查看: 5680|回复: 1
dayu210 编译鸿蒙4.0的错误
发表于 2023-11-10 20:28:43 | 显示全部楼层 |阅读模式
硬件主板型号:dayu210
固件名称/系统版本:开源鸿蒙4.0
warning: subsystem name config incorrect in '/sdb1/work-source/OpenHarmony4.0/third_party/flutter/glfw/bundle.json', build file subsystem name is ,configured subsystem name is thirdparty.
warning: subsystem name config incorrect in '/sdb1/work-source/OpenHarmony4.0/third_party/wpa_supplicant/wpa_supplicant-2.9_standard/bundle.json', build file subsystem name is wpa_supplicant-2.9,configured subsystem name is thirdparty.
[OHOS ERROR] Traceback (most recent call last):
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/containers/status.py", line 47, in wrapper
[OHOS ERROR]     return func(*args, **kwargs)
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/modules/ohos_build_module.py", line 67, in run
[OHOS ERROR]     raise exception
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/modules/ohos_build_module.py", line 65, in run
[OHOS ERROR]     super().run()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/modules/interface/build_module_interface.py", line 72, in run
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/modules/interface/build_module_interface.py", line 65, in run
[OHOS ERROR]     self._load()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/modules/ohos_build_module.py", line 84, in _load
[OHOS ERROR]     self.loader.run()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/services/interface/load_interface.py", line 45, in run
[OHOS ERROR]     self.__post_init__()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/services/loader.py", line 120, in __post_init__
[OHOS ERROR]     self.parts_config_info = load_ohos_build.get_parts_info(
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/util/loader/load_ohos_build.py", line 834, in get_parts_info
[OHOS ERROR]     _parts_variants = build_loader.parts_variants()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/util/loader/load_ohos_build.py", line 520, in parts_variants
[OHOS ERROR]     self.parse()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/util/loader/load_ohos_build.py", line 511, in parse
[OHOS ERROR]     subsystem_config, parts_path_dict = self._merge_build_config()
[OHOS ERROR]   File "/sdb1/work-source/OpenHarmony4.0/build/hb/util/loader/load_ohos_build.py", line 482, in _merge_build_config
[OHOS ERROR]     raise OHOSException("subsystem name config incorrect in '{}', build file subsystem name is {},"
[OHOS ERROR] exceptions.ohos_exception.OHOSException: subsystem name config incorrect in '/sdb1/work-source/OpenHarmony4.0/vendor/hihope/dayu210/ohos.build', build file subsystem name is product_hihope,configured subsystem name is product_dayu210.
[OHOS ERROR]
[OHOS ERROR] Code:      2014
[OHOS ERROR]
[OHOS ERROR] Reason:    subsystem name config incorrect in '/sdb1/work-source/OpenHarmony4.0/vendor/hihope/dayu210/ohos.build', build file subsystem name is product_hihope,configured subsystem name is product_dayu210.
[OHOS ERROR]
[OHOS ERROR] Solution:  UNKNOWN REASON
[OHOS ERROR]
=====build  error=====
repo init -u git@gitee.com:bearkey/manifest.git -b bearkey-bq3588c-4.0release --no-repo-verify
repo sync -c
repo forall -c 'git lfs pull'
build/prebuilts_download.sh
./build.sh --product-name dayu210 --ccache
以上为官方提供的下载源码步骤和编译脚本,编译最后提示错误:  subsystem name config incorrect in '/sdb1/work-source/OpenHarmony4.0/vendor/hihope/dayu210/ohos.build', build file subsystem name is product_hihope,configured subsystem name is product_dayu210.
发表于 2023-11-12 15:15:13 | 显示全部楼层
repo sync -c命令更新下代码,再编译,就OK了
GMT+8, 2026-10-21 15:07 , Processed in 0.069506 second(s), 21 queries .
