查看: 1241|回复: 1
youyeetoo YY3588 鸿蒙5.1编译报错
发表于 2025-8-11 11:35:55 | 显示全部楼层 |阅读模式
硬件主板型号:youyeetoo YY3588
windows 虚拟机 wsl ubuntu22.04
编译步骤参考的是 https://wiki.youyeetoo.cn/zh/YY3588/CompileSource
7) 报错的命令。
bash -x ./build.sh --product-name YY3588 –ccache
8)下面是报错的信息。截屏高清图片上传超过1M不允许上传。
8)  以下是提取的图中文字:### 第一张图文字```OHOS INFO 2076/18902 ACTION
//developtools/packing_tool:packing_tool(//build/toolchain/linux:clang_x64)[OHOS ERROR] [NINJA FAILED] 2057/18902 CLANG //developtools/packing_tool/build/haptobin_tool(//build/toolchain/ohoshos_clang_arm64)developtools/packing_tool/bin/clang_x64/obj/developtools/packing_tool/build/haptobin_tool/developtools/packing_tool/jar/app_unpacking_tool.jar --jar app_unpacking_tool.jar --jar-path=../developtools/packing_tool/jar/app_unpacking_tool.jar --jar-checksum=jar-checksum --jar-app=unpacking_tool.jar --linuxOutput clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --haptabinOutput clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --packing_tool_args: --jarOutput clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --haptabinOutput clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --haptabinOutput=clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --max-sdk-root compilation_dir --sdk [OHOS ERROR] [NINJA FAILED] 2057/18902 CLANG //developtools/packing_tool/build/haptobin_tool(//build/toolchain/ohoshos_clang_arm64)prebuilts/packing_tool/compress_common.jar --jar-path=../prebuilts/packing_tool/compress_common.jar --jar-checksum=jar-checksum --jar-app=compress_common.jar --linuxOutput clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --haptabinOutput clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --haptabinOutput=clang_x64/obj/developtools/packing_tool/packing_tool/adapters/ohos --max-sdk-root compilation_dir --sdk [OHOS ERROR] [NINJA FAILED] 2057/18902 CLANG
发表于 2025-8-15 18:00:13 | 显示全部楼层
检查一下环境
GMT+8, 2026-11-19 08:03 , Processed in 0.077237 second(s), 21 queries .
