查看: 34937|回复: 0
Tinker Board Debian OS V2.1.16
发表于 2020-11-12 10:52:09 | 显示全部楼层 |阅读模式
Release Notes
1. Fix the flickering issue for IMX219 in full size mode
2. Fix the issue that channel halted with unknown reason for dwx2 USB host
3. Fine tune TX/RX delay for RK3288 LAN and RGMII driving for RTL8211E.
4. Fix the issue that noise occurs when playing 24bits 96KHz WAV file.
5. Resolve the failure to saveenv for u-boot when booting up from eMMC
6. Enable kernel setting for adjusting HDMI brightness, contrast, saturation, and hue
7. Build in driver for DS3231 RTC module
8. Support ASUS USB BT500 (RTL8761BU) dongle
9. Fix SPI issue to support Waveshare-Expansions.
10. Improve HDMI compatibility.
1.解决了全尺寸模式下IMX219的闪烁问题
2.修复dwx2 USB主机的未知原因导致通道停止的问题
3.调整RK3288 LAN的TX / RX延迟和RTL8211E的RGMII驱动。
4.解决了播放24位96KHz WAV文件时出现噪音的问题。
5.解决了从eMMC引导时saveenv for u-boot失败的问题
6.启用内核设置以调整HDMI亮度,对比度,饱和度和色相
7.内置DS3231 RTC模块的驱动程序
8.支持华硕USB BT500(RTL8761BU)加密狗
9.修复SPI问题以支持Waveshare-Expansions。
10.改善HDMI兼容性。
SHA256:
ab95580acca138d9d59418006dfb7a65ae6ab8e970d75c782b86fc5e498e4bc9 (zip)
https://dlcdnets.asus.com/pub/ASUS/mb/Embedded_IPC/TinkerBoard_S/Tinker_Board-Debian-Stretch-V2.1.16-20200813.zip
支持Tinkerboard 和tinkerboard S
GMT+8, 2026-10-29 03:11 , Processed in 0.105809 second(s), 20 queries .
