查看: 3260|回复: 0
TinkerBoard 2/2s (RK3399)启动报错,找不到libserial_port.so
发表于 2025-2-11 19:20:19 | 显示全部楼层 |阅读模式
硬件主板型号:TinkerBoard 2/2s (RK3399)
固件名称/系统版本:android 11
  1. 2025-02-11 18:51:30.985   247-247   tombstoned              tombstoned                           I  received crash request for pid 10327
  2. 2025-02-11 18:51:30.986 10387-10387 crash_dump32            pid-10387                            I  performing dump of process 10327 (target tid = 10327)
  3. 2025-02-11 18:51:31.000 10387-10387 DEBUG                   pid-10387                            A  *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
  4. 2025-02-11 18:51:31.000 10387-10387 DEBUG                   pid-10387                            A  Build fingerprint: 'asus/WW_Tinker_Board_2/Tinker_Board_2:11/RQ3A.210705.001/eng-infosys1-20250211.1358:userdebug/release-keys'
  5. 2025-02-11 18:51:31.000 10387-10387 DEBUG                   pid-10387                            A  Revision: '0'
  6. 2025-02-11 18:51:31.000 10387-10387 DEBUG                   pid-10387                            A  ABI: 'arm'
  7. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A  Timestamp: 2025-02-11 18:51:31+0800
  8. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A  pid: 10327, tid: 10327, name: main  >>> zygote <<<
  9. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A  uid: 0
  10. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A  signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
  11. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A  Abort message: 'Error preloading public library libserial_port.so: dlopen failed: library "libserial_port.so" not found'
  12. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A      r0  00000000  r1  00002857  r2  00000006  r3  ffaa24c0
  13. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A      r4  ffaa24d4  r5  ffaa24b8  r6  00002857  r7  0000016b
  14. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A      r8  ffaa24c0  r9  ffaa24d0  r10 ffaa24f0  r11 ffaa24e0
  15. 2025-02-11 18:51:31.001 10387-10387 DEBUG                   pid-10387                            A      ip  00002857  sp  ffaa2490  lr  f4f3be79  pc  f4f3be8c
  16. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A  backtrace:
  17. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #00 pc 00038e8c  /apex/com.android.runtime/lib/bionic/libc.so (abort+172) (BuildId: 5945517e01770eb6324783a436b26ced)
  18. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #01 pc 003fe9ed  /apex/com.android.art/lib/libart.so (art::Runtime::Abort(char const*)+1812) (BuildId: 712248af3f00d1afca3526238b090f27)
  19. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #02 pc 0000da15  /system/lib/libbase.so (android::base::SetAborter(std::__1::function<void (char const*)>&&)::$_3::__invoke(char const*)+48) (BuildId: 05ee0660bc077b949a623cbcca2380bc)
  20. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #03 pc 0000533d  /system/lib/liblog.so (__android_log_assert+172) (BuildId: 506b10c30286ee892e5b0030665e312a)
  21. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #04 pc 0000926f  /apex/com.android.art/lib/libnativeloader.so (android::nativeloader::LibraryNamespaces::Initialize()+198) (BuildId: 277e2a331b13f591c27ec14de343a6aa)
  22. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #05 pc 00008a8b  /apex/com.android.art/lib/libnativeloader.so (InitializeNativeLoader+14) (BuildId: 277e2a331b13f591c27ec14de343a6aa)
  23. 2025-02-11 18:51:31.041 10387-10387 DEBUG                   crash_dump32                         A        #06 pc 00298907  /apex/com.android.art/lib/libart.so (JNI_CreateJavaVM+590) (BuildId: 712248af3f00d1afca3526238b090f27)
  24. 2025-02-11 18:51:31.042 10387-10387 DEBUG                   crash_dump32                         A        #07 pc 0006bf25  /system/lib/libandroid_runtime.so (android::AndroidRuntime::startVm(_JavaVM**, _JNIEnv**, bool, bool)+9668) (BuildId: e475c75fcd362771ea5a7cf5207f457d)
