查看: 5950|回复: 3
tinker board 2s 编译Android11源码报错
发表于 2023-6-8 23:47:50 | 显示全部楼层 |阅读模式
以下报错的代码
  1.   AR      drivers/iio/common/st_sensors/built-in.a
  2.   AR      drivers/iio/common/built-in.a
  3.   CC      drivers/hid/hid-tivo.o
  4.   AR      drivers/iio/counter/built-in.a
  5.   AR      drivers/iio/dac/built-in.a
  6.   AR      drivers/iio/dummy/built-in.a
  7.   AR      net/ipv6/built-in.a
  8.   AR      drivers/iio/frequency/built-in.a
  9.   CC      drivers/hid/hid-topseed.o
  10.   AR      drivers/iio/gyro/built-in.a
  11.   AR      drivers/iio/health/built-in.a
  12.   AR      drivers/iio/humidity/built-in.a
  13.   AR      drivers/iio/imu/bmi160/built-in.a
  14.   CC      drivers/iio/imu/icm20948/icm20948.o
  15.   AR      drivers/iio/imu/inv_mpu6050/built-in.a
  16.   CC      drivers/gpu/arm/bifrost/context/backend/mali_kbase_context_jm.o
  17.   CC      drivers/input/misc/uinput.o
  18.   CC      drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.o
  19.   AR      drivers/iio/imu/st_lsm6dsx/built-in.a
  20.   CC      drivers/gpu/arm/bifrost/ipa/mali_kbase_ipa_simple.o
  21.   CC      drivers/irqchip/irq-gic.o
  22.   CC      drivers/hid/hid-twinhan.o
  23.   CC      drivers/gpu/arm/midgard/mali_kbase_mem.o
  24.   CC      drivers/gpu/arm/midgard/mali_kbase_mmu.o
  25.   AR      drivers/iio/imu/icm20948/built-in.a
  26.   AR      drivers/iio/imu/built-in.a
  27.   AR      drivers/iio/light/built-in.a
  28.   AR      drivers/iio/magnetometer/built-in.a
  29.   AR      drivers/iio/multiplexer/built-in.a
  30.   AR      drivers/iio/orientation/built-in.a
  31.   AR      drivers/iio/potentiometer/built-in.a
  32.   AR      drivers/iio/potentiostat/built-in.a
  33.   AR      drivers/iio/pressure/built-in.a
  34.   CC      drivers/gpu/arm/mali400/mali/common/mali_dlbu.o
  35.   AR      drivers/iio/proximity/built-in.a
  36.   AR      drivers/iio/resolver/built-in.a
  37.   AR      drivers/iio/temperature/built-in.a
  38.   AR      drivers/iio/trigger/built-in.a
  39.   CC      drivers/gpu/arm/midgard/mali_kbase_ctx_sched.o
  40.   CC      drivers/iio/industrialio-core.o
  41.   CC      drivers/gpu/drm/drm_simple_kms_helper.o
  42.   AR      net/ipv4/built-in.a
  43.   CC      drivers/gpu/drm/drm_modeset_helper.o
  44.   CC      drivers/gpu/drm/drm_scdc_helper.o
  45.   CC      drivers/hid/hid-uclogic.o
  46.   CC      drivers/iommu/iommu-sysfs.o
  47.   AR      drivers/input/misc/built-in.a
  48.   CC      drivers/gpu/arm/midgard/mali_kbase_jd.o
  49.   CC      net/netfilter/xt_tcpudp.o
  50.   CC      drivers/input/remotectl/rockchip_pwm_remotectl.o
  51.   CC      drivers/irqchip/irq-gic-common.o
  52.   CC      drivers/hid/hid-led.o
  53.   CC      drivers/hid/hid-zpff.o
  54.   CC      drivers/gpu/arm/mali400/mali/common/mali_broadcast.o
  55.   CC      drivers/gpu/arm/bifrost/ipa/mali_kbase_ipa.o
  56.   CC      drivers/gpu/arm/bifrost/ipa/mali_kbase_ipa_vinstr_g7x.o
  57.   CC      drivers/gpu/arm/bifrost/ipa/mali_kbase_ipa_vinstr_common.o
  58.   CC      drivers/gpu/arm/bifrost/ipa/mali_kbase_ipa_debugfs.o
  59.   CC      drivers/iio/industrialio-event.o
  60.   CC      drivers/iio/inkern.o
  61.   CC      drivers/iommu/dma-iommu.o
  62.   CC      drivers/gpu/arm/mali400/mali/common/mali_pm.o
  63.   CC      drivers/gpu/drm/drm_gem_framebuffer_helper.o
  64.   CC      net/netfilter/xt_mark.o
  65.   AR      drivers/input/remotectl/built-in.a
  66.   CC      drivers/irqchip/irq-gic-v2m.o
  67.   CC      drivers/input/sensors/accel/kxtj9.o
