查看: 12229|回复: 1
请教rockpi -4b 用自带脚本编android10源码报错?
发表于 2021-9-8 18:11:32 | 显示全部楼层 |阅读模式
out/soong/.bootstrap/bin/soong_build -t -l out/.module_paths/Android.bp.list -b out/soong -n out -d out/soong/build.ninja.d -globFile out/soong/.bootstrap/build-globs.ninja -o out/soong/build.ninja Android.bp
libRKmediaplayerservice want to conditional Compile
libRkTeeWeaver want to conditional Compile
libcrypto_defaults want to conditional Compile
libffmpeg_58 want to conditional Compile
libgralloc_priv want to conditional Compile
libjpeghwenc want to conditional Compile
libmpp want to conditional Compile
librga want to conditional Compile
librk_vpuapi want to conditional Compile
librockit want to conditional Compile
librtopus want to conditional Compile
libvpu want to conditional Compile
error: prebuilts/clang/host/darwin-x86/Android.bp:23:1: unrecognized module type "llvm_darwin_filegroup"
error: prebuilts/clang/host/darwin-x86/Android.bp:27:1: unrecognized module type "llvm_darwin_filegroup"
error: prebuilts/clang/host/darwin-x86/Android.bp:31:1: unrecognized module type "llvm_darwin_filegroup"
error: prebuilts/clang/host/darwin-x86/Android.bp:35:1: unrecognized module type "llvm_darwin_filegroup"
error: prebuilts/clang/host/linux-x86/Android.bp:17:1: unrecognized module type "llvm_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:25:1: unrecognized module type "llvm_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:34:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:51:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:68:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:85:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:103:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:117:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:131:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:145:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:165:1: unrecognized module type "libclang_rt_llndk_library"
error: prebuilts/clang/host/linux-x86/Android.bp:175:1: unrecognized module type "libclang_rt_llndk_library"
error: prebuilts/clang/host/linux-x86/Android.bp:185:1: unrecognized module type "libclang_rt_llndk_library"
error: prebuilts/clang/host/linux-x86/Android.bp:195:1: unrecognized module type "libclang_rt_llndk_library"
error: prebuilts/clang/host/linux-x86/Android.bp:205:1: unrecognized module type "libclang_rt_llndk_library"
error: prebuilts/clang/host/linux-x86/Android.bp:215:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:233:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:251:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:269:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:287:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:302:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:317:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:332:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:347:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:360:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:374:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:387:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:400:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:413:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:426:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:438:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:451:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:467:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:483:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:499:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:515:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:529:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:543:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:557:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:571:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:587:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:603:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:619:1: unrecognized module type "libclang_rt_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:635:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:649:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:663:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:677:1: unrecognized module type "libclang_rt_prebuilt_library_static"
error: prebuilts/clang/host/linux-x86/Android.bp:697:1: unrecognized module type "llvm_host_defaults"
error: prebuilts/clang/host/linux-x86/Android.bp:702:1: unrecognized module type "llvm_host_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:712:1: unrecognized module type "llvm_host_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:722:1: unrecognized module type "llvm_host_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:736:1: unrecognized module type "llvm_host_prebuilt_library_shared"
error: prebuilts/clang/host/linux-x86/Android.bp:744:1: unrecognized module type "clang_builtin_headers"
FAILED: [W][2021-09-08T22:12:26+0800][25408] void cmdline::logParams(nsjconf_t *)():250 Process will be UID/EUID=0 in the global user namespace, and will have user root-level access to files
[W][2021-09-08T22:12:26+0800][25408] void cmdline::logParams(nsjconf_t *)():260 Process will be GID/EGID=0 in the global user namespace, and will have group root-level access to files
22:12:27 soong bootstrap failed with: exit status 1
用的是源码里自带的脚本:build-rockpi-4b.sh 编的,从wiki下的android10源码,解压未做修改,请问有那位大神知道是什么原因吗?
 楼主| 发表于 2021-10-29 10:02:00 | 显示全部楼层
解决了,应该百度云下载的 源码 有问题,重新 repo 拉了源码,编译没有问题了。
GMT+8, 2026-11-19 23:05 , Processed in 0.073127 second(s), 21 queries .
