查看: 13957|回复: 2
开发板AIO3399j烧写官方android7.1镜像,报错
发表于 2021-4-15 10:30:29 | 显示全部楼层 |阅读模式
1 下载官方的镜像
AIO-3399J_Industry7.1.2_HDMI_201110.7z
2 按照官方教程烧写镜像
烧写统一固件 update.img:
sudo upgrade_tool uf update.img
如果升级失败,可以尝试先擦除后再升级。一定要根据《使用USB线烧写须知(重要)》的表格进行擦除烧写
# 擦除 flash 使用 ef 参数需要指定 loader 文件或者对应的 update.imgsudo upgrade_tool ef update.img   #update.img :你需要烧写的 Ubuntu 固件# 重新烧写sudo upgrade_tool uf update.img
3 报错如下:
DDR Version 1.24 20191016
In
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x32817281, stride = 0x9
OUT
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 336
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68472
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret0)
GPT 0x3335db8 signature is wrong
recovery gpt...
recovery gpt fail!
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x87104
RunBL31 0x40000 @ 93941 us
NOTICE:  BL31: v1.3(release):af49f67
NOTICE:  BL31: Built : 16:55:08, May 19 2020
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1191): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-256-gebb61ff5 #4 Wed Apr 22 01:34:02 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Nov 09 2020 - 17:33:59)
CPU: rk3399
cpu version = 0
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
               aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
               aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
               hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:    Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000000200000(000000007fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01e00000
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
no rockusb key node
power key: bank-0 pin-5
can't find dts node for fixed
usb bc: can find node by path: /dwc-control-usb/usb_bc
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=975000,pwm_value=58
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Can't find dts node for fuel guage cw201x
can't find dts node for ec-battery
Can't find dts node for charger bq25700
invalide header tag
ca head not found
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2020-11-09#1.26
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find panel driver
read logo on state from dts [1]
no fuel gauge found
rockchip_panel_deinit: failed to find panel deinit funcs
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
failed to display kernel logo
Hit any key to stop autoboot:  0
load fdt from resouce.
hwversion: disabled!
Secure Boot state: 0
kernel   @ 0x00280000 (0x01376808)
ramdisk  @ 0x04bf0000 (0x001e7860)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 0000000004616f30 ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:000000000a200000, 0000000075e00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.126 (ruanjg@tchipserver2) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #3 SMP PREEMPT Mon Nov 9 17:35:10 CST 2020
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef7000 s45592 r8192 d32232 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 507912
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00100000@0x003C4000(oem),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(reserved),0x00000400@0x004CE040(frp),-@0x004CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2020-11-09_17:33:59 SecureBootCheckOk=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] software IO TLB [mem 0x7eeae000-0x7eeee000] (0MB) mapped at [ffffffc07eeae000-ffffffc07eeedfff]
[    0.000000] Memory: 1985884K/2064384K available (11518K kernel code, 1754K rwdata, 5752K rodata, 832K init, 2390K bss, 62116K reserved, 16384K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8009170000 - 0xffffff8009240000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008bc0000   ( 11520 KB)
[    0.000000]     .rodata : 0xffffff8008bc0000 - 0xffffff8009170000   (  5824 KB)
[    0.000000]       .data : 0xffffff8009240000 - 0xffffff80093f6808   (  1755 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc2000000   (    31 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc080000000   (  2046 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 64.
[    0.000000]     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001831] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002783] pid_max: default: 32768 minimum: 301
[    0.003265] Security Framework initialized
[    0.003646] SELinux:  Initializing.
[    0.004069] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.004691] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.006070] Initializing cgroup subsys memory
[    0.006496] Initializing cgroup subsys freezer
[    0.007744] sched-energy: Sched-energy-costs installed from DT
[    0.008284] CPU0: update cpu_capacity 401
[    0.008730] ASID allocator initialised with 32768 entries
[    0.025591] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.026773] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.038973] Detected VIPT I-cache on CPU1
[    0.039001] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039034] CPU1: using LPI pending table @0x000000000a3f0000
[    0.039071] CPU1: update cpu_capacity 401
[    0.039075] CPU1: Booted secondary processor [410fd034]
[    0.048965] Detected VIPT I-cache on CPU2
[    0.048984] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.049015] CPU2: using LPI pending table @0x000000007c020000
[    0.049040] CPU2: update cpu_capacity 401
[    0.049043] CPU2: Booted secondary processor [410fd034]
[    0.058998] Detected VIPT I-cache on CPU3
[    0.059016] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.059047] CPU3: using LPI pending table @0x000000007c060000
[    0.059070] CPU3: update cpu_capacity 401
[    0.059074] CPU3: Booted secondary processor [410fd034]
[    0.069043] Detected PIPT I-cache on CPU4
[    0.069068] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.069101] CPU4: using LPI pending table @0x000000007c0b0000
[    0.069135] CPU4: update cpu_capacity 1024
[    0.069138] CPU4: Booted secondary processor [410fd082]
[    0.079070] Detected PIPT I-cache on CPU5
[    0.079087] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.079117] CPU5: using LPI pending table @0x000000007c0e0000
[    0.079142] CPU5: update cpu_capacity 1024
[    0.079144] CPU5: Booted secondary processor [410fd082]
[    0.079223] Brought up 6 CPUs
[    0.091133] SMP: Total of 6 processors activated.
[    0.091571] CPU features: detected feature: GIC system register CPU interface
[    0.092233] CPU: All CPU(s) started at EL2
[    0.092647] alternatives: patching kernel code
[    0.094936] devtmpfs: initialized
[    0.115698] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.116617] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.118025] pinctrl core: initialized pinctrl subsystem
[    0.120035] Failed to find legacy iommu devices
[    0.120828] NET: Registered protocol family 16
[    0.121664] schedtune: init normalization constants...
[    0.122160] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.122786] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.123422] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.124046] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.124670] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.125295] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.125918] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.126542] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.127171] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.127794] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.128523] schedtune: verify normalization constants...