  68.   CC      drivers/gpu/arm/midgard/mali_kbase_jd_debugfs.o
  69.   CC      drivers/input/sensors/accel/mma8452.o
  70.   CC      drivers/input/sensors/accel/lis3dh.o
  71.   CC      drivers/hid/hid-zydacron.o
  72.   CC      drivers/input/sensors/accel/mma7660.o
  73.   CC      drivers/input/sensors/accel/mxc6655xa.o
  74.   CC      drivers/input/sensors/accel/lsm303d.o
  75.   CC      drivers/gpu/arm/bifrost/mali_kbase_fence_ops.o
  76.   CC      drivers/input/sensors/accel/mc3230.o
  77.   CC      drivers/gpu/arm/midgard/mali_kbase_jm.o
  78.   CC      net/netfilter/xt_connmark.o
  79.   CC      drivers/hid/wacom_wac.o
  80.   CC      drivers/gpu/drm/bridge/panel.o
  81.   CC      drivers/irqchip/irq-gic-v3.o
  82.   CC      drivers/irqchip/irq-gic-v3-mbi.o
  83.   CC      drivers/irqchip/irq-gic-v3-its.o
  84.   CC      drivers/input/sensors/accel/mpu6880_acc.o
  85.   CC      drivers/gpu/arm/midgard/mali_kbase_gpuprops.o
  86.   CC      drivers/gpu/arm/midgard/mali_kbase_js.o
  87.   CC      drivers/gpu/arm/mali400/mali/common/mali_pmu.o
  88.   CC      drivers/hid/wacom_sys.o
  89.   CC      drivers/iio/industrialio-buffer.o
  90.   CC      drivers/iio/industrialio-trigger.o
  91.   CC      drivers/iommu/iova.o
  92.   CC      drivers/gpu/arm/midgard/mali_kbase_js_ctx_attr.o
  93.   CC      drivers/input/sensors/accel/sc7660.o
  94.   CC      drivers/gpu/arm/bifrost/mali_kbase_fence.o
  95.   CC      net/netfilter/xt_nat.o
  96.   CC      net/netfilter/xt_CLASSIFY.o
  97.   CC      drivers/gpu/drm/drm_fb_helper.o
  98.   CC      drivers/gpu/drm/drm_auth.o
  99.   CC      drivers/gpu/drm/drm_bufs.o
  100.   CC      drivers/gpu/arm/mali400/mali/common/mali_user_settings_db.o
  101.   CC      drivers/gpu/arm/mali400/mali/common/mali_kernel_utilization.o
  102.   CC      drivers/gpu/arm/mali400/mali/common/mali_control_timer.o
  103.   AR      drivers/iio/built-in.a
  104.   CC      drivers/gpu/arm/midgard/mali_kbase_event.o
  105.   CC      drivers/input/sensors/accel/sc7a20.o
  106.   CC      net/netfilter/xt_CONNSECMARK.o
  107.   CC      drivers/input/sensors/accel/sc7a30.o
  108.   CC      drivers/input/sensors/accel/mpu6500_acc.o
  109.   CC      drivers/hid/hid-waltop.o
  110.   CC      drivers/irqchip/irq-gic-v3-its-platform-msi.o
  111.   CC      drivers/hid/hid-wiimote-core.o
  112.   CC      drivers/hid/hid-wiimote-modules.o
  113.   CC      drivers/gpu/drm/drm_cache.o
  114.   CC      drivers/iommu/of_iommu.o
  115.   CC      drivers/gpu/arm/bifrost/mali_kbase_sync_file.o
  116.   CC      drivers/gpu/arm/bifrost/mali_kbase_sync_common.o
  117.   CC      drivers/gpu/arm/mali400/mali/common/mali_l2_cache.o
  118.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_cache_policy_backend.o
  119.   CC      drivers/gpu/arm/mali400/mali/common/mali_timeline.o
  120.   CC      drivers/gpu/arm/mali400/mali/common/mali_timeline_fence_wait.o
  121.   CC      drivers/gpu/arm/midgard/mali_kbase_context.o
  122.   CC      drivers/gpu/arm/mali400/mali/common/mali_timeline_sync_fence.o
  123.   CC      drivers/irqchip/irq-gic-v4.o
  124.   CC      net/netfilter/xt_CT.o
  125.   CC      net/netfilter/xt_LOG.o
  126.   CC      drivers/gpu/drm/drm_context.o
  127.   CC      drivers/iommu/rockchip-iommu.o
  128.   CC      drivers/input/sensors/accel/lsm330_acc.o
  129.   CC      net/netfilter/xt_NETMAP.o
  130.   CC      net/netfilter/xt_NFLOG.o
  131.   CC      net/netfilter/xt_NFQUEUE.o
  132.   CC      net/netfilter/xt_REDIRECT.o
  133.   CC      net/netfilter/xt_SECMARK.o
