查看: 8881|回复: 3
YY3568 openHarmony获取源代码出错
发表于 2023-8-2 10:57:46 | 显示全部楼层 |阅读模式
硬件主板型号:YY3568
按指南操作获取源码是需要用户名和密码
../bin/repo sync -c
Fetching projects:  99% (346/347) kernel_linux_patchesremote: [session-2144d2ae] Unauthorized
fatal: Authentication failed for 'https://gitee.com/youyeetoo/vendor_yy3568/'
vendor_yy3568:
发表于 2023-8-2 11:04:52 | 显示全部楼层
现在开了,你再试一下
 楼主| 发表于 2023-8-3 12:13:25 | 显示全部楼层
可以了
 楼主| 发表于 2023-8-3 12:14:58 | 显示全部楼层
执行命令./build.sh --product-name yy3568 –ccache
出错
Error: /home/******/yy3568/out/kernel/src_tmp/linux-5.10/arch/arm64/boot/dts/rockchip/rk3568-toybrick-x0.dtsi:628.2-3 syntax error
FATAL ERROR: Unable to parse input tree
make[3]: *** [scripts/Makefile.lib:329: arch/arm64/boot/dts/rockchip/rk3568-toybrick-x0-linux.dtb] Error 1
make[2]: *** [/home/******/yy3568/out/kernel/src_tmp/linux-5.10/Makefile:1396: rockchip/rk3568-toybrick-x0-linux.dtb] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [arch/arm64/Makefile:208: rk3568-toybrick-x0-linux.img] Error 2
make[1]: Leaving directory '/home/******/yy3568/out/kernel/OBJ/linux-5.10'
make: *** [Makefile:185: __sub-make] Error 2
GMT+8, 2026-11-19 08:03 , Processed in 0.076380 second(s), 24 queries .
