查看: 8886|回复: 6
youyeetoo的镜像烧录不进开发板
发表于 2023-6-4 18:29:06 | 显示全部楼层 |阅读模式
  1. DDR Version V1.13 20220218
  2. In
  3. ddrconfig:7
  4. LP4 MR14:0x4d
  5. LPDDR4, 324MHz
  6. BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
  7. tdqss: cs0 dqs0: 385ps, dqs1: 289ps, dqs2: 337ps, dqs3: 217ps,
  8. tdqss: cs1 dqs0: 385ps, dqs1: 289ps, dqs2: 337ps, dqs3: 241ps,
  9. change to: 324MHz
  10. PHY drv:clk:38,ca:38,DQ:30,odt:0
  11. vrefinner:41%, vrefout:41%
  12. dram drv:40,odt:0
  13. clk skew:0x58
  14. change to: 528MHz
  15. PHY drv:clk:38,ca:38,DQ:30,odt:0
  16. vrefinner:41%, vrefout:41%
  17. dram drv:40,odt:0
  18. clk skew:0x7c
  19. change to: 780MHz
  20. PHY drv:clk:38,ca:38,DQ:30,odt:0
  21. vrefinner:41%, vrefout:41%
  22. dram drv:40,odt:0
  23. clk skew:0x64
  24. change to: 1560MHz(final freq)
  25. PHY drv:clk:38,ca:38,DQ:30,odt:60
  26. vrefinner:16%, vrefout:29%
  27. dram drv:40,odt:80
  28. vref_ca:00000068
  29. clk skew:0x18
  30. cs 0:
  31. the read training result:
  32. DQS0:0x2b, DQS1:0x27, DQS2:0x31, DQS3:0x30,
  33. min  :0x11 0x15 0x16 0x10  0x2  0x6  0x9  0x6 , 0xd  0xb  0x2  0x2  0xc  0xb 0x10  0x9 ,
  34.       0x11 0x15  0xe  0xa  0x4  0x2  0x2  0x4 ,0x10  0xa  0xe  0x2 0x10 0x10 0x12 0x11 ,
  35. mid  :0x26 0x28 0x29 0x24 0x17 0x1b 0x1d 0x1b ,0x21 0x1e 0x17 0x15 0x20 0x1f 0x22 0x1d ,
  36.       0x2b 0x2c 0x26 0x23 0x1c 0x1a 0x1b 0x1d ,0x28 0x23 0x24 0x1b 0x28 0x2a 0x29 0x29 ,
  37. max  :0x3c 0x3c 0x3d 0x38 0x2c 0x30 0x31 0x30 ,0x36 0x32 0x2d 0x29 0x34 0x34 0x35 0x31 ,
  38.       0x46 0x44 0x3f 0x3c 0x34 0x32 0x34 0x36 ,0x41 0x3d 0x3b 0x35 0x41 0x44 0x41 0x42 ,
  39. range:0x2b 0x27 0x27 0x28 0x2a 0x2a 0x28 0x2a ,0x29 0x27 0x2b 0x27 0x28 0x29 0x25 0x28 ,
  40.       0x35 0x2f 0x31 0x32 0x30 0x30 0x32 0x32 ,0x31 0x33 0x2d 0x33 0x31 0x34 0x2f 0x31 ,
  41. the write training result:
  42. DQS0:0x64, DQS1:0x51, DQS2:0x5b, DQS3:0x43,
  43. min  :0x91 0x95 0x96 0x92 0x82 0x88 0x8c 0x8e 0x8d ,0x7e 0x7c 0x74 0x75 0x7d 0x7f 0x81 0x7f 0x78 ,
  44.       0x90 0x8f 0x8a 0x8a 0x7d 0x7c 0x7f 0x86 0x85 ,0x71 0x70 0x6f 0x69 0x73 0x76 0x73 0x79 0x6e ,
  45. mid  :0xad 0xb1 0xb1 0xad 0x9d 0xa2 0xa7 0xa7 0xa5 ,0x98 0x96 0x8f 0x8f 0x97 0x96 0x99 0x98 0x91 ,
  46.       0xab 0xaa 0xa3 0xa3 0x97 0x95 0x98 0x9e 0x9e ,0x8d 0x89 0x88 0x83 0x8d 0x92 0x8d 0x93 0x88 ,
  47. max  :0xca 0xcd 0xcd 0xc9 0xb8 0xbc 0xc2 0xc1 0xbd ,0xb2 0xb1 0xaa 0xa9 0xb1 0xae 0xb2 0xb2 0xab ,
  48.       0xc6 0xc5 0xbc 0xbc 0xb2 0xaf 0xb2 0xb6 0xb7 ,0xaa 0xa3 0xa1 0x9d 0xa7 0xae 0xa8 0xad 0xa3 ,
  49. range:0x39 0x38 0x37 0x37 0x36 0x34 0x36 0x33 0x30 ,0x34 0x35 0x36 0x34 0x34 0x2f 0x31 0x33 0x33 ,
  50.       0x36 0x36 0x32 0x32 0x35 0x33 0x33 0x30 0x32 ,0x39 0x33 0x32 0x34 0x34 0x38 0x35 0x34 0x35 ,