  134.   CC      net/netfilter/xt_TPROXY.o
  135.   CC      drivers/gpu/arm/mali400/mali/common/mali_spinlock_reentrant.o
  136.   CC      drivers/irqchip/irq-gic-v3-its-pci-msi.o
  137.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_gpuprops_backend.o
  138.   CC      drivers/input/sensors/accel/bma2xx.o
  139.   CC      drivers/gpu/arm/midgard/mali_kbase_pm.o
  140.   CC      drivers/hid/hid-wiimote-debug.o
  141.   CC      drivers/gpu/arm/mali400/mali/common/mali_pm_domain.o
  142.   CC      drivers/gpu/arm/mali400/mali/linux/mali_osk_pm.o
  143.   CC      drivers/gpu/drm/drm_dma.o
  144.   CC      drivers/irqchip/irq-partition-percpu.o
  145.   CC      drivers/gpu/arm/mali400/mali/linux/mali_pmu_power_up_down.o
  146.   CC      drivers/input/sensors/accel/da223_cust.o
  147.   CC      drivers/input/sensors/accel/da223_core.o
  148.   CC      drivers/gpu/drm/drm_file.o
  149.   CC      drivers/gpu/drm/drm_gem.o
  150.   CC      drivers/gpu/arm/mali400/mali/__malidrv_build_info.o
  151.   CC      drivers/gpu/drm/drm_ioctl.o
  152.   AR      drivers/hid/built-in.a
  153.   CC      drivers/input/sensors/compass/ak8975.o
  154.   CC      drivers/input/sensors/gyro/l3g4200d.o
  155.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_irq_linux.o
  156.   CC      net/netfilter/xt_TCPMSS.o
  157.   CC      net/netfilter/xt_TRACE.o
  158.   CC      net/netfilter/xt_IDLETIMER.o
  159.   CC      drivers/gpu/arm/midgard/mali_kbase_config.o
  160.   CC      drivers/gpu/arm/midgard/mali_kbase_vinstr.o
  161.   AR      drivers/irqchip/built-in.a
  162.   CC      drivers/gpu/arm/midgard/mali_kbase_softjobs.o
  163.   AR      drivers/iommu/built-in.a
  164.   CC      drivers/gpu/arm/mali400/mali/linux/mali_memory_dma_buf.o
  165.   CC      drivers/leds/trigger/ledtrig-timer.o
  166.   CC      drivers/leds/trigger/ledtrig-oneshot.o
  167.   CC      drivers/input/sensors/gyro/l3g20d.o
  168.   AR      drivers/input/sensors/accel/built-in.a
  169.   CC      drivers/input/sensors/gyro/ewtsa.o
  170.   CC      drivers/input/sensors/compass/ak8963.o
  171.   CC      drivers/input/sensors/gyro/mpu6500_gyro.o
  172.   CC      drivers/input/sensors/gyro/mpu6880_gyro.o
  173.   CC      drivers/input/sensors/gyro/lsm330_gyro.o
  174.   CC      drivers/gpu/drm/drm_irq.o
  175.   CC      drivers/gpu/drm/drm_lock.o
  176.   CC      drivers/leds/trigger/ledtrig-heartbeat.o
  177.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_instr_backend.o
  178.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_js_backend.o
  179.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_backend.o
  180.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_driver.o
  181.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_metrics.o
  182.   CC      net/netfilter/xt_bpf.o
  183.   CC      drivers/gpu/arm/mali400/mali/linux/mali_memory_secure.o
  184.   CC      drivers/gpu/arm/mali400/mali/linux/mali_sync.o
  185.   CC      drivers/gpu/arm/mali400/mali/linux/mali_internal_sync.o
  186.   AR      drivers/input/sensors/gyro/built-in.a
  187.   CC      drivers/leds/trigger/ledtrig-backlight.o
  188.   AR      drivers/input/sensors/compass/built-in.a
  189.   CC      drivers/leds/trigger/ledtrig-gpio.o
  190.   CC      drivers/input/sensors/hall/mh248.o
  191.   CC      drivers/input/sensors/lsensor/cm3217.o
  192.   CC      drivers/gpu/arm/midgard/mali_kbase_10969_workaround.o
  193.   CC      drivers/gpu/arm/midgard/mali_kbase_hw.o
  194.   CC      drivers/gpu/arm/midgard/mali_kbase_utility.o
