查看: 33988|回复: 3
ROC_RK3308-CC SDK包Firefly-RK3308_Linux_SDK_git_20190924.7z编译buildroot
发表于 2021-4-9 10:18:42 | 显示全部楼层 |阅读模式
问题:ROC_RK3308-CC SDK包Firefly-RK3308_Linux_SDK_git_20190924.7z编译buildroot报错  #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."92 |  #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."
SDK包是从网盘下载的,对比md5码,解压无异常,按照维基的SDK 编译步骤走了一遍,uboot 和kernel的编译都 成功了,
唯独编译 buildroot 时 出现了 上面的报错,求分析
发表于 2021-4-9 11:30:37 | 显示全部楼层
发表于 2021-4-9 11:32:40 | 显示全部楼层
 楼主| 发表于 2021-4-9 16:58:53 | 显示全部楼层
各种尝试,最后参考了下面链接的做法
http://www.voycn.com/article/bianyimoujiyuopenwrtdesdk
然后SDK的 buildroot 编译就通过了
GMT+8, 2026-10-26 14:32 , Processed in 0.075131 second(s), 23 queries .