[    0.129031] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.129564] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.130096] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.130635] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.131167] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.131699] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.132232] schedtune: configured to support 5 boost groups
[    0.140670] cpuidle: using governor ladder
[    0.150673] cpuidle: using governor menu
[    0.151061] Registered FIQ tty driver
[    0.151796] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff8009244000)
[    0.152525] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.154079] DMA: preallocated 1024 KiB pool for atomic allocations
[    0.174289] console [pstore-1] enabled
[    0.174866] pstore: Registered ramoops as persistent store backend
[    0.175460] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.178449] fiq debugger fiq mode enabled
[[    0.179093] console [ttyFIQ0] enabled
[    0.179786] bootconsole [uart0] disabled
[    0.180357] Registered fiq debugger ttyFIQ0
[    0.213430] reg_fixed_voltage_probe vcc5v0_host sys/camera_test/vcc5v0_dbg
[    0.215530] iommu: Adding device ff650000.vpu_service to group 0
[    0.215603] iommu: Adding device ff660000.rkvdec to group 1
[    0.215667] iommu: Adding device ff670000.iep to group 2
[    0.215752] iommu: Adding device ff8f0000.vop to group 3
[    0.215821] iommu: Adding device ff900000.vop to group 4
[    0.215920] iommu: Adding device ff910000.isp to group 5
[    0.216011] iommu: Adding device ff920000.isp to group 6
[    0.216647] rk_iommu ff670800.iommu: can't get aclk
[    0.216661] rk_iommu ff670800.iommu: can't get hclk
[    0.217497] SCSI subsystem initialized
[    0.222883] usbcore: registered new interface driver usbfs
[    0.222932] usbcore: registered new interface driver hub
[    0.223012] usbcore: registered new device driver usb
[    0.223379] media: Linux media interface: v0.10
[    0.223417] Linux video capture interface: v2.00
[    0.223579] pps_core: LinuxPPS API ver. 1 registered
[    0.223588] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.223608] PTP clock support registered
[    0.225148] Advanced Linux Sound Architecture Driver Initialized.
[    0.225624] Bluetooth: Core ver 2.21
[    0.225652] NET: Registered protocol family 31
[    0.225661] Bluetooth: HCI device and connection manager initialized
[    0.225673] Bluetooth: HCI socket layer initialized
[    0.225684] Bluetooth: L2CAP socket layer initialized
[    0.225708] Bluetooth: SCO socket layer initialized
[    0.226394] rockchip-cpuinfo cpuinfo: Serial        : 8ed4ada1cbe0f445
[    0.226916] clocksource: Switched to clocksource arch_sys_counter
[    0.270702] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.270927] NET: Registered protocol family 2
[    0.271362] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.271509] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.271784] TCP: Hash tables configured (established 16384 bind 16384)
[    0.271857] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.271916] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.272093] NET: Registered protocol family 1
[    0.272915] Trying to unpack rootfs image as initramfs...
[    0.370940] Freeing initrd memory: 1948K
[    0.371514] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.371604] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.374297] audit: initializing netlink subsys (disabled)
[    0.374359] audit: type=2000 audit(0.370:1): initialized
[    0.379339] VFS: Disk quotas dquot_6.6.0
[    0.379467] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.380466] Registering sdcardfs 0.1
[    0.381007] fuse init (API version 7.23)
[    0.382047]
[    0.382047] TEE Core Framework initialization (ver 1:0.1)
[    0.382079] TEE armv7 Driver initialization
[    0.382421] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    0.382440] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    0.382607] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    0.386479] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.386507] io scheduler noop registered
[    0.386667] io scheduler cfq registered (default)
[    0.389055] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[    0.392236] ace test_init function.
[    0.392388] ace test_init end.ret=0
[    0.392720] radar end.ret=0
[    0.394977] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.395009] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    0.440280] rockchip-pcie f8000000.pcie: invalid power supply
[    0.940345] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    0.940574] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    0.941409] iep: failed to find iep power down clock source.
[    0.941884] IEP Power ON
[    0.942128] IEP Power OFF
[    0.942280] IEP Driver loaded succesfully
[    0.942545] Module initialized.
[    0.942823] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    0.943063] rk-vcodec ff650000.vpu_service: probe device
[    0.943278] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    0.943888] rk-vcodec ff650000.vpu_service: could not find power_model node
[    0.943906] rk-vcodec ff650000.vpu_service: init success
[    0.944093] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    0.944596] rk-vcodec ff660000.rkvdec: probe device
[    0.944761] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    0.945119] rk-vcodec ff660000.rkvdec: could not find power_model node
[    0.945135] rk-vcodec ff660000.rkvdec: init success
[    0.946695] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.946718] dma-pl330 ff6d0000.dma-controller:     DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.948071] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.948094] dma-pl330 ff6e0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.949816] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.950360] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[    0.950789] [drm] Initialized drm 1.1.0 20060810
[    0.954025] [drm] Rockchip DRM driver version: v1.0.0
[    0.954335] rockchip-drm display-subsystem: defer getting devfreq
[    0.954612] rockchip-vop ff900000.vop: missing rockchip,grf property
[    0.954861] rockchip-vop ff900000.vop: unable to request PWM
[    0.954891] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    0.954933] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    0.955099] rockchip-vop ff8f0000.vop: unable to request PWM
[    0.955121] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    0.955355] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    0.955376] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    0.955480] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    0.959510] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[    0.959533] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.959541] [drm] No driver support for vblank timestamp query.
