查看: 37948|回复: 0
Core-3559AV100-JD4板烧写SDK中的kernel和rootfs启动失败
发表于 2021-3-4 21:26:06 | 显示全部楼层 |阅读模式
Core-3559AV100-JD4板烧写Hi3559AV100_SDK_V2.0.3.1\image_glibc_multi-core_arm64下的uImage_hi3559av100_multi-core和rootfs_hi3559av100_96M.ext4系统无法启动,提示如下错误:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.9.37 #1
Hardware name: Hisilicon HI3559AV100 DEMO Board (DT)
Call trace:
[<ffffff80080880d8>] dump_backtrace+0x0/0x1d0
[<ffffff80080883b4>] show_stack+0x14/0x20
[<ffffff8008338bcc>] dump_stack+0x94/0xb8
[<ffffff800811d9d0>] panic+0x130/0x280
[<ffffff80088210fc>] mount_block_root+0x22c/0x2e8
[<ffffff8008821370>] mount_root+0x74/0x84
[<ffffff80088214e4>] prepare_namespace+0x164/0x1a0
[<ffffff8008820d0c>] kernel_init_freeable+0x1c0/0x1e0
[<ffffff8008650868>] kernel_init+0x10/0x100
[<ffffff8008082ee0>] ret_from_fork+0x10/0x30
SMP: stopping secondary CPUs
Kernel Offset: disabled
Memory Limit: 512 MB
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-blo
ck(0,0)
GMT+8, 2026-11-7 22:00 , Processed in 0.067065 second(s), 21 queries .
