查看: 4199|回复: 2
YY3568 安装 Ubuntut系统无法启用
发表于 2024-3-25 10:16:17 | 显示全部楼层 |阅读模式
硬件主板型号:YY3568
固件名称/系统版本:Ubuntu
自编的或固件下载地址:官方下载固件
下载官方提供的镜像,“yy3568-u20-edp-wifi.img.7z”,通过官方提供的RKDevTool,选择固件进行升级,升级后,无法进行桌面,使用串口调试,进入如下界面后,卡死
界面内容如下:
Connecting to COM5...
Connected.
 楼主| 发表于 2024-3-25 10:18:29 | 显示全部楼层
[    3.140204] rk817-battery: Failed to locate of_node [id: -1]
[    3.140353] rk817-battery rk817-battery: Failed to find matching dt id
[    3.140473] rk817-charger: Failed to locate of_node [id: -1]
[    3.140567] rk817-charger rk817-charger: Failed to find matching dt id
[    3.143574] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[    3.149683] rk808-rtc rk808-rtc: registered as rtc0
[    3.151399] rk808-rtc rk808-rtc: setting system clock to 2017-08-04T09:00:03 UTC (1501837203)
[    3.153733] goodix_ts_probe() start
[    3.153913] got tp regulator ok
[    3.188863] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    3.259603] <<-GTP-ERROR->> I2C Rea
 楼主| 发表于 2024-3-25 11:19:05 | 显示全部楼层
附件中为错误日志
33333.zip
8.02 KB, 下载次数: 973
错误日志
GMT+8, 2026-11-11 02:57 , Processed in 0.078903 second(s), 25 queries .
