查看: 5842|回复: 0
tinker board 2s 编译过程
发表于 2023-10-31 16:39:04 | 显示全部楼层 |阅读模式
硬件主板型号:tinker board 2s
固件名称/系统版本:Android 11
2023年10月22日 周日
报错1:
/usr/bin/ld: scripts/dtc/dtc-parser.tab.o.bss+0x10): multiple definition of `yylloc'; scripts/dtc/dtc-lexer.lex.o.bss+0x0): first defined here
collect2: error: ld returned 1 exit status
make[2]: *** [scripts/Makefile.host:108: scripts/dtc/dtc] Error 1
make[1]: *** [scripts/Makefile.build:425: scripts/dtc] Error 2
make: *** [Makefile:491: scripts] Error 2
解决办法:
diff --git a/u-boot/scripts/dtc/dtc-parser.tab.c_shipped b/u-boot/scripts/dtc/dtc-parser.tab.c_shipped
index aea514fa69..e70924a8ce 100644
--- a/u-boot/scripts/dtc/dtc-parser.tab.c_shipped
+++ b/u-boot/scripts/dtc/dtc-parser.tab.c_shipped
@@ -1202,7 +1202,7 @@ int yychar;
/* The semantic value of the lookahead symbol.  */
YYSTYPE yylval;
/* Location data for the lookahead symbol.  */
-YYLTYPE yylloc
+extern YYLTYPE yylloc
# if defined YYLTYPE_IS_TRIVIAL && YYLTYPE_IS_TRIVIAL
   =  1, 1, 1, 1
# endif
报错2
Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error
FATAL ERROR: Unable to parse input tree
  DTC     arch/arm/dts/rk3288-veyron-minnie.dtb
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3036-sdk.dtb] Error 1
make[2]: *** Waiting for unfinished jobs....
  DTC     arch/arm/dts/rk3288-vyasa.dtb
arch/arm/dts/rk3126-evb.dtb: Warning (reg_format): "reg" property in /syscon@20008000/usb2-phy@17c has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1)
arch/arm/dts/rk3126-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c
arch/arm/dts/rk3126-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c
arch/arm/dts/rk3128-evb.dtb: Warning (reg_format): "reg" property in /syscon@20008000/usb2-phy@17c has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1)
arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c
arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c
Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error
start=$(/home/yxl/tinker_Board_2s_Android11/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(/home/yxl/tinker_Board_2s_Android11/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3188-radxarock.dtb] Error 1
make[1]: *** [dts/Makefile:101: arch-dtbs] Error 2
make: *** [Makefile:882: dts/dt.dtb] Error 2
make: *** Waiting for unfinished jobs....
Build uboot failed!
Error: arch/arm/dts/.rk3328-evb.dtb.pre.tmp:301.1-10 syntax error
Error: arch/arm/dts/.rk3368-sheep.dtb.pre.tmp:288.1-10 syntax error
Error: arch/arm/dts/.rk3368-lion.dtb.pre.tmp:196.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3328-evb.dtb] Error 1
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-lion.dtb] Error 1
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-sheep.dtb] Error 1
Error: arch/arm/dts/.rk3368-px5-evb.dtb.pre.tmp:335.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-px5-evb.dtb] Error 1
Error: arch/arm/dts/.rk3368-geekbox.dtb.pre.tmp:320.1-10 syntax error
make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-geekbox.dtb] Error 1
Build uboot failed!
解决办法:
1. vi  u-boot/Makefile 添加 KBUILD_CFLAGS += $(call cc-disable-warning, address-of-packed-member)   位置的话理论上讲只要是没有if判断影响执行这句语句的位置都可以;
2. vi u-boot/arch/arm/dts/Makefile  CONFIG_ARCH_ROCKCHIP内把报错的dtb删掉;一般就是rk3036-sdk.dtb、rk3188-radxarock.dtb、rk3368-lion.dtb、rk3368-sheep.dtb、rk3368-geekbox.dtb、rk3368-px5-evb.dtb,我记得还有1~2个报错的dtb文件,请根据错误自行删除;
3. vi u-boot/scripts/dtc/dtc-lexer.l  搜索yylloc  把-YYLTYPE yylloc 整行删掉;
4.vi u-boot/scripts/dtc/dtc-lexer.lex.c_shipped 搜索yylloc 把-YYLTYPE yylloc 整行删掉;
报错3:
awk: line 2: function strtonum never defined
解决办法:
sudo apt-get install gawk
报错4:
error, forbidden warning
报错5:
/bin/sh: 1: lz4c: not found
报错4解决办法:
1、makefile文件的KBUILD_CFLAGS增加-w
diff --git a/kernel/Makefile b/kernel/Makefile
index 357bb313ad..44b1f794e5 100644
--- a/kernel/Makefile
+++ b/kernel/Makefile
@@ -463,6 +463,7 @@ KBUILD_CFLAGS   := -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs \
                   -fno-strict-aliasing -fno-common -fshort-wchar \
                   -Werror-implicit-function-declaration \
                   -Werror=return-type -Wno-format-security \
+                  -w \
                   -std=gnu89
KBUILD_CPPFLAGS := -D__KERNEL__
KBUILD_AFLAGS_KERNEL :=
2、gcc-wrapper.py中注释掉interpret_warning(line)即可
kernel\msm-4.9\scripts\gcc-wrapper.py
proc = subprocess.Popen(args, stderr=subprocess.PIPE)
        for line in proc.stderr:
            print >> sys.stderr, line,
            #interpret_warning(line) #注释掉这行
报错5解决办法:
sudo apt-get install liblz4-tool
报错6
error: hardware/rockchip/librga/Android.bp:18:1: module "gen_rga_api_version": module source path "hardware/rockchip/librga/.git" does not exist
error: hardware/rockchip/libmpimmz/Android.bp:7:1: module "gen_mmz_version": module source path "hardware/rockchip/libmpimmz/.git" does not exist
解决办法
由repo仓管理切换为单git仓管理,进行编译报错,删除对应.git即可
这是我编译过程的遇到的问题 已编译成功
GMT+8, 2026-10-29 03:11 , Processed in 0.112802 second(s), 20 queries .