[    0.959836] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[    0.959859] rockchip-drm display-subsystem: can't not find any loader display
[    0.959873] rockchip-drm display-subsystem: failed to show loader logo
[    0.959964] Freeing drm_logo memory: 488K
[    0.959985] rockchip-drm display-subsystem: No connectors reported connected with modes
[    0.959996] [drm] Cannot find any crtc or sizes - going 1024x768
[    0.964302] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.981755] mali ff9a0000.gpu: Failed to get regulator
[    0.981781] mali ff9a0000.gpu: Power control initialization failed
[    0.982051] Unable to detect cache hierarchy for CPU 0
[    0.999525] brd: module loaded
[    1.017316] loop: module loaded
[    1.021188] zram: Added device: zram0
[    1.021795] Loading dl1825 driver
[    1.022228] SCSI Media Changer driver v0.25
[    1.023020] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    1.023034] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    1.023045] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    1.023836] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.194170] wk2xxx_serial_init()
[    1.194187] wk2xxx_request_port
[    1.194199] ttysWK0 at I/O 0x1 (irq = 101, base_baud = 460800) is a wk2xxx
[    1.194401] uart_add_one_port success for line i:= 0 with right 0
[    1.194416] wk2xxx_request_port
[    1.194427] ttysWK1 at I/O 0x2 (irq = 101, base_baud = 460800) is a wk2xxx
[    1.194609] uart_add_one_port success for line i:= 1 with right 0
[    1.194624] wk2xxx_request_port
[    1.194634] ttysWK2 at I/O 0x3 (irq = 101, base_baud = 460800) is a wk2xxx
[    1.194814] uart_add_one_port success for line i:= 2 with right 0
[    1.194828] wk2xxx_request_port
[    1.194838] ttysWK3 at I/O 0x4 (irq = 101, base_baud = 460800) is a wk2xxx
[    1.195021] uart_add_one_port success for line i:= 3 with right 0
[    1.195035] uart_add_one_port = 0x0
[    1.195060] register spi return v = :0
[    1.195097] register firefly_spi_init spi return v = :0
[    1.195149] tun: Universal TUN/TAP device driver, 1.6
[    1.195163] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.196016] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[    1.196108] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.196130] rk_gmac-dwmac fe300000.ethernet: TX delay(0x31).
[    1.196141] rk_gmac-dwmac fe300000.ethernet: RX delay(0x24).
[    1.196164] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.196329] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    1.196343] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.201358] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.201478] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.201486]  Ring mode enabled
[    1.201494]  DMA HW capability register supported
[    1.201500]  Normal descriptors
[    1.201509]  RX Checksum Offload Engine supported (type 2)
[    1.201516]  Wake-Up On Lan supported
[    1.201553]  Enable RX Mitigation via HW Watchdog Timer
[    1.277115] libphy: stmmac: probed
[    1.277181] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.277194] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.277205] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[    1.277217] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[    1.277230] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[    1.277241] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[    1.277252] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[    1.277262] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[    1.277273] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[    1.277283] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[    1.277294] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[    1.277305] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[    1.277315] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[    1.277326] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[    1.277337] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[    1.277348] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[    1.277358] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[    1.277369] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[    1.277379] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[    1.277390] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[    1.277400] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[    1.277411] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[    1.277421] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[    1.277432] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[    1.277442] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[    1.277494] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[    1.277505] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[    1.277515] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[    1.277526] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[    1.277536] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[    1.277546] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[    1.277557] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[    1.278945] PPP generic driver version 2.4.2
[    1.279245] PPP BSD Compression module registered
[    1.279303] PPP Deflate Compression module registered
[    1.279336] PPP MPPE Compression module registered
[    1.279356] NET: Registered protocol family 24
[    1.279402] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.279454] CSLIP: code copyright 1989 Regents of the University of California.
[    1.279542] usbcore: registered new interface driver mt7601u
[    1.279560] Rockchip WiFi SYS interface (V1.00) ...
[    1.279644] usbcore: registered new interface driver catc
[    1.279742] usbcore: registered new interface driver kaweth
[    1.279759] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.279811] usbcore: registered new interface driver pegasus
[    1.279865] usbcore: registered new interface driver rtl8150
[    1.279972] usbcore: registered new interface driver r8152
[    1.279987] hso: drivers/net/usb/hso.c: Option Wireless
[    1.280071] usbcore: registered new interface driver hso
[    1.280180] usbcore: registered new interface driver asix
[    1.280236] usbcore: registered new interface driver ax88179_178a
[    1.280315] usbcore: registered new interface driver cdc_ether
[    1.280369] usbcore: registered new interface driver cdc_eem
[    1.280452] usbcore: registered new interface driver dm9601
[    1.280521] usbcore: registered new interface driver smsc75xx
[    1.280586] usbcore: registered new interface driver smsc95xx
[    1.280667] usbcore: registered new interface driver gl620a
[    1.280722] usbcore: registered new interface driver net1080
[    1.280775] usbcore: registered new interface driver plusb
[    1.280859] usbcore: registered new interface driver rndis_host
[    1.280916] usbcore: registered new interface driver cdc_subset
[    1.280970] usbcore: registered new interface driver zaurus
[    1.281026] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.281129] usbcore: registered new interface driver int51x1
[    1.281185] usbcore: registered new interface driver kalmia
[    1.281243] usbcore: registered new interface driver ipheth
[    1.281326] usbcore: registered new interface driver sierra_net
[    1.281383] usbcore: registered new interface driver cx82310_eth
[    1.281448] usbcore: registered new interface driver cdc_ncm
[    1.281533] usbcore: registered new interface driver qmi_wwan
[    1.281593] usbcore: registered new interface driver cdc_mbim
[    1.288322] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[    1.294244] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.295874] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.295897] ehci-pci: EHCI PCI platform driver
[    1.296003] ehci-platform: EHCI generic platform driver
[    1.299745] ehci-platform fe380000.usb: EHCI Host Controller
[    1.300028] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.300301] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    1.310267] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.310486] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.310522] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.310535] usb usb1: Product: EHCI Host Controller