  195.   CC      drivers/input/sensors/psensor/ps_stk3410.o
  196.   CC      drivers/input/sensors/sensor-i2c.o
  197.   CC      drivers/leds/trigger/ledtrig-cpu.o
  198.   CC      drivers/gpu/drm/drm_memory.o
  199.   CC      drivers/gpu/drm/drm_drv.o
  200.   AR      drivers/input/sensors/hall/built-in.a
  201.   AR      drivers/macintosh/built-in.a
  202.   CC      drivers/input/sensors/lsensor/cm3218.o
  203.   CC      drivers/input/sensors/lsensor/ls_stk3410.o
  204.   CC      drivers/leds/led-core.o
  205.   CC      net/netfilter/xt_comment.o
  206.   CC      net/netfilter/xt_connlimit.o
  207.   CC      net/netfilter/xt_conntrack.o
  208.   AR      drivers/gpu/arm/mali400/mali/built-in.a
  209.   AR      drivers/gpu/arm/mali400/built-in.a
  210.   CC      drivers/mailbox/mailbox.o
  211.   CC      drivers/leds/trigger/ledtrig-default-on.o
  212.   CC      drivers/mailbox/rk3368-mailbox.o
  213.   CC      drivers/mailbox/scpi_protocol.o
  214.   AR      drivers/input/sensors/psensor/built-in.a
  215.   CC      drivers/md/dm-uevent.o
  216.   CC      drivers/media/cec/cec-core.o
  217.   AR      drivers/input/sensors/lsensor/built-in.a
  218.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_ca.o
  219.   CC      drivers/gpu/arm/midgard/mali_kbase_debug.o
  220.   CC      drivers/input/sensors/sensor-dev.o
  221.   CC      drivers/gpu/arm/midgard/mali_kbase_trace_timeline.o
  222.   CC      drivers/gpu/arm/midgard/mali_kbase_gpu_memory_debugfs.o
  223.   AR      drivers/media/common/b2c2/built-in.a
  224.   AR      drivers/media/common/saa7146/built-in.a
  225.   AR      drivers/media/common/siano/built-in.a
  226.   AR      drivers/media/common/v4l2-tpg/built-in.a
  227.   CC      drivers/media/common/videobuf2/videobuf2-core.o
  228.   CC      drivers/gpu/drm/drm_scatter.o
  229.   AR      drivers/leds/trigger/built-in.a
  230.   CC      drivers/leds/led-class.o
  231.   CC      drivers/leds/led-class-flash.o
  232.   CC      drivers/leds/led-triggers.o
  233.   CC      net/netfilter/xt_ecn.o
  234.   CC      drivers/mfd/mfd-core.o
  235.   CC      drivers/mfd/rk618.o
  236.   AR      drivers/mailbox/built-in.a
  237.   CC      drivers/mfd/rk628.o
  238.   CC      drivers/mfd/rk630.o
  239.   CC      drivers/gpu/drm/drm_pci.o
  240.   CC      drivers/media/cec/cec-adap.o
  241.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_always_on.o
  242.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_coarse_demand.o
  243.   CC      drivers/md/dm.o
  244.   CC      drivers/md/dm-table.o
  245.   CC      drivers/md/dm-target.o
  246.   CC      drivers/leds/leds-gpio.o
  247.   CC      drivers/gpu/arm/midgard/mali_kbase_mem_linux.o
  248.   CC      drivers/leds/leds-rgb13h.o
  249.   AR      drivers/media/firewire/built-in.a
  250.   CC      drivers/gpu/drm/drm_sysfs.o
  251.   CC      net/netfilter/xt_hashlimit.o
  252.   CC      net/netfilter/xt_helper.o
  253.   AR      drivers/input/sensors/built-in.a
  254.   CC      drivers/input/tablet/acecad.o
  255.   AR      drivers/misc/cb710/built-in.a
  256.   CC      drivers/misc/eeprom/at24.o
  257.   CC      drivers/gpu/drm/drm_hashtab.o
  258.   CC      drivers/mfd/rk630-i2c.o
  259.   CC      drivers/mfd/rk808.o
  260.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_pm_policy.o
  261.   AR      drivers/leds/built-in.a
  262.   CC      drivers/mfd/rk1000-core.o
  263.   CC      drivers/mfd/syscon.o
  264.   CC      drivers/md/dm-linear.o
  265.   CC      drivers/input/tablet/aiptek.o
  266.   AR      drivers/misc/eeprom/built-in.a
