查看: 33801|回复: 3
rock pi4b烧写update.img之后不能正常启动
发表于 2020-9-24 23:29:18 | 显示全部楼层 |阅读模式
我用Android_tool工具烧写镜像到emmc之后,系统起不来。下面是启动log,是什么原因导致的
DDR Version 1.20 20190314
In
soft reset
SRX
channel 0
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=14 CS=1 Die Bus-Width=16 Size=512MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x10
ch 1 ddrconfig = 0x101, ddrsize = 0x10
pmugrf_os_reg[2] = 0x3241F241, stride = 0x5
OUT
Boot1 Release Time: Jun  2 2020 15:02:17, version: 1.26
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14930MB
FwPartOffset=2000 , 100000
UsbBoot ...73735
powerOn 86004
In
soft reset
SRX
channel 0
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x0
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
256B stride
OUT
Boot1: 2018-06-26, version: 1.14
CPUId = 0x0
ChipType = 0x10, 279
Spi_ChipId = b4016
SpiBootInit:0
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 23428
SecureMode = 0
SecureInit ret = 0, SecureMode = 0
GPT vendor signature is wrong
LoadTrust Addr:0x1800
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 1000
Load OK, addr=0x200000, size=0xee888
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):0e7a845
NOTICE:  BL31: Built : 16:13:46, Apr 17 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-02676-g4490220395 (Jul 01 2019 - 07:49:56 +0000)
Model: Rockchip RK3399 rockpi4b Board
PreSerial: 2
DRAM:  1022 MiB
Relocation Offset is: 3dbe0000
Sysmem: init
I2c speed: 400000Hz
PMIC:  RK808
vdd-center init 950000 uV
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
dcache off
Device 0: unknown device
dcache on
Card did not respond to voltage select!
mmc_init: -95, time 9
switch to partitions #0, OK
mmc0(part 0) is current device
Bootdev: mmc 0
PartType: EFI
boot mode: recovery
enter Recovery mode!
boot mode: recovery
Load FDT from recovery part
Rockchip UBOOT DRM driver version: v1.0.1
发表于 2020-9-25 14:24:06 | 显示全部楼层
麻烦提供一下系统版本截图
 楼主| 发表于 2020-9-25 20:25:05 | 显示全部楼层
我上面用的是update.img镜像烧写到emmc,使用tf卡做的GPT镜像可以起来
发表于 2020-12-29 20:17:06 | 显示全部楼层
你是怎么烧进去的呢!从bootloader吗!
GMT+8, 2026-11-19 23:05 , Processed in 0.077341 second(s), 26 queries .