[    1.310548] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[    1.310561] usb usb1: SerialNumber: fe380000.usb
[    1.311195] hub 1-0:1.0: USB hub found
[    1.311262] hub 1-0:1.0: 1 port detected
[    1.315338] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.315531] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    1.315715] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.323603] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.323735] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.323754] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.323764] usb usb2: Product: EHCI Host Controller
[    1.323774] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[    1.323783] usb usb2: SerialNumber: fe3c0000.usb
[    1.324227] hub 2-0:1.0: USB hub found
[    1.324264] hub 2-0:1.0: 1 port detected
[    1.324787] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.324821] ohci-platform: OHCI generic platform driver
[    1.325123] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.325296] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    1.325420] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    1.381116] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.381165] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.381178] usb usb3: Product: Generic Platform OHCI controller
[    1.381190] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[    1.381202] usb usb3: SerialNumber: fe3a0000.usb
[    1.381786] hub 3-0:1.0: USB hub found
[    1.381858] hub 3-0:1.0: 1 port detected
[    1.382747] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.382987] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.383158] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    1.437774] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.437852] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.438067] usb usb4: Product: Generic Platform OHCI controller
[    1.438286] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[    1.438503] usb usb4: SerialNumber: fe3e0000.usb
[    1.439374] hub 4-0:1.0: USB hub found
[    1.439463] hub 4-0:1.0: 1 port detected
[    1.441204] usbcore: registered new interface driver cdc_acm
[    1.441275] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.441547] usbcore: registered new interface driver usblp
[    1.441738] usbcore: registered new interface driver cdc_wdm
[    1.441982] usbcore: registered new interface driver uas
[    1.442266] usbcore: registered new interface driver usb-storage
[    1.442409] usbcore: registered new interface driver ums-alauda
[    1.442627] usbcore: registered new interface driver ums-cypress
[    1.442846] usbcore: registered new interface driver ums-datafab
[    1.443065] usbcore: registered new interface driver ums_eneub6250
[    1.443289] usbcore: registered new interface driver ums-freecom
[    1.443504] usbcore: registered new interface driver ums-isd200
[    1.443726] usbcore: registered new interface driver ums-jumpshot
[    1.443941] usbcore: registered new interface driver ums-karma
[    1.444165] usbcore: registered new interface driver ums-onetouch
[    1.444381] usbcore: registered new interface driver ums-sddr09
[    1.444598] usbcore: registered new interface driver ums-sddr55
[    1.444818] usbcore: registered new interface driver ums-usbat
[    1.445091] usbcore: registered new interface driver usbserial
[    1.445251] usbcore: registered new interface driver usbserial_generic
[    1.445460] usbserial: USB Serial support registered for generic
[    1.445702] usbcore: registered new interface driver option
[    1.445897] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.446385] usbcore: registered new interface driver trancevibrator
[    1.446562] usb20_otg: version 3.10a 21-DEC-2012
[    1.447111] usb20_host: version 3.10a 21-DEC-2012
[    1.448109] usbcore: registered new interface driver xpad
[    1.448259] usbcore: registered new interface driver usb_acecad
[    1.448483] usbcore: registered new interface driver aiptek
[    1.448697] usbcore: registered new interface driver gtco
[    1.448918] usbcore: registered new interface driver hanwang
[    1.449131] usbcore: registered new interface driver kbtab
[    1.450416] .. rk pwm remotectl v1.1 init
[    1.450892] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.451571] sensor_register_slave:mma8452,id=17
[    1.451624] sensor_register_slave:lis3dh,id=7
[    1.451642] sensor_register_slave:mma7660,id=18
[    1.451659] sensor_register_slave:lsm303d,id=22
[    1.451675] sensor_register_slave:gs_mc3230,id=23
[    1.451684] [Gsensor]   gsensor_init
[    1.451700] sensor_register_slave:mpu6880_acc,id=24
[    1.451717] sensor_register_slave:mpu6500_acc,id=25
[    1.451733] sensor_register_slave:lsm330_acc,id=26
[    1.451750] sensor_register_slave:bma2xx_acc,id=27
[    1.451769] sensor_register_slave:akm8975,id=30
[    1.451825] sensor_register_slave:akm8963,id=31
[    1.451842] sensor_register_slave:l3g4200d,id=45
[    1.451859] sensor_register_slave:l3g20d,id=46
[    1.451876] sensor_register_slave:ewtsa,id=47
[    1.451893] sensor_register_slave:lsm330_gyro,id=51
[    1.451909] sensor_register_slave:cm3217,id=53
[    1.451926] sensor_register_slave:cm3218,id=54
[    1.451943] sensor_register_slave:ls_stk3410,id=62
[    1.451960] sensor_register_slave:ps_stk3410,id=67
[    1.453097] i2c /dev entries driver
[    1.454883] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.455016] fan53555-reg: supplied by vcc5v0_sys
[    1.458060] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.458158] fan53555-reg: supplied by vcc5v0_sys
[    1.460381] rockchip-pinctrl pinctrl: pin gpio1-18 already requested by 0-0040; cannot claim for 0-001b
[    1.460431] rockchip-pinctrl pinctrl: pin-50 (0-001b) status -22
[    1.460446] rockchip-pinctrl pinctrl: could not request pin 50 (gpio1-18) from group pmic-dvs2  on device rockchip-pinctrl
[    1.460458] rk808 0-001b: Error applying setting, reverse things back
[    1.460912] rk808 0-001b: Pmic Chip id: 0x0
[    1.464556] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.464671] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.464817] DCDC_REG1: supplied by vcc3v3_sys
[    1.465645] DCDC_REG2: supplied by vcc3v3_sys
[    1.466304] DCDC_REG3: supplied by vcc3v3_sys
[    1.466660] DCDC_REG4: supplied by vcc3v3_sys
[    1.467246] LDO_REG1: supplied by vcc3v3_sys
[    1.468500] LDO_REG2: supplied by vcc3v[   17.262533] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   18.262970] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   19.263406] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   20.263846] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   21.264281] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   22.264717] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   23.265153] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   24.265591] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   24.603843] random: nonblocking pool is initialized
[   25.266026] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   26.266461] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  798.619060] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  799.619529] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  800.620000] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  801.620564] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  802.621035] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  803.621506] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  804.621976] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  805.622446] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  806.622915] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  807.623384] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  808.623927] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  809.624396] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  810.624878] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  811.625348] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[  812.625818] binder: 230:230 transaction failed 29189/-22, size 0-0 line 29483_sys
[    1.469611] LDO_REG3: supplied by vcc3v3_sys
