查看: 10364|回复: 4
RK3588S-PC android12编译问题
发表于 2023-4-7 15:39:55 | 显示全部楼层 |阅读模式
编译流程:
获取Android12.0SDK firefly_rk3588_android12.0_git_20220311
解压:
7z x ./firefly_rk3588_android12.0_git_20220311.7z.001 -oRK3588_Android12.0cd ./RK3588_Android12.0git reset --hard更新SDK:cd ~/proj/RK3588_Android12.0git clone https://gitlab.com/T-Firefly/rk3588-android12.0-bundle.git .bundle.bundle/updategit rebase FETCH_HEAD3.2.1.2. 显示屏 DM-M10R800 V2 固件编译
./FFTools/make.sh -d roc-rk3588s-pc-mipi101-M101014-BE45-A1 -j8 -l roc_rk3588s_pc_mipi-userdebug执行到这一步时编译报错,kernel编译成功,编译android时报错,[100% 1/1] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
FAILED: out/soong/build.ninja
cd "$(dirname "out/soong/.bootstrap/bin/soong_build")" && BUILDER="$PWD/$(basename "out/soong/.bootstrap/bin/soong_build")" && cd / && env -i "$BUILDER"     --top "$TOP"     --out "out/soong"     -n "out"     -d "out/soong/build.ninja.d"     -t -l out/.module_paths/Android.bp.list -globFile out/soong/.bootstrap/build-globs.ninja -o out/soong/build.ninja --available_env out/soong/soong.environment.available --used_env out/soong/soong.environment.used Android.bp
audioflinger want to conditional Compile
devicefactory want to conditional Compile
libRkTeeWeaver want to conditional Compile
libaudioclient want to conditional Compile
libaudiohal want to conditional Compile
libeptz want to conditional Compile
libgralloc_priv want to conditional Compile
libmpimmz conditional Compile
librga want to conditional Compile
librknnrt want to conditional Compile
librockx want to conditional Compile
managerdefault want to conditional Compile
Rockchip conditional compile
librknnrt enabled on RK3588
libeptz enabled on RK3588
[hardware/rockchip/libgralloc frameworks/native/include system/core/libsync system/core/libsync/include external/libdrm/include/drm] 32
>>>>>>>>>>>>>>>>>>>>> rk3588
Optee Version: v2
librockx enabled on RK3588
Killed
15:29:13 soong bootstrap failed with: exit status 1
ninja: build stopped: subcommand failed.
root@ahser-host:~/rk3588s-pc/android12/RK3588_Android12.0#
发表于 2023-4-7 16:03:38 | 显示全部楼层
你编译的主机物理内存+交换内存大于16g吗
 楼主| 发表于 2023-4-7 16:36:14 | 显示全部楼层
我分配的物理内存13g
 楼主| 发表于 2023-4-7 16:37:50 | 显示全部楼层
              total        used        free      shared  buff/cache   available
Mem:          13671         201       13314           0         156       13238
Swap:          2047         227        1820
发表于 2023-4-12 10:37:13 | 显示全部楼层
楼主解决了吗,我也碰到了
GMT+8, 2026-11-1 07:41 , Processed in 0.075447 second(s), 25 queries .
