查看: 18201|回复: 2
hikey970使用SPI2片选无效
发表于 2020-7-13 16:44:41 | 显示全部楼层 |阅读模式
使用hikey970的SPI2搭载sensor做数据传输,但是发现CS总是为高电平,我试着直接往CS的GPIO写0,读出来的值也是0,但是CS的电压值一直为高,这样我的sensor就没发正常使用,请求大佬给予技术支持。
 楼主| 发表于 2020-7-14 11:30:19 | 显示全部楼层
附加内存log:
[  531.402482] mali e82c0000.mali: error detected from slot 0, job status 0x00000051 (INSTR_INVALID_ENC)
[  531.402520] mali e82c0000.mali: t6xx: GPU fault 0x51 from job slot 0
[  531.413372] mali e82c0000.mali: error detected from slot 0, job status 0x00000051 (INSTR_INVALID_ENC)
[  531.413401] mali e82c0000.mali: t6xx: GPU fault 0x51 from job slot 0
[  531.420140] mali e82c0000.mali: error detected from slot 0, job status 0x0000005b (UNKNOWN)
[  531.420157] mali e82c0000.mali: t6xx: GPU fault 0x5b from job slot 0
[  531.430810] mali e82c0000.mali: error detected from slot 0, job status 0x00000051 (INSTR_INVALID_ENC)
[  531.431206] mali e82c0000.mali: t6xx: GPU fault 0x51 from job slot 0
[  531.447987] mali e82c0000.mali: error detected from slot 0, job status 0x00000051 (INSTR_INVALID_ENC)
[  531.448005] mali e82c0000.mali: t6xx: GPU fault 0x51 from job slot 0
[  531.497381] mali e82c0000.mali: error detected from slot 0, job status 0x00000051 (INSTR_INVALID_ENC)
[  531.497488] mali e82c0000.mali: t6xx: GPU fault 0x51 from job slot 0
 楼主| 发表于 2020-7-15 14:24:07 | 显示全部楼层
有没有人成功使用SPI2的DMA模式,能否分享一下?非常感谢
GMT+8, 2026-11-25 09:05 , Processed in 0.076400 second(s), 22 queries .