[    1.470725] LDO_REG4: supplied by vcc3v3_sys
[    1.471624] vcc_sd: Failed to create debugfs directory
[    1.471757] LDO_REG5: supplied by vcc3v3_sys
[    1.472843] LDO_REG6: supplied by vcc3v3_sys
[    1.473965] LDO_REG7: supplied by vcc3v3_sys
[    1.475078] LDO_REG8: supplied by vcc3v3_sys
[    1.476196] SWITCH_REG1: supplied by vcc3v3_sys
[    1.476548] SWITCH_REG2: supplied by vcc3v3_sys
[    1.477144] firefly_hwversion_in_range  |\E6{\C0\FF\FF\FF\80l{\C0\FF\FF\FF: hwversion in range(0 conditions)
[    1.480511] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.481168] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad4000
[    1.482090] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad6000
[    1.482818] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009ad8000
[    1.484005] IR NEC protocol handler initialized
[    1.484056] IR RC5(x/sz) protocol handler initialized
[    1.484073] IR RC6 protocol handler initialized
[    1.484088] IR JVC protocol handler initialized
[    1.484144] IR Sony protocol handler initialized
[    1.484159] IR SANYO protocol handler initialized
[    1.484173] IR Sharp protocol handler initialized
[    1.484187] IR MCE Keyboard/mouse protocol handler initialized
[    1.484201] IR XMP protocol handler initialized
[    1.484489] usbcore: registered new interface driver uvcvideo
[    1.484531] USB Video Class driver (1.1.1)
[    1.484553] CamSys driver version: v0.48.2, CamSys head file version: v1.0.0
[    1.490301] __power_supply_register: Expected proper parent device for 'test_ac'
[    1.490508] __power_supply_register: Expected proper parent device for 'test_battery'
[    1.490862] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    1.490987] __power_supply_register: Expected proper parent device for 'test_usb'
[    1.494936] rk_tsadcv2_temp_to_code: Invalid temp(2147483647), set temp to =125000
[    1.495855] device-mapper: uevent: version 1.0.3
[    1.496312] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.496572] Bluetooth: HCI UART driver ver 2.3
[    1.496617] Bluetooth: HCI UART protocol H4 registered
[    1.496627] Bluetooth: HCI UART protocol LL registered
[    1.496643] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    1.496651] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    1.496660] rtk_btusb: Register usb char device interface for BT driver
[    1.496940] usbcore: registered new interface driver rtk_btusb
[    1.497547] cpu cpu0: bin=1
[    1.497656] cpu cpu0: leakage=26
[    1.509808] cpu cpu0: temp=38125, pvtm=147882 (148227 + -345)
[    1.510221] cpu cpu0: pvtm-volt-sel=1
[    1.510349] cpu cpu0: bin-scale=34
[    1.510711] cpu cpu4: bin=1
[    1.510815] cpu cpu4: leakage=49
[    1.523076] cpu cpu4: temp=38125, pvtm=154827 (155040 + -213)
[    1.523237] cpu cpu4: pvtm-volt-sel=1
[    1.523331] cpu cpu4: bin-scale=17
[    1.524753] cpu cpu0: avs=0, target-scale=34
[    1.524893] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.526677] cpu cpu4: avs=0, target-scale=17
[    1.526814] cpu cpu4: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.529273] sdhci: Secure Digital Host Controller Interface driver
[    1.529318] sdhci: Copyright(c) Pierre Ossman
[    1.529338] Synopsys Designware Multimedia Card Interface Driver
[    1.530485] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.530635] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.530687] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.530739] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.530765] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.530823] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    1.530836] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    1.531893] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.532004] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.532022] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.532070] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    1.532126] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.532684] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.532865] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    1.543624] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.556991] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    1.557967] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.559678] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    1.559692] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    1.587042] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.588317] hidraw: raw HID events driver (C) Jiri Kosina
[    1.591489] usbcore: registered new interface driver usbhid
[    1.591504] usbhid: USB HID core driver
[    1.591607] inv_mpu_iio: inv_mpu_init:746
[    1.592079] ashmem: initialized
[    1.593095] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[    1.596051] rknandbase v1.1 2016-11-08
[    1.596459] usbcore: registered new interface driver snd-usb-audio
[    1.597636] rt5640 1-001c: Can not read property hp-con-gpio
[    1.601827] gpiod_direction_output: invalid GPIO
[    1.601838] gpiod_direction_output: invalid GPIO
[    1.601849] gpiod_direction_output: invalid GPIO
[    1.612944] tc358749x 1-000f: tc358749x_i2c_probe success
[    1.615772] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[    1.616559] u32 classifier
[    1.616572]     Actions configured
[    1.616601] Netfilter messages via NETLINK v0.30.
[    1.616645] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.616975] ctnetlink v0.93: registering with nfnetlink.
[    1.617431] xt_time: kernel timezone is -0000
[    1.618044] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.618239] arp_tables: (C) 2002 David S. Miller
[    1.618554] Initializing XFRM netlink socket
[    1.618924] NET: Registered protocol family 10
[    1.619640] mip6: Mobile IPv6
[    1.619667] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.620421] sit: IPv6 over IPv4 tunneling driver
[    1.620804] NET: Registered protocol family 17
[    1.620838] NET: Registered protocol family 15
[    1.620872] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.620968] Bridge firewalling registered
[    1.620981] Ebtables v2.0 registered
[    1.621179] Bluetooth: RFCOMM TTY layer initialized
[    1.621198] Bluetooth: RFCOMM socket layer initialized
[    1.621220] Bluetooth: RFCOMM ver 1.11
[    1.621237] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.621256] Bluetooth: BNEP filters: protocol multicast
[    1.621266] Bluetooth: BNEP socket layer initialized
[    1.621276] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.621285] Bluetooth: HIDP socket layer initialized
[    1.621313] l2tp_core: L2TP core driver, V2.0
[    1.621327] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    1.621345] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.621566] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    1.621606] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    1.621613] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    1.621620] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    1.621675] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    1.621685] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    1.621692] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    1.621735] [BT_RFKILL]: Enter rfkill_rk_init
[    1.621998] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    1.622036] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    1.622061] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    1.622085] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    1.622508] [BT_RFKILL]: Request irq for bt wakeup host
[    1.622542] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    1.622556] [BT_RFKILL]: ** disable irq
[    1.622672] [BT_RFKILL]: bt_default device registered.
[    1.622860] sensor_register_slave:mpu6500_gyro,id=49
[    1.622875] sensor_register_slave:mpu6880_gyro,id=50
[    1.623951] Registered cp15_barrier emulation handler
[    1.624049] Registered setend emulation handler
[    1.625044] registered taskstats version 1
[    1.625576] rockchip ion idev is NULL
[    1.625591] rga2 ff680000.rga: rga ion client create success!
[    1.625715] rga2: Driver loaded successfully ver:3.02
[    1.625845] rga2: Module initialized.
