查看: 4953|回复: 0
rk3399pro的npu找不到
发表于 2023-10-31 10:54:50 | 显示全部楼层 |阅读模式
硬件主板型号:tinker edge R
固件名称/系统版本:Tinker_Edge_R-Debian-Buster-v2.0.5-20220217
[    1.880322] tinker-mcu: tinker_mcu_probe: address = 0x45
[    1.885656] tinker-mcu: tinker_mcu_probe: i2c_id= 0x4
[    1.890730] tinker-mcu: send_cmds: 80
[    1.894591] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.902017] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.909436] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.916859] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.924276] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.931536] tinker-mcu: send_cmds: send command failed
[    1.936695] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
[    1.943060] tinker-mcu: tinker_mcu_ili9881c_probe: address = 0x36
[    1.949202] tinker-mcu: tinker_mcu_ili9881c_probe: i2c_id= 0x4
[    1.955063] tinker-mcu: send_cmds: 04
[    1.958914] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.966335] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.973754] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.981173] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.988592] tinker-mcu: send_cmds: send command failed, ret = -6, retry again!
[    1.995855] tinker-mcu: send_cmds: send command failed
[    2.001014] tinker-mcu: tinker_mcu_ili9881c_probe: init_cmd_check[-6] failed, 0
1.dmesg发现 send_cmds出错,问一下对系统是否有影响
2.我发现如果插上usbhub,有可能会导致3399pro的npu找不到,为什么, npu_transfer_proxy devices 下面,列表为空
GMT+8, 2026-10-27 12:18 , Processed in 0.072813 second(s), 20 queries .