  25. 2025-02-11 18:51:31.042 10387-10387 DEBUG                   crash_dump32                         A        #08 pc 0006c371  /system/lib/libandroid_runtime.so (android::AndroidRuntime::start(char const*, android::Vector<android::String8> const&, bool)+284) (BuildId: e475c75fcd362771ea5a7cf5207f457d)
  26. 2025-02-11 18:51:31.042 10387-10387 DEBUG                   crash_dump32                         A        #09 pc 00002dfd  /system/bin/app_process32 (main+964) (BuildId: 0b1837ddf6b25314eb841b624670ac54)
  27. 2025-02-11 18:51:31.042 10387-10387 DEBUG                   crash_dump32                         A        #10 pc 000336af  /apex/com.android.runtime/lib/bionic/libc.so (__libc_init+66) (BuildId: 5945517e01770eb6324783a436b26ced)
  28. 2025-02-11 18:51:31.133 10387-10387 crash_dump32            crash_dump32                         I  type=1400 audit(0.0:1048): avc: denied { open } for path="/dev/__properties__/u:object_r:device_config_runtime_native_boot_prop:s0" dev="tmpfs" ino=21128 scontext=u:r:crash_dump:s0 tcontext=u:object_r:device_config_runtime_native_boot_prop:s0 tclass=file permissive=1
  29. 2025-02-11 18:51:31.151 10326-10326 ActivityRe...onHardware zygote64                             E  activity_recognition HAL is deprecated. class_init is effectively a no-op
  30. 2025-02-11 18:51:31.172 10387-10387 crash_dump32            crash_dump32                         E  unable to connect to activity manager: Connection refused
  31. 2025-02-11 18:51:31.172   247-247   tombstoned              tombstoned                           E  Tombstone written to: /data/tombstones/tombstone_04
  32. 2025-02-11 18:51:31.238 10331-10349 AudioHardwareTiny       android.hardware.audio.service       D  adev_close_output_stream!
  33. 2025-02-11 18:51:31.238 10331-10349 AudioHardwareTiny       android.hardware.audio.service       D  do_out_standby,out = 0xf44041b0,device = 0x2
  34. 2025-02-11 18:51:31.238 10331-10349 r_submix                android.hardware.audio.service       I  adev_close()
  35. 2025-02-11 18:51:35.678     0-0     init                    kernel                               I  starting service 'zygote'...
  36. 2025-02-11 18:51:35.679     0-0     init                    kernel                               I  Created socket '/dev/socket/zygote', mode 660, user 0, group 1000
  37. 2025-02-11 18:51:35.679     0-0     init                    kernel                               I  Created socket '/dev/socket/usap_pool_primary', mode 660, user 0, group 1000
  38. 2025-02-11 18:51:35.683     0-0     init                    kernel                               I  starting service 'zygote_secondary'...
  39. 2025-02-11 18:51:35.683     0-0     init                    kernel                               I  Created socket '/dev/socket/zygote_secondary', mode 660, user 0, group 1000
  40. 2025-02-11 18:51:35.684     0-0     init                    kernel                               I  Created socket '/dev/socket/usap_pool_secondary', mode 660, user 0, group 1000
  41. 2025-02-11 18:51:35.687     0-0     init                    kernel                               I  starting service 'audioserver'...
  42. 2025-02-11 18:51:35.692     0-0     init                    kernel                               I  starting service 'cameraserver'...
  43. 2025-02-11 18:51:35.696     0-0     init                    kernel                               I  starting service 'media'...
  44. 2025-02-11 18:51:35.698     0-0     libprocessgroup         kernel                               W  Failed to open /dev/cpuset/camera-daemon/tasks: No such file or directory: No such file or directory
  1. arm64-v8a编译的libserial_port.so放了两个位置:
  2. '/system/lib/libserial_port.so'   和  '/system/lib64/libserial_port.so'
  3. libserial_port.so也添加到public.libraries.txt了,Android11系统无法启动。
  4. Abort message: 'Error preloading public library libserial_port.so: dlopen failed: library "libserial_port.so" not found'
GMT+8, 2026-10-22 02:43 , Processed in 0.069262 second(s), 21 queries .