[    1.626600] mali ff9a0000.gpu: leakage=32
[    1.627901] mmc1: MAN_BKOPS_EN bit is not set
[    1.630260] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    1.639205] mali ff9a0000.gpu: temp=38125, pvtm=125094 (125232 + -138)
[    1.639928] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[    1.640228] mali ff9a0000.gpu: pvtm-volt-sel=1
[    1.640804] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    1.641245] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[    1.641287] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    1.641536] mali ff9a0000.gpu: Protected mode not available
[    1.641637] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[    1.641956] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.642020] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[    1.642078] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[    1.642139] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    1.642461]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    1.642475]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    1.642482]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    1.642489]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    1.642497]     kernel: 0x002000000 -- 0x003800000 (24 MB)
[    1.642513]       boot: 0x003800000 -- 0x005800000 (32 MB)
[    1.642520]   recovery: 0x005800000 -- 0x009800000 (64 MB)
[    1.642526]     backup: 0x009800000 -- 0x010800000 (112 MB)
[    1.642532]      cache: 0x010800000 -- 0x018800000 (128 MB)
[    1.642539]     system: 0x018800000 -- 0x078800000 (1536 MB)
[    1.642545]        oem: 0x078800000 -- 0x098800000 (512 MB)
[    1.642552]   metadata: 0x098800000 -- 0x099800000 (16 MB)
[    1.642559] verity_mode: 0x099800000 -- 0x099808000 (0 MB)
[    1.642565]   reserved: 0x099808000 -- 0x099c08000 (4 MB)
[    1.642571]        frp: 0x099c08000 -- 0x099c88000 (0 MB)
[    1.642574] mali ff9a0000.gpu: Probed as mali0
[    1.642583]   userdata: 0x099c88000 -- 0x3a3a00000 (12445 MB)
[    1.642632]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[    1.647195] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    1.647329] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[    1.647555] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    1.647602] xhci-hcd xhci-hcd.10.auto: irq 235, io mem 0xfe800000
[    1.647794] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    1.647807] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.647815] usb usb5: Product: xHCI Host Controller
[    1.647822] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[    1.647830] usb usb5: SerialNumber: xhci-hcd.10.auto
[    1.648176] hub 5-0:1.0: USB hub found
[    1.648205] hub 5-0:1.0: 1 port detected
[    1.648405] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    1.648516] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[    1.648566] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.648636] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    1.648645] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.648652] usb usb6: Product: xHCI Host Controller
[    1.648659] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[    1.648666] usb usb6: SerialNumber: xhci-hcd.10.auto
[    1.648970] hub 6-0:1.0: USB hub found
[    1.648996] hub 6-0:1.0: 1 port detected
[    1.650200] xhci-hcd xhci-hcd.10.auto: remove, state 1
[    1.650226] usb usb6: USB disconnect, device number 1
[    1.655146] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    1.655314] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 7
[    1.655520] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    1.655567] xhci-hcd xhci-hcd.11.auto: irq 236, io mem 0xfe900000
[    1.655741] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[    1.655754] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.655762] usb usb7: Product: xHCI Host Controller
[    1.655769] usb usb7: Manufacturer: Linux 4.4.126 xhci-hcd
[    1.655776] usb usb7: SerialNumber: xhci-hcd.11.auto
[    1.656098] hub 7-0:1.0: USB hub found
[    1.656132] hub 7-0:1.0: 1 port detected
[    1.656329] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[    1.656434] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8
[    1.656488] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.656562] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[    1.656575] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.656583] usb usb8: Product: xHCI Host Controller
[    1.656589] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[    1.656596] usb usb8: SerialNumber: xhci-hcd.11.auto
[    1.656893] hub 8-0:1.0: USB hub found
[    1.656934] hub 8-0:1.0: 1 port detected
[    1.658060] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.658159] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.658180] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.658210] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.658225] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.658264] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    1.658271] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    1.658525] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    1.666627] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[    1.666641] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[    1.666684] xhci-hcd xhci-hcd.10.auto: USB bus 6 deregistered
[    1.666835] xhci-hcd xhci-hcd.10.auto: remove, state 1
[    1.666859] usb usb5: USB disconnect, device number 1
[    1.667310] xhci-hcd xhci-hcd.10.auto: USB bus 5 deregistered
[    1.673634] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.687133] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    1.688324] rockchip-dmc dmc: Failed to get leakage
[    1.688429] rockchip-dmc dmc: Failed to get pvtm
[    1.689716] rockchip-dmc dmc: could not find power_model node
[    1.695116] devfreq dmc: Couldn't update frequency transition information.
[    1.699775] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[    1.700135] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[    1.700195] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[    1.700202] ALSA pcmC1D1c,0:: cannot preallocate for size 32768
[    1.700216] asoc-simple-card rt5640-sound: rt5640-aif2 <-> ff890000.i2s mapping ok
[    1.700392] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[    1.700452] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[    1.700459] ALSA pcmC1D2p,0:: cannot preallocate for size 32768
[    1.700516] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[    1.700562] dma-pl330 ff6d0000.dma-controller: iram space is not enough!
[    1.700582] ALSA pcmC1D2c,0:: cannot preallocate for size 32768
[    1.700595] asoc-simple-card rt5640-sound: tc358749x-audio <-> ff890000.i2s mapping ok
[    1.703788] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[    1.704963] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:03 UTC (1358499003)
[    1.705992] It doesn't contain Rogue gpu
[    1.721797] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.722886] vdd3v3_pcie: disabling
[    1.722918] vcc_sd: disabling
[    1.722925] vcc_otg_vbus: disabling
[    1.723607] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.723898] ret 1024
[    1.724295] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-c55b2bd', rk_ko_ver is '5', built at '17:34:50', on 'Nov  9 2020'.
[    1.724582] Mali: Mali device driver loaded
[    1.724973] input: rk29-keypad as /devices/platform/rockchip-key/input/input2
[    1.725285] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.725764] ALSA device list:
[    1.725782]   #0: rk-hdmi-dp-sound
[    1.725788]   #1: rockchip,rt5640-codec
[    1.726137] Freeing unused kernel memory: 832K
[    1.728431] init: init first stage started!
[    1.728493] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.732101] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[    1.754967] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[    1.755019] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.755035] usb 2-1: Product: USB 2.0 Hub [MTT]
[    1.755937] hub 2-1:1.0: USB hub found
[    1.756138] hub 2-1:1.0: 7 ports detected
[    1.794144] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[    1.803651] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 111
[    1.806942] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    1.806995] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[    1.807534] audit: type=1403 audit(1358499003.600:2): policy loaded auid=4294967295 ses=4294967295
[    1.808068] init: (Initializing SELinux non-enforcing took 0.08s.)