  267.   AR      drivers/misc/lis3lv02d/built-in.a
  268.   AR      drivers/misc/mic/bus/built-in.a
  269.   CC      drivers/media/cec/cec-api.o
  270.   AR      drivers/misc/mic/built-in.a
  271.   AR      drivers/misc/ti-st/built-in.a
  272.   CC      drivers/misc/sram.o
  273.   CC      drivers/md/dm-stripe.o
  274.   CC      drivers/media/common/videobuf2/vb2-trace.o
  275.   CC      drivers/media/common/videobuf2/videobuf2-v4l2.o
  276.   CC      drivers/media/common/videobuf2/videobuf2-memops.o
  277.   CC      net/netfilter/xt_hl.o
  278.   CC      drivers/gpu/drm/drm_mm.o
  279.   CC      drivers/mfd/fusb302.o
  280.   CC      net/netfilter/xt_iprange.o
  281.   CC      drivers/misc/uid_sys_stats.o
  282.   CC      drivers/misc/tinker_mcu.o
  283.   CC      drivers/misc/tinker_mcu_ili9881c.o
  284.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_time.o
  285.   CC      drivers/gpu/arm/midgard/mali_kbase_core_linux.o
  286.   CC      drivers/md/dm-ioctl.o
  287.   CC      drivers/input/tablet/gtco.o
  288.   CC      drivers/input/tablet/hanwang.o
  289.   CC      drivers/media/cec/cec-notifier.o
  290.   CC      drivers/input/tablet/kbtab.o
  291.   CC      drivers/gpu/drm/drm_crtc.o
  292.   CC      drivers/media/common/videobuf2/videobuf2-vmalloc.o
  293.   CC      drivers/media/common/videobuf2/videobuf2-dma-contig.o
  294.   CC      net/netfilter/xt_l2tp.o
  295.   CC      net/netfilter/xt_length.o
  296.   CC      net/netfilter/xt_limit.o
  297.   CC      drivers/media/common/videobuf2/videobuf2-dma-sg.o
  298.   AR      drivers/input/tablet/built-in.a
  299.   CC      drivers/media/i2c/cam_sensor/cam_sensor_core.o
  300.   AR      drivers/misc/built-in.a
  301.   CC      drivers/input/input.o
  302.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_core.o
  303.   CC      drivers/input/input-compat.o
  304.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_l2_mmu_config.o
  305.   AR      drivers/media/cec/built-in.a
  306.   CC      drivers/input/input-mt.o
  307.   CC      drivers/media/i2c/cam_sensor/cam_imx219.o
  308.   CC      drivers/md/dm-io.o
  309.   AR      drivers/media/mmc/siano/built-in.a
  310.   AR      drivers/media/mmc/built-in.a
  311.   CC      drivers/md/dm-kcopyd.o
  312.   CC      drivers/md/dm-sysfs.o
  313.   CC      drivers/gpu/drm/drm_fourcc.o
  314.   AR      drivers/mfd/built-in.a
  315.   CC      drivers/media/i2c/cam_sensor/cam_ov5647.o
  316.   CC      net/netfilter/xt_mac.o
  317.   CC      net/netfilter/xt_multiport.o
  318.   CC      drivers/gpu/arm/midgard/mali_kbase_replay.o
  319.   AR      drivers/media/common/videobuf2/built-in.a
  320.   AR      drivers/media/common/built-in.a
  321.   CC      drivers/gpu/arm/midgard/mali_kbase_mem_profile_debugfs.o
  322.   CC      drivers/gpu/arm/midgard/mali_kbase_mmu_mode_lpae.o
  323.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_clk_rate_trace_mgr.o
  324.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_jm_as.o
  325. drivers/media/i2c/cam_sensor/cam_imx219.c: In function 'imx219_probe':
  326. drivers/media/i2c/cam_sensor/cam_imx219.c:1068:22: warning: unused variable 'node' [-Wunused-variable]
  327. error, forbidden warning:cam_imx219.c:1068
  328.   struct device_node *node = dev->of_node;
  329.                       ^~~~
  330. scripts/Makefile.build:333: recipe for target 'drivers/media/i2c/cam_sensor/cam_imx219.o' failed
  331. make[4]: *** [drivers/media/i2c/cam_sensor/cam_imx219.o] Error 1
  332. make[4]: *** Waiting for unfinished jobs....
