查看: 1455|回复: 0
3568java调用gpio测试打包失败
发表于 2025-1-6 14:12:54 | 显示全部楼层 |阅读模式
硬件主板型号:3568
固件名称/系统版本:Android11
Log日志:
9 issues were found when checking AAR metadata:
  1.  Dependency 'androidx.constraintlayout:constraintlayout:2.2.0' requires libraries and applications that
      depend on it to compile against version 34 or later of the
      Android APIs.
      :app is currently compiled against android-33.
      Also, the maximum recommended compile SDK version for Android Gradle
      plugin 7.4.0 is 33.
      Recommended action: Update this project's version of the Android Gradle
      plugin to one that supports 34, then update this project to use
      compileSdkVerion of at least 34.
      Note that updating a library or application's compileSdkVersion (which
      allows newer APIs to be used) can be done separately from updating
      targetSdkVersion (which opts the app in to new runtime behavior) and
      minSdkVersion (which determines which devices the app can be installed
      on).
  2.  Dependency 'androidx.appcompat:appcompat-resources:1.7.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  3.  Dependency 'androidx.appcompat:appcompat:1.7.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  4.  Dependency 'androidx.activity:activity:1.8.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  5.  Dependency 'androidx.transition:transition:1.5.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  6.  Dependency 'androidx.core:core-ktx:1.13.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  7.  Dependency 'androidx.core:core:1.13.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  8.  Dependency 'androidx.profileinstaller:profileinstaller:1.4.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
  9.  Dependency 'androidx.annotation:annotation-experimental:1.4.0' requires libraries and applications that
      Android APIs.
      plugin 7.4.0 is 33.
      on).
问题描述及复现步骤:根据官网上的Java调用GPIO教程进行操作后,打包过程中报错
GMT+8, 2026-11-18 00:27 , Processed in 0.067047 second(s), 20 queries .
