查看: 4320|回复: 2
canMV IDE初次编译运行代码报错
发表于 2024-5-22 17:43:51 | 显示全部楼层 |阅读模式
代码:
# Hello World Example
# Welcome to the CanMV IDE! Click on the green run arrow button below to run the script!
import sensor, image, time, lcd
lcd.init()                          # Init lcd display
lcd.clear(lcd.RED)                  # Clear lcd screen.
sensor.reset()                      # Reset and initialize the sensor.
sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.QVGA)   # Set frame size to QVGA (320x240)
sensor.skip_frames(time = 2000)     # Wait for settings take effect.
clock = time.clock()                # Create a clock object to track the FPS.
while(True):
    clock.tick()                    # Update the FPS clock.
    img = sensor.snapshot()         # Take a picture and return the image.
    lcd.display(img)                # Display image on lcd.
    print(clock.fps())              # Note: CanMV Cam runs about half as fast when connected
                                    # to the IDE. The FPS should increase once disconnected.
报错:
Traceback (most recent call last):
  File "<stdin>", line 5, in <module>
ImportError: no module named 'sensor'
 楼主| 发表于 2024-5-22 17:46:22 | 显示全部楼层
1)初次安装好canmv,然后运行代码
2)代码是实例代码
3)报错了,但是直接printf(“hello world”),没问题,单纯写这么一行
发表于 2024-5-22 18:06:20 | 显示全部楼层
下载v0.6版本的镜像,应该是能正常工作的
GMT+8, 2026-10-20 08:40 , Processed in 0.077161 second(s), 22 queries .
