查看: 7940|回复: 0
RK3588S-PC编译问题
发表于 2023-4-7 22:58:08 | 显示全部楼层 |阅读模式
编译报错如下:
[backcolor=rgba(17, 17, 17, 0.96)]FAILED: out/soong/.intermediates/system/tools/xsdc/tests/resources/simple_complex_content/xsdc_simple_complex_content_tests.docs/android_common/metalava/check_current_api.timestamp
[backcolor=rgba(17, 17, 17, 0.96)]( true && diff -u -F '{ *$' system/tools/xsdc/tests/resources/simple_complex_content/api/current.txt out/soong/.intermediates/system/tools/xsdc/tests/resources/simple_complex_content/xsdc_simple_complex_content_tests.docs/android_common/metalava/api/current.txt && diff -u -F '{ *$' system/tools/xsdc/tests/resources/simple_complex_content/api/removed.txt out/soong/.intermediates/system/tools/xsdc/tests/resources/simple_complex_content/xsdc_simple_complex_content_tests.docs/android_common/metalava/api/removed.txt && touch out/soong/.intermediates/system/tools/xsdc/tests/resources/simple_complex_content/xsdc_simple_complex_content_tests.docs/android_common/metalava/check_current_api.timestamp ) || ( echo -e "\n******************************\nYou have tried to change the API from what has been previously approved.\n\nTo make these errors go away, you have two choices:\n   1. You can add '@hide' javadoc comments (and remove @SystemApi/@TestApi/etc)\n      to the new methods, etc. shown in the above diff.\n\n   2. You can update current.txt and/or removed.txt by executing the following command:\n         m xsdc_simple_complex_content_tests.docs-update-current-api\n\n      To submit the revised current.txt to the main Android repository,\n      you will need approval.\n******************************\n" ; exit 38 ) # hash of input list: 8947d0b6052d4eb78490672f8f898de5b6ba76e5af1795a92a73bc32e60ba235
[backcolor=rgba(17, 17, 17, 0.96)]--- system/tools/xsdc/tests/resources/simple_complex_content/api/current.txt        2023-04-04 19:04:24.533808784 +0800
[backcolor=rgba(17, 17, 17, 0.96)]+++ out/soong/.intermediates/system/tools/xsdc/tests/resources/simple_complex_content/xsdc_simple_complex_content_tests.docs/android_common/metalava/api/current.txt        2023-04-07 21:55:42.437954007 +0800
[backcolor=rgba(17, 17, 17, 0.96)]@@ -1,89 +0,0 @@
[backcolor=rgba(17, 17, 17, 0.96)]-// Signature format: 2.0
[backcolor=rgba(17, 17, 17, 0.96)]-package simple.complex.content {
[backcolor=rgba(17, 17, 17, 0.96)]-  @Deprecated public class Address {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor @Deprecated public Address();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public String getCity();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public final String getName();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public String getStreet();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public boolean hasCity();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public boolean hasName();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public boolean hasStreet();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public void setCity(String);
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public final void setName(String);
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Deprecated public void setStreet(String);
[backcolor=rgba(17, 17, 17, 0.96)]-  }
[backcolor=rgba(17, 17, 17, 0.96)]-  public class KRAddress extends simple.complex.content.Address {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public KRAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-  public class Person {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public Person();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public simple.complex.content.KRAddress getKRAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public String getName();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public simple.complex.content.SubAddress getSubAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public simple.complex.content.USAddressP getUSAddressP();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasKRAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasName();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasSubAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasUSAddressP();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setKRAddress(simple.complex.content.KRAddress);
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setName(String);
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setSubAddress(simple.complex.content.SubAddress);
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setUSAddressP(simple.complex.content.USAddressP);
[backcolor=rgba(17, 17, 17, 0.96)]-  public class Person2 {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public Person2();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @NonNull public simple.complex.content.SubAddress getSubAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setSubAddress(@NonNull simple.complex.content.SubAddress);
[backcolor=rgba(17, 17, 17, 0.96)]-  public class SubAddress {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public SubAddress();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @Nullable public final String getChoice1_optional();
[backcolor=rgba(17, 17, 17, 0.96)]-    method @NonNull public final String getChoice2_optional();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasChoice1_optional();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasChoice2_optional();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public final void setChoice1_optional(@Nullable String);
[backcolor=rgba(17, 17, 17, 0.96)]-    method public final void setChoice2_optional(@NonNull String);
[backcolor=rgba(17, 17, 17, 0.96)]-  public final class USAddressP extends simple.complex.content.Address {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public USAddressP();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public String getState();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public java.math.BigInteger getZipcode();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasState();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public boolean hasZipcode();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setState(String);
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void setZipcode(java.math.BigInteger);
[backcolor=rgba(17, 17, 17, 0.96)]-  public class XmlParser {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public XmlParser();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public static simple.complex.content.Person readPerson(java.io.InputStream) throws javax.xml.datatype.DatatypeConfigurationException, java.io.IOException, org.xmlpull.v1.XmlPullParserException;
[backcolor=rgba(17, 17, 17, 0.96)]-    method public static simple.complex.content.Person2 readPerson2(java.io.InputStream) throws javax.xml.datatype.DatatypeConfigurationException, java.io.IOException, org.xmlpull.v1.XmlPullParserException;
[backcolor=rgba(17, 17, 17, 0.96)]-    method public static String readText(org.xmlpull.v1.XmlPullParser) throws java.io.IOException, org.xmlpull.v1.XmlPullParserException;
[backcolor=rgba(17, 17, 17, 0.96)]-    method public static void skip(org.xmlpull.v1.XmlPullParser) throws java.io.IOException, org.xmlpull.v1.XmlPullParserException;
[backcolor=rgba(17, 17, 17, 0.96)]-  public class XmlWriter implements java.io.Closeable {
[backcolor=rgba(17, 17, 17, 0.96)]-    ctor public XmlWriter(java.io.PrintWriter);
[backcolor=rgba(17, 17, 17, 0.96)]-    method public void close();
[backcolor=rgba(17, 17, 17, 0.96)]-    method public static void write(simple.complex.content.XmlWriter, simple.complex.content.Person) throws java.io.IOException;
[backcolor=rgba(17, 17, 17, 0.96)]-    method public static void write(simple.complex.content.XmlWriter, simple.complex.content.Person2) throws java.io.IOException;
[backcolor=rgba(17, 17, 17, 0.96)]-}
[backcolor=rgba(17, 17, 17, 0.96)]-e
[backcolor=rgba(17, 17, 17, 0.96)]******************************
[backcolor=rgba(17, 17, 17, 0.96)]You have tried to change the API from what has been previously approved.
[backcolor=rgba(17, 17, 17, 0.96)]To make these errors go away, you have two choices:
[backcolor=rgba(17, 17, 17, 0.96)]   1. You can add '@hide' javadoc comments (and remove @SystemApi/@TestApi/etc)
[backcolor=rgba(17, 17, 17, 0.96)]      to the new methods, etc. shown in the above diff.
[backcolor=rgba(17, 17, 17, 0.96)]   2. You can update current.txt and/or removed.txt by executing the following command:
[backcolor=rgba(17, 17, 17, 0.96)]         m xsdc_simple_complex_content_tests.docs-update-current-api
[backcolor=rgba(17, 17, 17, 0.96)]      To submit the revised current.txt to the main Android repository,
[backcolor=rgba(17, 17, 17, 0.96)]      you will need approval.
GMT+8, 2026-10-23 17:46 , Processed in 0.073545 second(s), 20 queries .
