查看: 3253|回复: 0
rock 3a 烧写系统启动不了uboot
发表于 2023-3-13 15:18:25 | 显示全部楼层 |阅读模式
新人求助,新的rock 3a开发板按照
https://youyeetoo.cn/forum.php?mod=viewthread&tid=5523&highlight=rock%2Bpi%2B3
这个里面 线刷系统(EMMC作为存储模块才可用线刷) 烧写了系统,然后启动的时候控制台启动不了uboot,请大佬们看一下是啥原因
[14:54:25.758]收←◆\0
[14:54:27.152]收←◆DDR Version V1.10 20210810
In
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB
tdqss: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -48ps, dqs3: -120ps,
tdqss: cs1 dqs0: 48ps, dqs1: -96ps, dqs2: -48ps, dqs3: -144ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x61
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1056MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x32
cs 0:
the read training result:
DQS0:0x38, DQS1:0x3b, DQS2:0x3c, DQS3:0x35,
min  : 0x7  0x8  0xa  0x8  0x1  0x2  0x4  0x1 , 0x8  0x5  0x1  0x1  0xb  0x8  0x8  0x6 ,
       0xd  0xd  0xa  0x9  0x3  0x0  0x2  0x3 , 0x9  0x6  0x4  0x1  0xb  0xa  0x9  0xa ,
mid  :0x23 0x25 0x26 0x24 0x1d 0x1f 0x21 0x1e ,0x25 0x23 0x1e 0x1f 0x27 0x25 0x27 0x24 ,
      0x29 0x28 0x26 0x25 0x1f 0x1d 0x1f 0x20 ,0x24 0x22 0x21 0x1d 0x28 0x27 0x25 0x27 ,
max  :0x3f 0x42 0x43 0x40 0x39 0x3c 0x3e 0x3b ,0x42 0x42 0x3b 0x3e 0x44 0x43 0x46 0x43 ,
      0x46 0x44 0x43 0x42 0x3b 0x3a 0x3d 0x3e ,0x3f 0x3f 0x3e 0x3a 0x46 0x44 0x42 0x44 ,
range:0x38 0x3a 0x39 0x38 0x38 0x3a 0x3a 0x3a ,0x3a 0x3d 0x3a 0x3d 0x39 0x3b 0x3e 0x3d ,
      0x39 0x37 0x39 0x39 0x38 0x3a 0x3b 0x3b ,0x36 0x39 0x3a 0x39 0x3b 0x3a 0x39 0x3a ,
the write training result:
DQS0:0x2f, DQS1:0x29, DQS2:0x2c, DQS3:0x22,
min  :0x58 0x59 0x5a 0x58 0x50 0x52 0x55 0x56 0x53 ,0x4f 0x4f 0x48 0x4b 0x52 0x50 0x52 0x51 0x4d ,
      0x54 0x54 0x4f 0x4f 0x4b 0x49 0x4c 0x4f 0x4f ,0x4d 0x4c 0x49 0x47 0x50 0x50 0x4f 0x52 0x4b ,
mid  :0x74 0x76 0x77 0x74 0x6b 0x6d 0x70 0x71 0x6e ,0x6c 0x69 0x64 0x66 0x6d 0x6b 0x6c 0x6d 0x68 ,
      0x71 0x71 0x6c 0x6b 0x65 0x62 0x66 0x6a 0x6a ,0x69 0x66 0x63 0x61 0x6b 0x6c 0x69 0x6e 0x63 ,
max  :0x91 0x93 0x94 0x91 0x86 0x89 0x8c 0x8c 0x8a ,0x89 0x84 0x81 0x82 0x88 0x87 0x87 0x89 0x84 ,
      0x8e 0x8e 0x8a 0x88 0x80 0x7b 0x80 0x86 0x85 ,0x86 0x81 0x7d 0x7b 0x86 0x88 0x83 0x8a 0x7c ,
range:0x39 0x3a 0x3a 0x39 0x36 0x37 0x37 0x36 0x37 ,0x3a 0x35 0x39 0x37 0x36 0x37 0x35 0x38 0x37 ,
      0x3a 0x3a 0x3b 0x39 0x35 0x32 0x34 0x37 0x36 ,0x39 0x35 0x34 0x34 0x36 0x38 0x34 0x38 0x31 ,
cs 1:
