such file or directory
  13. error: kernel/arch/arm64/boot/dts/rockchip/roc-rk3588s-pc-mipi101-M101014-BE45-A1.dts: No such file or directory
  14. error: kernel/arch/arm64/configs/firefly-linux.config: No such file or directory
  15. error: kernel/drivers/input/touchscreen/Kconfig: No such file or directory
  16. error: kernel/drivers/input/touchscreen/Makefile: No such file or directory
  17. error: kernel/drivers/input/touchscreen/gt9xx/gt9xx.c: No such file or directory
  18. error: kernel/drivers/input/touchscreen/gt9xx/gt9xx.h: No such file or directory
  19. error: kernel/drivers/input/touchscreen/gt9xx/gt9xx_update.c: No such file or directory
  20. firefly@firefly:~$
问题描述及复现步骤:如何使用7寸屏幕,就是我在下完0002-YYT-MIPI7LCD-3588-linux.patch文件并执行git apply
1-YYT-MIPI7LCD-3588-android12.patch后报错,里边说的在根目录下编译说的是要下载源代码然后在源代码编译后生成固件在烧录吗
发表于 2025-10-9 15:00:39 | 显示全部楼层
是,在SDK里面执行
发表于 2025-10-17 10:36:49 | 显示全部楼层
何浩钧 发表于 2025-10-9 15:00
是,在SDK里面执行
gbc@gbc-A29R:~/firefly_rk3588_SDK$ git apply 0002-YYT-MIPI7LCD-3588-linux.patch
//#if WHICHDSI
//#if WHICHDSI
        status = "okay";
       status = "okay";
//#if WHICHDSI
error: 打补丁失败:kernel/arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1.dts:6
error: kernel/arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1.dts:补丁未应用
error: kernel/arch/arm64/boot/dts/rockchip/roc-rk3588s-pc-mipi101-M101014-BE45-A1.dts:错误类型
error: 打补丁失败:kernel/arch/arm64/configs/firefly-linux.config:127
error: kernel/arch/arm64/configs/firefly-linux.config:补丁未应用
error: 打补丁失败:kernel/drivers/input/touchscreen/Makefile:120
error: kernel/drivers/input/touchscreen/Makefile:补丁未应用
error: 打补丁失败:kernel/drivers/input/touchscreen/gt9xx/gt9xx.c:92
error: kernel/drivers/input/touchscreen/gt9xx/gt9xx.c:补丁未应用
error: 打补丁失败:kernel/drivers/input/touchscreen/gt9xx/gt9xx.h:391
error: kernel/drivers/input/touchscreen/gt9xx/gt9xx.h:补丁未应用
error: 打补丁失败:kernel/drivers/input/touchscreen/gt9xx/gt9xx_update.c:2883
error: kernel/drivers/input/touchscreen/gt9xx/gt9xx_update.c:补丁未应用
,在sdk里面执行,失败了
发表于 2025-10-20 15:12:19 | 显示全部楼层
0002-YYT-MIPI7LCD- ...
手动打一下
发表于 2025-10-20 15:14:35 | 显示全部楼层
什么意思,重新执行这个指令
发表于 2025-10-20 15:15:42 | 显示全部楼层
现在的问题是,代码对应不上
发表于 2025-10-20 19:36:32 | 显示全部楼层
手动根据补丁修改一下
GMT+8, 2026-11-6 02:49 , Processed in 0.085174 second(s), 26 queries .