  333.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_flash/focaltech_upgrade_ft8201.o
  334.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_test/supported_ic/focaltech_test_ft8201.o
  335.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_test/focaltech_test.o
  336. scripts/Makefile.build:637: recipe for target 'drivers/media/i2c/cam_sensor' failed
  337. make[3]: *** [drivers/media/i2c/cam_sensor] Error 2
  338. scripts/Makefile.build:637: recipe for target 'drivers/media/i2c' failed
  339. make[2]: *** [drivers/media/i2c] Error 2
  340. make[2]: *** Waiting for unfinished jobs....
  341.   AR      drivers/media/pci/b2c2/built-in.a
  342.   CC      drivers/input/touchscreen/gsl3676/gsl3676.o
  343.   AR      drivers/media/pci/ddbridge/built-in.a
  344.   AR      drivers/media/pci/dm1105/built-in.a
  345.   CC      drivers/gpu/arm/midgard/mali_kbase_mmu_mode_aarch64.o
  346.   AR      drivers/media/pci/intel/ipu3/built-in.a
  347.   AR      drivers/media/pci/intel/built-in.a
  348.   CC      drivers/gpu/arm/midgard/mali_kbase_disjoint_events.o
  349.   AR      drivers/media/pci/mantis/built-in.a
  350.   AR      drivers/media/pci/netup_unidvb/built-in.a
  351.   AR      drivers/media/pci/ngene/built-in.a
  352.   CC      drivers/gpu/drm/drm_modes.o
  353.   AR      drivers/media/pci/pluto2/built-in.a
  354.   AR      drivers/media/pci/pt1/built-in.a
  355.   CC      net/netfilter/xt_owner.o
  356.   CC      net/netfilter/xt_pkttype.o
  357.   CC      drivers/gpu/drm/drm_edid.o
  358.   AR      drivers/media/pci/pt3/built-in.a
  359.   AR      drivers/media/pci/saa7146/built-in.a
  360.   AR      drivers/media/pci/smipcie/built-in.a
  361.   AR      drivers/media/pci/ttpci/built-in.a
  362.   AR      drivers/media/pci/built-in.a
  363. scripts/Makefile.build:637: recipe for target 'drivers/media' failed
  364. make[1]: *** [drivers/media] Error 2
  365. make[1]: *** Waiting for unfinished jobs....
  366.   CC      drivers/md/dm-stats.o
  367.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_debug_job_fault_backend.o
  368.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_jm_hw.o
  369.   CC      drivers/input/touchscreen/gt1x/gt1x_extents.o
  370.   CC      drivers/input/touchscreen/gt1x/gt1x_generic.o
  371.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_core.o
  372.   CC      drivers/gpu/arm/midgard/mali_kbase_gator_api.o
  373.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_ex_fun.o
  374.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_ex_mode.o
  375.   AR      drivers/input/touchscreen/focaltech_touch/focaltech_flash/built-in.a
  376.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_jm_rb.o
  377.   CC      net/netfilter/xt_policy.o
  378.   AR      drivers/input/touchscreen/gsl3676/built-in.a
  379.   CC      net/netfilter/xt_quota.o
  380.   AR      drivers/input/touchscreen/focaltech_touch/focaltech_test/supported_ic/built-in.a
  381.   CC      net/netfilter/xt_quota2.o
  382.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_mt_common.o
  383.   CC      drivers/md/dm-rq.o
  384.   CC      drivers/input/ff-core.o
  385.   CC      drivers/input/ff-memless.o
  386.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_test/focaltech_test_ini.o
  387.   CC      drivers/input/touchscreen/gt1x/gt1x_tools.o
  388.   CC      drivers/input/touchscreen/gt1x/gt1x.o
  389.   CC      drivers/input/touchscreen/gt1x/gt1x_update.o
  390.   CC      net/netfilter/xt_socket.o
  391.   CC      net/netfilter/xt_state.o
  392.   CC      drivers/gpu/arm/bifrost/backend/gpu/mali_kbase_devfreq.o
  393.   CC      net/netfilter/xt_statistic.o
  394.   CC      drivers/gpu/arm/midgard/mali_kbase_debug_mem_view.o
  395.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_flash.o
  396.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_gesture.o
  397.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_esdcheck.o
  398.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_mtb.o
