查看: 37307|回复: 1
怎么修改脚本才能在执行/build.sh rootfs的时候不下载attr-2.4.4
发表于 2021-3-5 16:52:29 | 显示全部楼层 |阅读模式
root@dggphisprb02049:/usr1/z00376331/firefly-hisi-sdk# ./build.sh rootfs
make: Entering directory '/usr1/z00376331/firefly-hisi-sdk/buildroot'
/bin/sh: /1024/1024: syntax error: operand expected (error token is "/1024/1024")
>>> host-attr 2.4.48 Downloading
--2021-03-05 16:17:17--  http://download.savannah.gnu.org/releases/attr/attr-2.4.48.tar.gz
Resolving download.savannah.gnu.org (download.savannah.gnu.org)... 209.51.188.200, 2001:470:142:5::200
Connecting to download.savannah.gnu.org (download.savannah.gnu.org)|209.51.188.200|:80... failed: Connection timed out.
Connecting to download.savannah.gnu.org (download.savannah.gnu.org)|2001:470:142:5::200|:80... failed: Network is unreachable.
--2021-03-05 16:19:28--  http://sources.buildroot.net/attr/attr-2.4.48.tar.gz
Resolving sources.buildroot.net (sources.buildroot.net)... 104.26.1.37, 104.26.0.37, 172.67.72.56, ...
Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.1.37|:80... failed: Connection timed out.
Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.0.37|:80... failed: Connection timed out.
Connecting to sources.buildroot.net (sources.buildroot.net)|172.67.72.56|:80... failed: Connection timed out.
Connecting to sources.buildroot.net (sources.buildroot.net)|2606:4700:20::681a:25|:80... failed: Network is unreachable.
Connecting to sources.buildroot.net (sources.buildroot.net)|2606:4700:20::681a:125|:80... failed: Network is unreachable.
Connecting to sources.buildroot.net (sources.buildroot.net)|2606:4700:20::ac43:4838|:80... failed: Network is unreachable.
--2021-03-05 16:26:01--  http://sources.buildroot.net/attr-2.4.48.tar.gz
Resolving sources.buildroot.net (sources.buildroot.net)... 104.26.0.37, 104.26.1.37, 172.67.72.56, ...
package/pkg-generic.mk:157: recipe for target '/usr1/z00376331/firefly-hisi-sdk/output/Firefly-3559A4G_linux/build/host-attr-2.4.48/.stamp_downloaded' failed
make: *** [/usr1/z00376331/firefly-hisi-sdk/output/Firefly-3559A4G_linux/build/host-attr-2.4.48/.stamp_downloaded] Error 1
make: Leaving directory '/usr1/z00376331/firefly-hisi-sdk/buildroot'
发表于 2021-3-7 15:40:44 | 显示全部楼层
没联网吗?
http://sources.buildroot.net/attr/attr-2.4.48.tar.gz 看你这个都下载不了?
你手动下载看看能下载吗
GMT+8, 2026-11-7 22:01 , Processed in 0.071040 second(s), 22 queries .
