查看: 19220|回复: 0
jetson nano工作温度 商业级
发表于 2019-4-30 16:50:40 | 显示全部楼层 |阅读模式
jetson nano的工作温度是与TX1,TX2一样的,所以它是商业级的,
TX2i才是工业级的
官方回复的原话如下:
That said, the temperature range and other attributes will be comparable to Jetson TX1 and Jetson TX2, not Jetson TX2i. You should plan to address more stringent operational requirements at the system level.
GMT+8, 2026-10-13 21:22 , Processed in 0.066708 second(s), 20 queries .