  399.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_i2c.o
  400.   CC      drivers/input/input-polldev.o
  401.   CC      drivers/input/touchscreen/gt9xx/gt9xx.o
  402.   CC      drivers/gpu/arm/midgard/mali_kbase_debug_job_fault.o
  403.   AR      drivers/input/touchscreen/gt1x/built-in.a
  404.   CC      drivers/gpu/arm/midgard/mali_kbase_smc.o
  405.   CC      drivers/gpu/arm/midgard/mali_kbase_mem_pool.o
  406.   CC      drivers/gpu/arm/midgard/mali_kbase_mem_pool_debugfs.o
  407.   CC      drivers/md/dm-builtin.o
  408.   CC      drivers/gpu/drm/drm_info.o
  409.   CC      net/netfilter/xt_string.o
  410.   AR      drivers/input/touchscreen/focaltech_touch/focaltech_test/built-in.a
  411.   CC      net/netfilter/xt_time.o
  412.   CC      drivers/input/touchscreen/gt9xx/gt9xx_update.o
  413.   CC      net/netfilter/xt_u32.o
  414.   CC      drivers/gpu/arm/midgard/mali_kbase_tlstream.o
  415.   AR      drivers/gpu/arm/bifrost/built-in.a
  416.   CC      drivers/gpu/arm/midgard/mali_kbase_strings.o
  417.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_devtree.o
  418.   CC      drivers/input/touchscreen/focaltech_touch/focaltech_point_report_check.o
  419.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_platform.o
  420.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_i2c.o
  421.   CC      drivers/input/input-leds.o
  422.   CC      drivers/md/dm-bufio.o
  423.   CC      drivers/gpu/drm/drm_encoder_slave.o
  424.   CC      drivers/gpu/drm/drm_trace_points.o
  425.   CC      drivers/gpu/drm/drm_global.o
  426.   CC      drivers/gpu/drm/drm_prime.o
  427.   CC      drivers/input/evdev.o
  428.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_loader.o
  429.   AR      net/netfilter/built-in.a
  430.   AR      net/built-in.a
  431.   CC      drivers/gpu/arm/midgard/mali_kbase_as_fault_debugfs.o
  432.   CC      drivers/gpu/arm/midgard/mali_kbase_regs_history_debugfs.o
  433.   CC      drivers/gpu/drm/drm_rect.o
  434.   AR      drivers/input/touchscreen/focaltech_touch/built-in.a
  435.   CC      drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.o
  436.   CC      drivers/input/touchscreen/cyttsp5/cyttsp5_device_access.o
  437.   CC      drivers/gpu/arm/midgard/ipa/mali_kbase_ipa_simple.o
  438.   CC      drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.o
  439.   AR      drivers/input/touchscreen/gt9xx/built-in.a
  440.   CC      drivers/gpu/arm/midgard/ipa/mali_kbase_ipa_debugfs.o
  441.   CC      drivers/gpu/arm/midgard/mali_kbase_sync_file.o
  442.   CC      drivers/gpu/drm/drm_vma_manager.o
  443.   CC      drivers/gpu/arm/midgard/mali_kbase_sync_common.o
  444.   CC      drivers/md/dm-crypt.o
  445.   CC      drivers/md/dm-default-key.o
  446.   CC      drivers/input/touchscreen/hyn_cst2xx/hyn_cst2xx.o
  447.   CC      drivers/input/touchscreen/of_touchscreen.o
  448.   CC      drivers/input/touchscreen/gslx6801.o
  449.   CC      drivers/input/touchscreen/gsl_point_id.o
  450.   CC      drivers/input/touchscreen/gslx680_pad.o
  451.   CC      drivers/input/touchscreen/gslx680.o
  452.   CC      drivers/md/dm-snap.o
  453.   CC      drivers/md/dm-exception-store.o
  454.   CC      drivers/md/dm-snap-transient.o
  455.   CC      drivers/gpu/arm/midgard/mali_kbase_fence.o
  456.   CC      drivers/gpu/drm/drm_flip_work.o
  457.   CC      drivers/gpu/drm/drm_modeset_lock.o
  458.   CC      drivers/gpu/drm/drm_atomic.o
  459.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_cache_policy_backend.o
  460.   CC      drivers/input/touchscreen/gsl3673.o
  461.   CC      drivers/input/touchscreen/gsl3673_800x1280.o
  462.   CC      drivers/md/dm-snap-persistent.o
  463.   CC      drivers/md/dm-verity-avb.o
  464.   AR      drivers/input/touchscreen/hyn_cst2xx/built-in.a
  465.   CC      drivers/md/dm-verity-fec.o
  466.   CC      drivers/gpu/drm/drm_bridge.o
  467.   CC      drivers/gpu/drm/drm_framebuffer.o
  468.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_device_hw.o
  469.   CC      drivers/md/dm-verity-target.o