[    1.811683] init: init second stage started!
[    1.816799] init: Setting ro.rk.soc=rk3399
[    1.816935] init: OK,EMMC DRIVERS INIT OK
[    1.816976] init: property_set("ro.boot.mode", "emmc") failed
[    1.817038] init: property_set("ro.hardware", "rk30board") failed
[    1.818977] init: Running restorecon...
[    1.883752] init: waitpid failed: No child processes
[    1.884034] init: (Loading properties from /default.prop took 0.00s.)
[    1.885536] init: (Parsing /init.environ.rc took 0.00s.)
[    1.885825] init: (Parsing /init.usb.rc took 0.00s.)
[    1.886595] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[    1.887159] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[    1.887219] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[    1.887282] init: could not import file '/init.stt_trace.rc' from '/init.debug.rc': No such file or directory
[    1.887423] init: (Parsing /init.logs.rc took 0.00s.)
[    1.887493] init: (Parsing /init.crashlogd.rc took 0.00s.)
[    1.887574] init: (Parsing /init.coredump.rc took 0.00s.)
[    1.887620] init: (Parsing /init.log-watch.rc took 0.00s.)
[    1.887667] init: (Parsing /init.kernel.rc took 0.00s.)
[    1.887745] init: (Parsing /init.debug-charging.rc took 0.00s.)
[    1.887769] init: (Parsing /init.debug.rc took 0.00s.)
[    1.887781] init: (Parsing init.rockchip.rc took 0.00s.)
[    1.888088] init: (Parsing init.connectivity.rc took 0.00s.)
[    1.888128] init: could not import file 'init.box.samba.rc' from '/init.rk30board.rc': No such file or directory
[    1.888225] init: (Parsing init.rk3399.rc took 0.00s.)
[    1.888312] init: init.tablet.rc: 23: invalid keyword 'ioprio'
[    1.888360] init: (Parsing init.tablet.rc took 0.00s.)
[    1.888388] init: could not import file 'init.car.rc' from '/init.rk30board.rc': No such file or directory
[    1.888430] init: could not import file 'init.optee.rc' from '/init.rk30board.rc': No such file or directory
[    1.888444] init: (Parsing /init.rk30board.rc took 0.00s.)
[    1.888896] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    1.888978] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[    1.889000] init: (Parsing /init.rc took 0.00s.)
[    1.889379] init: Starting service 'ueventd'...
[    1.891086] ueventd: ueventd started!
[    1.891686] ueventd: invalid gid 'trace'
[    1.893777] audit: type=1400 audit(1358499003.686:3): avc:  denied  { getattr } for  pid=1 comm="init" path="/sys/kernel/debug/tracing/trace_marker" dev="tracefs" ino=3200 scontext=u:r:init:s0 tcontext=ubject_r:debugfs_trace_marker:s0 tclass=file permissive=1
[    2.079950] ueventd: Coldboot took 0.19s.
[    2.115270] init: write_file: Unable to open '/proc/self/coredump_filter': No such file or directory
[    2.115316] init: write_file: Unable to open '/proc/sys/kernel/panic_on_stackoverflow': No such file or directory
[    2.115345] init: Waiting for /dev/.coldboot_done...
[    2.115395] init: Waiting for /dev/.coldboot_done took 0.00s.
[    2.115429] init: /dev/hw_random not found
[    2.115911] keychord: using input dev ff420030.pwm for fevent
[    2.115922] keychord: using input dev rk29-keypad for fevent
[    2.124684] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[    2.131763] audit: type=1400 audit(1358499003.923:4): avc:  denied  { relabelto } for  pid=1 comm="init" name="oem" dev="rootfs" ino=2145 scontext=u:r:init:s0 tcontext=ubject_remfs:s0 tclass=dir permissive=1
[    2.131810] audit: type=1400 audit(1358499003.923:5): avc:  denied  { associate } for  pid=1 comm="init" name="oem" dev="rootfs" ino=2145 scontext=ubject_remfs:s0 tcontext=ubject_r:rootfs:s0 tclass=filesystem permissive=1
[    2.131927] audit: type=1400 audit(1358499003.923:6): avc:  denied  { mounton } for  pid=1 comm="init" path="/oem" dev="rootfs" ino=2145 scontext=u:r:init:s0 tcontext=ubject_remfs:s0 tclass=dir permissive=1
[    2.140193] vendor storage:20160801 ret = 0
[    2.140236] EXT4-fs (mmcblk1p11): VFS: Can't find ext4 filesystem
[    2.140349] Registered swp emulation handler
[    2.140569] init: write_file: Unable to open '/sys/module/rockchip_pm/parameters/policy': No such file or directory
[    2.141343] fs_mgr: Warning: unknown flag resize
[    2.141426] init: /dev/hw_random not found
[    2.141498] init: write_file: Unable to open '/sys/block/mmcblk0/bdi/read_ahead_kb': No such file or directory
[    2.141951] fs_mgr: Warning: unknown flag resize
[    2.143662] EXT4-fs (mmcblk1p10): VFS: Can't find ext4 filesystem
[    2.143718] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=-1
[    2.143938] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/platform/fe330000.sdhci/by-name/system at /system options: noauto_da_alloc error: Invalid argument
[    2.145207] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[    2.145229] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache (executable not in system image)
[    2.151421] EXT4-fs (mmcblk1p9): recovery complete
[    2.151846] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    2.151926] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[    2.153527] EXT4-fs (mmcblk1p12): Ignoring removed nomblk_io_submit option
[    2.154984] EXT4-fs (mmcblk1p12): warning: maximal mount count reached, running e2fsck is recommended
[    2.155462] EXT4-fs (mmcblk1p12): recovery complete
[    2.155473] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    2.155508] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[    2.171409] fs_mgr: check_fs(): unmount(/metadata) succeeded
[    2.171443] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata (executable not in system image)
[    2.178052] EXT4-fs (mmcblk1p12): warning: maximal mount count reached, running e2fsck is recommended
[    2.178586] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    2.178648] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[    2.181268] EXT4-fs (mmcblk1p16): Ignoring removed nomblk_io_submit option
[    2.190732] EXT4-fs (mmcblk1p16): warning: maximal mount count reached, running e2fsck is recommended
[    2.191523] EXT4-fs (mmcblk1p16): recovery complete
[    2.191994] EXT4-fs (mmcblk1p16): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    2.192144] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/userdata,/data,ext4)=0: Success
[    2.212143] fs_mgr: check_fs(): unmount(/data) succeeded
[    2.212249] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/userdata (executable not in system image)
[    2.216257] EXT4-fs (mmcblk1p16): warning: maximal mount count reached, running e2fsck is recommended
[    2.216999] EXT4-fs (mmcblk1p16): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[    2.217085] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=ext4)=0
[    2.218537] init: fs_mgr_mount_all returned an error
[    2.219255] init: fs_mgr_mount_all returned unexpected error 255
[    2.219420] init: do_start: Service logd not found
[    2.222383] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali_kbase.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk29-ipp.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/pvrsrvkm.ko") failed: No such file or directoryinit: finit_module for "/drmboot.ko" failed: Exec format errorfs_mgr: Warning: unknown flag resize
[    2.225423] zram0: detected capacity change from 0 to 533413888
[    2.226678] Unable to find swap-space signature
[    2.226784] fs_mgr: swapon failed for /dev/block/zram0
[    2.227118] init: (Loading properties from /system/build.prop took 0.00s.)
