查看: 7752|回复: 0
bpi-r3 SD错误(已解决)
发表于 2023-3-3 12:47:24 | 显示全部楼层 |阅读模式
  *** U-Boot Boot Menu ***
     1. Startup system (Default)
     2. Upgrade firmware
     3. Upgrade ATF BL2
     4. Upgrade ATF FIP
     5. Upgrade SD partition table
     6. Upgrade single image
     7. Load image
     0. U-Boot console
  Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit
Reading from 0x880000 to 0x46000000, size 0x200 ... OK
Reading from 0x880000 to 0x46000000, size 0x38dff8 ... Fail
*** Only 0x0 read! ***
MT7986>
使用op官网得sd固件启动时候还得tftp加载  openwrt-mediatek-filogic-bananapi_bpi-r3-initramfs-recovery.itb才能启动但是不能识别U盘
断电一宿好使了
GMT+8, 2026-10-30 18:33 , Processed in 0.069700 second(s), 20 queries .
