查看: 30809|回复: 0
新人提问:970AOSP编译成功之后引导不起来
发表于 2019-4-28 15:16:25 | 显示全部楼层 |阅读模式
引导的时候报failed to read fstab from dt
[    5.902279] <[hisi_ip_to_atf_is_enabled]:regulator_id=2>
[    5.907587] <[hisi_ip_to_atf_i_enabled]:regulator_id=3>
[    5.912894] <[hisi_ip_to_atf_is_enabled]:regulator_id=4>
[    5.918202] <[hisi_ip_to_atf_is_enabed]:regulator_id=5>
[    5.923508] <[hisi_ip_to_atf_is_enabled]:regulator_id=6>
[    5.928815] <[hisi_ip_to_atf_is_enabled]:rgulator_id=7>
[    5.934121] ALSA device list:
[    5.937083]   #0: hikey-hdmi
[    5.940015] uart-pl011 fff32000.serial: noDMA platform data
AT
AT
[    5.946669] Freeing unused kernel memory: 4096K
[    5.954802] init: init first stage started!
[    5.959139] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
        [    5.966276] init: [libfs_mgr]ReadDefaultFstab(): failed to find device defab
[    5.974023] init: Failed to fstab [libfs_mgr]ReadDefaultFstab(): failed to find device default fstab
[    5.994592] init: First stage mount skipped (missing/incmpatible/empty fstab in device tree)
[    6.003151] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[    6.00999] init: execv("/system/bin/init") failed: No such file or directory
[    6.017097] init: Reboot ending, jumping to kernel
[   6.021896] kvm: exiting hardware virtualization
[    6.026738] hifi_misc [I][339334]:hifi_reboot_notifier:1378: reboot +.
[   6.033264] hifi_misc [I][339548]:hifi_reboot_notifier:1387: reboot -.
[    6.042525] sd 0:0:0:3: [sdd] Synchronizing SCSI cache
[    6.048911] sd 0:0:0:2: [sdc] Synchronizing SCSI cache
[    6.054506] sd 0:0:0:1: [sdb] Synchronizing SCSI cache
[    6.230265] reboot: Restarting system with command 'bootloader'
然后就重启到了bootloader 求解决 以及image.gz-dtb是不是已经被舍弃了?我只看到Image.gz跟Image
GMT+8, 2026-11-7 22:01 , Processed in 0.071005 second(s), 20 queries .