[    2.227207] init: (Loading properties from /vendor/build.prop took 0.00s.)
[    2.227420] init: (Loading properties from /factory/factory.prop took 0.00s.)
[    2.227685] fs_mgr: Warning: unknown flag resize
[    2.227888] init: /recovery not specified in fstab
[    2.228222] init: do_start: Service debuggerd not found
[    2.228280] init: do_start: Service debuggerd64 not found
[    2.228496] init: do_start: Service vold not found
[    2.229416] init: Not bootcharting.
[    2.246806] init: cannot find '/system/bin/tzdatacheck' (No such file or directory), disabling 'exec 1 (/system/bin/tzdatacheck)'
[    2.248225] audit: type=1400 audit(1358499004.040:7): avc:  denied  { setattr } for  pid=1 comm="init" name="cifsmanager" dev="mmcblk1p16" ino=186945 scontext=u:r:init:s0 tcontext=ubject_r:cifsmanager_exec:s0 tclass=dir permissive=1
[    2.250189] EXT4-fs (mmcblk1p16): Unrecognized mount option "background_gc=on" or missing value
[    2.252389] init: write_file: Unable to open '/proc/sys/kernel/core_pattern': No such file or directory
[    2.252512] init: (Loading properties from /data/local.prop took 0.00s.)
[    2.252764] init: do_start: Service logd not found
[    2.252785] init: do_start: Service logd-reinit not found
[    2.253162] init: write_file: Unable to open '/proc/sys/vm/min_free_order_shift': No such file or directory
[    2.254214] init: Starting service 'healthd'...
[    2.254523] init: cannot find '/system/bin/displayd' (No such file or directory), disabling 'displayd'
[    2.254577] init: cannot find '/system/vendor/bin/elogs.sh' (No such file or directory), disabling 'earlylogs'
[    2.254837] init: SELinux:  Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[    2.255906] init: write_file: Unable to open '/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold': No such file or directory
[    2.256135] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    2.257150] init: cannot find '/system/bin/busybox' (No such file or directory), disabling 'exec 2 (/system/bin/busybox)'
[    2.257957] audit: type=1400 audit(1358499004.050:8): avc:  denied  { relabelto } for  pid=1 comm="init" name="recovery" dev="tmpfs" ino=2449 scontext=u:r:init:s0 tcontext=ubject_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[    2.258029] audit: type=1400 audit(1358499004.050:9): avc:  denied  { relabelto } for  pid=1 comm="init" name="boot" dev="tmpfs" ino=2445 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[    2.258358] init: SELinux: Could not get canonical path for /system/bin/tee-supplicant restorecon: No such file or directory.
[    2.258402] init: SELinux: Could not get canonical path for /system/bin/rk_store_keybox restorecon: No such file or directory.
[    2.258535] init: cannot find '/system/xbin/fsu' (No such file or directory), disabling 'fsud'
[    2.258562] init: cannot find '/system/xbin/vm' (No such file or directory), disabling 'vm_daemon'
[    2.259478] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    2.259499] init: write: cannot expand '${ro.serialno}'
[    2.259515] init: property 'ro.product.manufacturer' doesn't exist while expanding '${ro.product.manufacturer}'
[    2.259524] init: write: cannot expand '${ro.product.manufacturer}'
[    2.259538] init: property 'ro.product.model' doesn't exist while expanding '${ro.product.model}'
[    2.259546] init: write: cannot expand '${ro.product.model}'
[    2.260409] file system registered
[    2.261203] using random self ethernet address
[    2.261221] using random host ethernet address
[    2.261268] init: write_file: Unable to open '/config/usb_gadget/g1/functions/rndis.gs4/wceis': Permission denied
[    2.265762] audit: type=1400 audit(1358499004.056:10): avc:  denied  { setattr } for  pid=1 comm="init" name="mmcblk1p13" dev="tmpfs" ino=2478 scontext=u:r:init:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[    2.267267] init: cannot find '/system/bin/sh' (No such file or directory), disabling 'console'
[    2.267346] init: Starting service 'adbd'...
[    3.256335] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    4.256760] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    5.257206] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    6.257636] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    7.258070] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    8.258503] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[    9.258942] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   10.259378] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   11.259817] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   12.260339] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   12.483408] read descriptors
[   12.483490] read strings
[   13.260781] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   14.261221] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   15.261657] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
[   16.262092] binder: 230:230 transaction failed 29189/-22, size 0-0 line 2948
发表于 2021-4-15 12:10:30 | 显示全部楼层
用 androidtool 先擦除,然后重新上电,再烧录一次。
 楼主| 发表于 2021-4-15 12:23:28 | 显示全部楼层
必须要用androidtool工具来擦出吗?ubuntu环境下可以是使用upgrade_tool来擦出吗?
GMT+8, 2026-10-26 06:49 , Processed in 0.089370 second(s), 22 queries .