  470.   CC      drivers/md/dm-bow.o
  471.   CC      drivers/md/dm-user.o
  472.   CC      drivers/gpu/drm/drm_connector.o
  473.   AR      drivers/input/touchscreen/cyttsp5/built-in.a
  474.   CC      drivers/gpu/drm/drm_blend.o
  475.   CC      drivers/gpu/drm/drm_encoder.o
  476.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_gpu.o
  477.   CC      drivers/gpu/drm/drm_mode_object.o
  478.   CC      drivers/gpu/drm/drm_property.o
  479.   CC      drivers/gpu/drm/drm_plane.o
  480.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_gpuprops_backend.o
  481.   CC      drivers/input/touchscreen/wacom_w9013.o
  482.   CC      drivers/input/touchscreen/tinker_ft5406.o
  483.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_debug_job_fault_backend.o
  484.   CC      drivers/gpu/drm/drm_color_mgmt.o
  485.   CC      drivers/gpu/drm/drm_print.o
  486.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_irq_linux.o
  487.   CC      drivers/gpu/drm/drm_dumb_buffers.o
  488.   AR      drivers/md/built-in.a
  489.   CC      drivers/gpu/drm/drm_mode_config.o
  490.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_instr_backend.o
  491.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_jm_as.o
  492.   CC      drivers/gpu/drm/drm_vblank.o
  493.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_jm_hw.o
  494.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_jm_rb.o
  495.   AR      drivers/input/touchscreen/built-in.a
  496.   AR      drivers/input/built-in.a
  497.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_js_affinity.o
  498.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_js_backend.o
  499.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_mmu_hw_direct.o
  500.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_backend.o
  501.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_driver.o
  502.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_metrics.o
  503.   CC      drivers/gpu/drm/drm_syncobj.o
  504.   CC      drivers/gpu/drm/drm_lease.o
  505.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_ca.o
  506.   CC      drivers/gpu/drm/drm_writeback.o
  507.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_ca_fixed.o
  508.   CC      drivers/gpu/drm/drm_client.o
  509.   CC      drivers/gpu/drm/drm_ioc32.o
  510.   CC      drivers/gpu/drm/drm_gem_cma_helper.o
  511.   CC      drivers/gpu/drm/ati_pcigart.o
  512.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_always_on.o
  513.   CC      drivers/gpu/drm/drm_panel.o
  514.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_coarse_demand.o
  515.   CC      drivers/gpu/drm/drm_of.o
  516.   CC      drivers/gpu/drm/drm_debugfs.o
  517.   CC      drivers/gpu/drm/drm_debugfs_crc.o
  518.   CC      drivers/gpu/drm/drm_edid_load.o
  519.   CC      drivers/gpu/drm/drm_mipi_dsi.o
  520.   CC      drivers/gpu/drm/drm_panel_orientation_quirks.o
  521.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_demand.o
  522.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_policy.o
  523.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_time.o
  524.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.o
  525.   CC      drivers/gpu/arm/midgard/backend/gpu/mali_kbase_pm_ca_devfreq.o
  526.   AR      drivers/gpu/drm/built-in.a
  527.   AR      drivers/gpu/arm/midgard/built-in.a
  528.   AR      drivers/gpu/arm/built-in.a
  529.   AR      drivers/gpu/built-in.a
  530. Makefile:1201: recipe for target 'drivers' failed
  531. make: *** [drivers] Error 2
  532. #### failed to build some targets (02:10 (mm:ss)) ####
  533. Build kernel failed!
使用的编译命令:
source build/envsetup.shlunch WW_Tinker_Board_2-userdebug./build.sh -UKAu
发表于 2023-6-9 09:45:34 | 显示全部楼层
./docker_builder/docker-builder-run.sh运行了吗
 楼主| 发表于 2023-6-9 19:42:42 | 显示全部楼层
我还没安装docker。
 楼主| 发表于 2023-6-9 21:35:40 | 显示全部楼层
你好,我尝试了运行
  1. ./docker_builder/docker-builder-run.sh
还是同样的报错。
GMT+8, 2026-10-29 03:12 , Processed in 0.091295 second(s), 25 queries .
