查看: 7523|回复: 3
开发板烧录Ubuntu后无法进入系统
发表于 2023-10-17 09:34:03 | 显示全部楼层 |阅读模式
硬件主板型号:YY3568
固件名称/系统版本:Ubuntu20
自编的或固件下载地址:https://pan.baidu.com/s/1KbkK375qgouv6DoPx_t3bQ
问题描述及复现步骤:加载系统卡住,重复烧录都是卡在这个位置
 楼主| 发表于 2023-10-17 09:37:48 | 显示全部楼层
卡在如下位置
[    1.557401] cpuidle: using governor menu
[    1.558001] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    1.558754] ASID allocator initialised with 65536 entries
[    1.561270] ramoops: dmesg-0 0x20000@0x0000000000110000
[    1.561786] ramoops: console 0x80000@0x0000000000130000
[    1.562290] ramoops: pmsg    0x50000@0x00000000001b0000
[    1.563090] printk: console [ramoops-1] enabled
[    1.563520] pstore: Registered ramoops as persistent store backend
[    1.564123] ramoops: using 0xf0000@0x110000, ecc: 0
[    1.595433] rockchip-gpio fdd60000.gpio0: probed /pinctrl/gpio0@fdd60000
[    1.596525] rockchip-gpio fe740000.gpio1: probed /pinctrl/gpio1@fe740000
[    1.597703] rockchip-gpio fe750000.gpio2: probed /pinctrl/gpio2@fe750000
[    1.598822] rockchip-gpio fe760000.gpio3: probed /pinctrl/gpio3@fe760000
[    1.599908] rockchip-gpio fe770000.gpio4: probed /pinctrl/gpio4@fe770000
[    1.600611] rockchip-pinctrl pinctrl: probed pinctrl
[    1.622627] fiq_debugger fiq_debugger.0: IRQ fiq not found
[    1.623169] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[    1.623720] fiq_debugger_probe: could not install nmi irq handler
发表于 2023-10-17 09:56:47 | 显示全部楼层
风火轮用户ywK20 发表于 2023-10-17 09:37
卡在如下位置
[    1.558001] hw-breakpoint: found 6 break ...
这个不好判断,或者你联系一下客服,远程看一下
发表于 2023-10-17 11:46:35 | 显示全部楼层
卡在如下位置
你接显示屏看有没有启动,或者使用adb或者ssh看能不能登录。
Ubuntu的调试串口没有适配好,系统是正常启动的
GMT+8, 2026-11-8 14:32 , Processed in 0.095935 second(s), 24 queries .