  51. cs 1:
  52. the read training result:
  53. DQS0:0x2c, DQS1:0x28, DQS2:0x32, DQS3:0x2f,
  54. min  :0x11 0x13 0x15 0x11  0x2  0x8  0xc  0x7 , 0xc  0xc  0x2  0x2  0xb  0xa  0xf  0x7 ,
  55.       0x13 0x13  0xc  0x9  0x4  0x2  0x3  0x2 ,0x11  0x8  0xe  0x2 0x11  0xe 0x13  0xe ,
  56. mid  :0x26 0x28 0x29 0x25 0x17 0x1d 0x20 0x1c ,0x21 0x1f 0x17 0x15 0x1f 0x1e 0x22 0x1c ,
  57.       0x2d 0x2b 0x25 0x22 0x1c 0x19 0x1b 0x1b ,0x28 0x22 0x24 0x1b 0x28 0x27 0x29 0x27 ,
  58. max  :0x3c 0x3d 0x3e 0x3a 0x2c 0x32 0x34 0x31 ,0x36 0x32 0x2d 0x29 0x34 0x32 0x35 0x31 ,
  59.       0x47 0x43 0x3f 0x3c 0x34 0x31 0x34 0x34 ,0x40 0x3c 0x3a 0x34 0x3f 0x40 0x3f 0x40 ,
  60. range:0x2b 0x2a 0x29 0x29 0x2a 0x2a 0x28 0x2a ,0x2a 0x26 0x2b 0x27 0x29 0x28 0x26 0x2a ,
  61.       0x34 0x30 0x33 0x33 0x30 0x2f 0x31 0x32 ,0x2f 0x34 0x2c 0x32 0x2e 0x32 0x2c 0x32 ,
  62. the write training result:
  63. DQS0:0x64, DQS1:0x51, DQS2:0x5b, DQS3:0x43,
  64. min  :0x94 0x98 0x99 0x94 0x84 0x8b 0x8f 0x90 0x8e ,0x7e 0x7d 0x75 0x74 0x7e 0x82 0x82 0x7f 0x79 ,
  65.       0x90 0x90 0x8a 0x8a 0x7e 0x7f 0x7f 0x88 0x86 ,0x7a 0x76 0x75 0x6f 0x79 0x7c 0x79 0x7d 0x73 ,
  66. mid  :0xaf 0xb3 0xb4 0xaf 0x9f 0xa4 0xaa 0xa9 0xa8 ,0x9a 0x97 0x90 0x8e 0x98 0x98 0x9c 0x99 0x93 ,
  67.       0xab 0xaa 0xa3 0xa4 0x98 0x96 0x99 0x9f 0x9e ,0x94 0x90 0x8e 0x88 0x93 0x97 0x92 0x97 0x8d ,
  68. max  :0xcb 0xce 0xd0 0xca 0xba 0xbe 0xc6 0xc3 0xc2 ,0xb6 0xb2 0xab 0xa9 0xb3 0xaf 0xb6 0xb4 0xae ,
  69.       0xc7 0xc4 0xbc 0xbe 0xb2 0xad 0xb4 0xb7 0xb7 ,0xaf 0xaa 0xa7 0xa1 0xad 0xb2 0xab 0xb2 0xa7 ,
  70. range:0x37 0x36 0x37 0x36 0x36 0x33 0x37 0x33 0x34 ,0x38 0x35 0x36 0x35 0x35 0x2d 0x34 0x35 0x35 ,
  71.       0x37 0x34 0x32 0x34 0x34 0x2e 0x35 0x2f 0x31 ,0x35 0x34 0x32 0x32 0x34 0x36 0x32 0x35 0x34 ,
  72. CA Training result:
  73. cs:0 min  :0x48 0x37 0x40 0x2c 0x42 0x27 0x43 ,0x4c 0x37 0x3e 0x32 0x40 0x2b 0x47 ,
  74. cs:0 mid  :0x7e 0x7a 0x73 0x6d 0x71 0x6a 0x67 ,0x80 0x7a 0x72 0x72 0x71 0x6e 0x6a ,
  75. cs:0 max  :0xb4 0xbd 0xa7 0xaf 0xa1 0xae 0x8c ,0xb4 0xbd 0xa6 0xb2 0xa3 0xb1 0x8e ,
  76. cs:0 range:0x6c 0x86 0x67 0x83 0x5f 0x87 0x49 ,0x68 0x86 0x68 0x80 0x63 0x86 0x47 ,
  77. cs:1 min  :0x4a 0x37 0x40 0x2a 0x3f 0x2b 0x37 ,0x4f 0x3b 0x43 0x35 0x40 0x2f 0x3f ,
  78. cs:1 mid  :0x7e 0x79 0x73 0x6d 0x73 0x6c 0x69 ,0x82 0x7d 0x74 0x73 0x75 0x70 0x6d ,
  79. cs:1 max  :0xb2 0xbc 0xa6 0xb0 0xa7 0xae 0x9c ,0xb5 0xc0 0xa5 0xb2 0xab 0xb2 0x9c ,
  80. cs:1 range:0x68 0x85 0x66 0x86 0x68 0x83 0x65 ,0x66 0x85 0x62 0x7d 0x6b 0x83 0x5d ,
  81. out
  82. Boot1 Release Time: Dec  9 2021 15:28:55, version: 1.14
  83. support nand flash type: slc
  84. ...nandc_flash_init enter...
