查看: 19260|回复: 0
TX2开发套件 C02 底板的上电自启教程
发表于 2019-6-5 16:26:04 | 显示全部楼层 |阅读模式
C02底板是长这样的
它的这个接口是向板边的,而B04版本的是竖起来的。
(看底板版本的教程看另一个贴子:http://smartfire.cn/thread-1079-1-1.html)
上电自启的方法:
C02 board does not support Auto-Power-On function directly, it requires a few more changes to enable that:
1. Install 0 Ohm, 0402 resistor at R313
Asserts ACOK to allow Jetson TX2 or Jetson TX2 4GB to Auto-Power-On.
2. Move R501, 10k, 0402, resistor to R287
Enables the VDD_IN supply to the module connector as soon as the power is applied (disables hot-plug protection)
3. Remove R383
Disables the ON control from the pushbutton Micro-Controller
4. Remove R384
Removes the VDD_IN Bleeder resistor to keep this from consuming power during normal operation.
5. Add wire across Q47 pin 2 and 3.
Force Button Micro-Controller in Mobile PMIC Mode (allows Jetson TX2i to function as if it were in a P2597_B04 carrier board – will boot when power is attached without button press)
C02 版本底板的设计文件可这里下载
链接:https://pan.baidu.com/s/1u65JUZhoxtpc_jhziZM1Ew
提取码:sg40
GMT+8, 2026-10-13 21:25 , Processed in 0.082234 second(s), 23 queries .