DQS0:0x3a, DQS1:0x3d, DQS2:0x3f, DQS3:0x35,
min  : 0x7  0x8  0xa  0x9  0x1  0x3  0x4  0x2 , 0x9  0x5  0x2  0x2  0xe  0xa  0xb  0x8 ,
       0xe  0xf  0xb  0xa  0x5  0x2  0x3  0x5 , 0x8  0x5  0x4  0x1  0xb  0xa  0x9  0xa ,
mid  :0x23 0x26 0x27 0x25 0x1d 0x20 0x21 0x1f ,0x26 0x24 0x20 0x20 0x2a 0x28 0x29 0x26 ,
      0x2c 0x2b 0x28 0x27 0x22 0x20 0x21 0x22 ,0x23 0x22 0x21 0x1e 0x28 0x27 0x25 0x27 ,
max  :0x3f 0x44 0x45 0x42 0x3a 0x3e 0x3f 0x3c ,0x44 0x44 0x3e 0x3f 0x47 0x46 0x48 0x45 ,
      0x4a 0x48 0x46 0x44 0x3f 0x3e 0x3f 0x40 ,0x3f 0x3f 0x3f 0x3b 0x46 0x45 0x42 0x44 ,
range:0x38 0x3c 0x3b 0x39 0x39 0x3b 0x3b 0x3a ,0x3b 0x3f 0x3c 0x3d 0x39 0x3c 0x3d 0x3d ,
      0x3c 0x39 0x3b 0x3a 0x3a 0x3c 0x3c 0x3b ,0x37 0x3a 0x3b 0x3a 0x3b 0x3b
[14:54:27.259]收←◆0x39 0x3a ,
min  :0x5f 0x60 0x61 0x5f 0x57 0x5a 0x5d 0x5d 0x5b ,0x4e 0x4d 0x46 0x47 0x50 0x4e 0x50 0x4f 0x4c ,
      0x53 0x53 0x4f 0x4f 0x4a 0x47 0x4c 0x4e 0x4f ,0x4d 0x4b 0x49 0x46 0x4f 0x4f 0x4e 0x52 0x49 ,
mid  :0x7b 0x7d 0x7f 0x7b 0x73 0x76 0x79 0x78 0x77 ,0x6b 0x68 0x61 0x64 0x6b 0x69 0x6b 0x6b 0x67 ,
      0x70 0x70 0x6c 0x6b 0x65 0x60 0x64 0x6a 0x6a ,0x69 0x65 0x63 0x60 0x6a 0x6b 0x68 0x6d 0x62 ,
max  :0x98 0x9b 0x9d 0x98 0x8f 0x93 0x96 0x94 0x93 ,0x88 0x83 0x7d 0x81 0x87 0x85 0x86 0x87 0x82 ,
      0x8d 0x8e 0x89 0x88 0x80 0x7a 0x7c 0x86 0x86 ,0x86 0x80 0x7d 0x7b 0x85 0x87 0x83 0x89 0x7b ,
range:0x39 0x3b 0x3c 0x39 0x38 0x39 0x39 0x37 0x38 ,0x3a 0x36 0x37 0x3a 0x37 0x37 0x36 0x38 0x36 ,
      0x3a 0x3b 0x3a 0x39 0x36 0x33 0x30 0x38 0x37 ,0x39 0x35 0x34 0x35 0x36 0x38 0x35 0x37 0x32 ,
CA Training result:
cs:0 min  :0x47 0x49 0x42 0x43 0x41 0x3e 0x46 ,0x47 0x47 0x41 0x41 0x42 0x40 0x48 ,
cs:0 mid  :0x87 0x87 0x81 0x81 0x80 0x7d 0x77 ,0x87 0x84 0x80 0x7f 0x81 0x7f 0x79 ,
cs:0 max  :0xc8 0xc6 0xc1 0xbf 0xc0 0xbc 0xa8 ,0xc8 0xc2 0xc0 0xbd 0xc0 0xbe 0xab ,
cs:0 range:0x81 0x7d 0x7f 0x7c 0x7f 0x7e 0x62 ,0x81 0x7b 0x7f 0x7c 0x7e 0x7e 0x63 ,
cs:1 min  :0x45 0x4b 0x40 0x42 0x3e 0x41 0x46 ,0x45 0x49 0x40 0x41 0x40 0x43 0x46 ,
cs:1 mid  :0x87 0x86 0x81 0x7f 0x80 0x7c 0x79 ,0x87 0x84 0x81 0x7e 0x81 0x7f 0x79 ,
cs:1 max  :0xca 0xc2 0xc3 0xbd 0xc2 0xb8 0xac ,0xca 0xc0 0xc3 0xbb 0xc2 0xbb 0xac ,
cs:1 range:0x85 0x77 0x83 0x7b 0x84 0x77 0x66 ,0x85 0x77 0x83 0x7a 0x82 0x78 0x66 ,
out
启动到这里停止了
GMT+8, 2024-6-2 13:12 , Processed in 0.049379 second(s), 19 queries .