  85. No.1 FLASH ID:0 0 0 0 0 0
  86. sfc nor id: ff ff ff
  87. sfc_nand id: ff ff ff
  88. SD IO init 0
  89. Set SD Clk: 200, 5
  90. Set SD Clk: 200, 5
  91. SDC_BusRequest:  CMD=8  SDC_RESP_TIMEOUT 1747
  92. mmc0:cmd8,20
  93. SDC_BusRequest:  CMD=5  SDC_RESP_TIMEOUT 1747
  94. mmc0:cmd5,20
  95. SDC_BusRequest:  CMD=55  SDC_RESP_TIMEOUT 1747
  96. mmc0:cmd55,20
  97. SDC_BusRequest:  CMD=1  SDC_RESP_TIMEOUT 1747
  98. mmc0:cmd1,20
  99. Set SD Clk: 200, 5
  100. SDC_BusRequest:  CMD=8  SDC_RESP_TIMEOUT 1747
  101. mmc0:cmd8,20
  102. SDC_BusRequest:  CMD=5  SDC_RESP_TIMEOUT 1747
  103. mmc0:cmd5,20
  104. SDC_BusRequest:  CMD=55  SDC_RESP_TIMEOUT 1747
  105. mmc0:cmd55,20
  106. SDC_BusRequest:  CMD=1  SDC_RESP_TIMEOUT 1747
  107. mmc0:cmd1,20
  108. Set SD Clk: 200, 5
  109. SDC_BusRequest:  CMD=8  SDC_RESP_TIMEOUT 1747
  110. mmc0:cmd8,20
  111. SDC_BusRequest:  CMD=5  SDC_RESP_TIMEOUT 1747
  112. mmc0:cmd5,20
  113. SDC_BusRequest:  CMD=55  SDC_RESP_TIMEOUT 1747
  114. mmc0:cmd55,20
  115. SDC_BusRequest:  CMD=1  SDC_RESP_TIMEOUT 1747
  116. mmc0:cmd1,20
  117. SdmmcInit=0 1
  118. Emmc IO init.
  119. EMMC_DLL_RXCLK = 0
  120. Emmc IO init.
  121. EMMC_DLL_RXCLK = 0
  122. mmc: ERROR: Reset 0x1 never completed.
  123. mmc_set_bus_width: 1
  124. SetEmmcClk: 375000, 5
  125. mmc: ERROR: SDHCI:Timeout for status update! cmd0:0x0, stat:0x0, mask:0x1
  126. emmc reinit
  127. mmc_set_bus_width: 1
  128. mmc: ERROR: Controller never released inhibit bit(s), present state 0x02070001.
  129. emmc reinit
  130. mmc_set_bus_width: 1
  131. mmc: ERROR: Controller never released inhibit bit(s), present state 0x02070001.
  132. SdmmcInit=2 1
  133. UsbBoot ...5528765
  134. powerOn 5529041
youyeetoo的镜像烧录不进开发板了,求指导!
 楼主| 发表于 2023-6-5 09:58:38 | 显示全部楼层
板子是yy3568
 楼主| 发表于 2023-6-4 18:32:42 | 显示全部楼层
C:\Users\WMW\Desktop\屏幕截图 2023-06-04 183113.png
发表于 2023-6-5 09:05:38 | 显示全部楼层
 楼主| 发表于 2023-6-5 09:53:40 | 显示全部楼层
maskrom模式下,“升级固件”界面,固件选择YY3568-Debian10-sata-dsi0-2023-5-11.img,然后点升级
发表于 2023-6-5 17:45:02 | 显示全部楼层
风火轮用户fE477 发表于 2023-6-5 09:53
maskrom模式下,“升级固件”界面,固件选择YY3568-Debian10-sata-dsi0-2023-5-11.img,然后点升级 ...
load模式进不来吗
 楼主| 发表于 2023-6-5 18:33:44 | 显示全部楼层
进不来loader,
GMT+8, 2026-9-25 04:09 , Processed in 0.127899 second(s), 30 queries .
