查看: 6103|回复: 3
yy3568 Android11 编译问题
发表于 2024-3-25 11:01:10 | 显示全部楼层 |阅读模式
硬件主板型号:yy3568
>>>>>>>>>>>>>>>>>>>>> rk356x
Optee Version: v2
libcameradevice curr board is rk356x
error: external/angle/Android.bp:776:1: module "angle_spvtools_vendor_tables_debuginfo" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not        exist
error: external/angle/Android.bp:776:1: module "angle_spvtools_vendor_tables_debuginfo" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" doe        s not exist
error: external/angle/Android.bp:706:1: module "angle_spvtools_vendor_tables_spv-amd-shader-trinary-minmax" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar        _tables.py" does not exist
error: external/angle/Android.bp:706:1: module "angle_spvtools_vendor_tables_spv-amd-shader-trinary-minmax" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.spv-amd        -shader-trinary-minmax.grammar.json" does not exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exi        st
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/unified1/spirv.core.grammar.js        on" does not exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does no        t exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.js        on" does not exist
14:19:17 soong bootstrap failed with: exit status 1
编译环境:Ubuntu 18.04.4 LTS  16G 内存 150G硬盘
编译参考:http://wiki.youyeetoo.cn/zh/YY3568/environment
按照开发文档上的连接下载了Android 源码,解压后通过git reset --hard HEAD检出源码
然后编译
source build/envsetup.sh lunch
YY3568-userdebug
./build.sh -UKAu
编译过程中IO4/6选了18 其余选33 编译报上面的错误,从代码来看貌似缺少文件。
发表于 2024-3-25 15:57:28 | 显示全部楼层
您好,我们这边已经重新验证过了,现在重新打包一份到wiki上。
 楼主| 发表于 2024-3-26 16:01:10 | 显示全部楼层
您好,我已经从新下载编译,貌似还缺少文件,下面是报错 日志,麻烦帮忙核实下,谢谢!
>>>>>>>>>>>>>>>>>>>>> rk356x
[hardware/rockchip/libgralloc/bifrost frameworks/native/include system/core/libsync system/core/libsync/include external/libdrm/include/drm] 30
Optee Version: v2
error: external/angle/Android.bp:776:1: module "angle_spvtools_vendor_tables_debuginfo" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does not exist
error: external/angle/Android.bp:706:1: module "angle_spvtools_vendor_tables_spv-amd-shader-trinary-minmax" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:706:1: module "angle_spvtools_vendor_tables_spv-amd-shader-trinary-minmax" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.spv-amd-shader-trinary-minmax.grammar.json" does not exist
error: external/angle/Android.bp:903:1: module "angle_spvtools_core_tables_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:903:1: module "angle_spvtools_core_tables_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/unified1/spirv.core.grammar.json" does not exist
error: external/angle/Android.bp:903:1: module "angle_spvtools_core_tables_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does not exist
error: external/angle/Android.bp:903:1: module "angle_spvtools_core_tables_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.json" does not exist
error: external/angle/Android.bp:807:1: module "angle_spvtools_language_header_debuginfo" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_language_headers.py" does not exist
error: external/angle/Android.bp:807:1: module "angle_spvtools_language_header_debuginfo" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does not exist
error: external/angle/Android.bp:790:1: module "angle_spvtools_opencl_tables_opencl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:790:1: module "angle_spvtools_opencl_tables_opencl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/1.0/extinst.opencl.std.100.grammar.json" does not exist
error: external/angle/Android.bp:790:1: module "angle_spvtools_opencl_tables_opencl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/1.0/spirv.core.grammar.json" does not exist
error: external/angle/Android.bp:790:1: module "angle_spvtools_opencl_tables_opencl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does not exist
error: external/angle/Android.bp:790:1: module "angle_spvtools_opencl_tables_opencl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.json" does not exist
error: external/angle/Android.bp:720:1: module "angle_spvtools_vendor_tables_spv-amd-shader-explicit-vertex-parameter" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:720:1: module "angle_spvtools_vendor_tables_spv-amd-shader-explicit-vertex-parameter" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.spv-amd-shader-explicit-vertex-parameter.grammar.json" does not exist
error: external/angle/Android.bp:872:1: module "angle_spvtools_glsl_tables_glsl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:872:1: module "angle_spvtools_glsl_tables_glsl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/1.0/extinst.glsl.std.450.grammar.json" does not exist
error: external/angle/Android.bp:872:1: module "angle_spvtools_glsl_tables_glsl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/1.0/spirv.core.grammar.json" does not exist
error: external/angle/Android.bp:872:1: module "angle_spvtools_glsl_tables_glsl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does not exist
error: external/angle/Android.bp:872:1: module "angle_spvtools_glsl_tables_glsl1-0" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.json" does not exist
error: external/angle/Android.bp:889:1: module "angle_spvtools_generators_inc" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_registry_tables.py" does not exist
error: external/angle/Android.bp:889:1: module "angle_spvtools_generators_inc" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/spir-v.xml" does not exist
error: external/angle/Android.bp:821:1: module "angle_spvtools_language_header_cldebuginfo100" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_language_headers.py" does not exist
error: external/angle/Android.bp:821:1: module "angle_spvtools_language_header_cldebuginfo100" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.json" does not exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-headers/src/include/spirv/unified1/spirv.core.grammar.json" does not exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.debuginfo.grammar.json" does not exist
error: external/angle/Android.bp:920:1: module "angle_spvtools_core_enums_unified1" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.json" does not exist
error: external/angle/Android.bp:734:1: module "angle_spvtools_vendor_tables_spv-amd-shader-ballot" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:734:1: module "angle_spvtools_vendor_tables_spv-amd-shader-ballot" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.spv-amd-shader-ballot.grammar.json" does not exist
error: external/angle/Android.bp:762:1: module "angle_spvtools_vendor_tables_opencl.debuginfo.100" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:762:1: module "angle_spvtools_vendor_tables_opencl.debuginfo.100" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.opencl.debuginfo.100.grammar.json" does not exist
error: external/angle/Android.bp:748:1: module "angle_spvtools_vendor_tables_spv-amd-gcn-shader" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/utils/generate_grammar_tables.py" does not exist
error: external/angle/Android.bp:748:1: module "angle_spvtools_vendor_tables_spv-amd-gcn-shader" variant "android_arm64_armv8-a_cortex-a55": module source path "external/angle/third_party/spirv-tools/src/source/extinst.spv-amd-gcn-shader.grammar.json" does not exist
14:29:26 soong bootstrap failed with: exit status 1
#### failed to build some targets (34 seconds) ####
发表于 2024-3-26 16:56:50 | 显示全部楼层
我们这边验证过,确实是没有问题的,可能是百度网盘下载的文件有点丢数据
GMT+8, 2026-10-30 10:29 , Processed in 0.076253 second(s), 23 queries .
