查看: 14390|回复: 0
RV1126 把wifi作为热点AP时,遇到的问题
发表于 2022-5-10 16:11:11 | 显示全部楼层 |阅读模式
我用下面的命令
  1. iw phy0 interface add wlan1 type managed
添加一个新的wlan1的网卡时,报错
  1. command failed: Cannot allocate memory (-12)
下面是dmsg的输出
  1. [root@RV1126_RV1109:/]# dmesg
  2. [  804.618686] [dhd] CFG80211-ERROR) wl_bss_iovar_war : wl bss 2
  3. [  804.621481] INTERNAL ERROR: FIRMWARE HALTED : set BUS DOWN
  4. [  804.622977] CONSOLE: led with -1
  5. [  804.623012] CONSOLE: 000016.691 wl0: wlc_bsscfg_alloc: wlc_bsscfg_alloc_ext failed with -1
  6. [  804.623031] CONSOLE: 000016.691 wl0: wlc_quiet_bsscfg_deinit: Quiet info not found
  7. [  804.623057] CONSOLE: 000016.691 wl0: wlc_csa_bsscfg_deinit: CSA info not found
  8. [  804.623070] CONSOLE: 000016.691
  9. [  804.623145] CONSOLE: FWID 01-ef5bb70a
  10. [  804.623167] CONSOLE: flags 1
  11. [  804.623181] CONSOLE: 000016.691
  12. [  804.623197] CONSOLE: TRAP 3(7fb18): pc 1fe8, lr 847061, sp 7fb6c, cpsr 60000003, spsr 61000010
  13. [  804.623213] CONSOLE: 000016.691   r0 0, r1 0, r2 0, r3 74c, r4 f, r5 727d8, r6 a6c
  14. [  804.623228] CONSOLE: 000016.691   r7 7b074, r8 0, r9 6918c, r10 1, r11 10, r12 877716
  15. [  804.623240] CONSOLE: 000016.691
  16. [  804.623253] CONSOLE:    sp+0 00000000 00000000 00000000 0000074c
  17. [  804.623267] CONSOLE: 000016.691   sp+10 00877716 00847061 00001fe8 61000010
  18. [  804.623278] CONSOLE:
  19. [  804.623291] CONSOLE: 000016.691 sp+84 00015e39
  20. [  804.623303] CONSOLE: 000016.691 sp+b0 00015d6d
  21. [  804.623315] CONSOLE: 000016.691 sp+e8 00015d6d
  22. [  804.623326] CONSOLE: 000016.691 sp+114 00000107
  23. [  804.623337] CONSOLE: 000016.691 sp+234 00000107
  24. [  804.623348] CONSOLE: 000016.691 sp+23c 00000107
  25. [  804.623360] CONSOLE: 000016.691 sp+254 00000107
  26. [  804.623371] CONSOLE: 000016.691 sp+268 00000107
  27. [  804.623383] CONSOLE: 000016.692 sp+29c 00000107
  28. [  804.623404] CONSOLE: 000016.692 sp+2bc 00000107
  29. [  804.623423] CONSOLE: 000016.692 sp+2cc 00000107
  30. [  804.623451] CONSOLE: 000016.692 sp+300 00000107
  31. [  804.623473] CONSOLE: 000016.692 sp+310 00000107
  32. [  804.623498] CONSOLE: 000016.692 sp+314 00000107
  33. [  804.623534] CONSOLE: 000016.692 sp+33c 00003769
  34. [  804.623563] CONSOLE: 000016.692 sp+36c 00000107
  35. [  804.623590] dhdsdio_checkdied: msgtrace address : 0x00000000
  36. [  804.623590] console address  : 0x0007DEBC
  37. [  804.623590] Assrt not built in dongle
  38. [  804.623590] Dongle trap type 0x3 @ epc 0x1fe8, cpsr 0x60000003, spsr 0x61000010, sp 0x7fb6c,lp 0x847061, rpc 0x1fe8 Trap offset 0x7fb18, r0 0x0, r1 0x0, r2 0x0, r3 0x74c, r4 0xf, r5 0x727d8, r6 0xa6c, r7 0x7b074
  39. [  804.623590]
  40. [  804.623590]
  41. [  804.623847] Dump dongle memory
  42. [  804.733569] dhd_schedule_memdump: buf(va)=e1f80000, buf(pa)=31f80000, bufsize=524288
  43. [  804.733688] dhdsdio_dpc: failed backplane access over SDIO, halting operation
  44. [  804.733726] write_dump_to_file: file_path = /data/misc/wifi/mem_dump_Dongle_Trap_1502585330.344564
  45. [  804.733801] open file error, err = -2
  46. [  804.733822] dhd_mem_dump: writing SoC_RAM dump to the file failed
  47. [  825.653162] dhd_bus_rxctl: resumed on timeout, INT status=0x00000002
  48. [  825.653229] dhd_bus_rxctl: rxcnt_timeout=1, rxlen=0
  49. [  825.653712] Dump dongle memory
  50. [  825.758224] dhd_schedule_memdump: buf(va)=e1f80000, buf(pa)=31f80000, bufsize=524288
  51. [  825.758296] write_dump_to_file: file_path = /data/misc/wifi/mem_dump_ERROR_RX_TIMED_OUT_1502585351.369135
  52. [  825.758371] open file error, err = -2
  53. [  825.758390] dhd_mem_dump: writing SoC_RAM dump to the file failed
  54. [  825.758423] dhd_check_hang: Event HANG send up due to  re=1 te=0 e=-110 s=0
  55. [  825.758441]   Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1)
  56. [  825.758441]   Firmware: wl0: Jan 28 2015 10:03:34 version 7.10.323.50 (r529740 WLTEST) FWID 01-ef5bb70a
  57. [  825.758441]   CLM: 7.11.15 (2014-05-26 10:53:55)
  58. [  825.758441]   Chip: a9a6 Rev 1
  59. [  825.758486] dhd_os_send_hang_message: Event HANG send up due to  re=1 te=0 s=0
  60. [  825.758509] dhd_check_hang: Event HANG send up due to  re=1 te=0 e=-110 s=0
  61. [  825.758522]   Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1)
  62. [  825.758522]   Firmware: wl0: Jan 28 2015 10:03:34 version 7.10.323.50 (r529740 WLTEST) FWID 01-ef5bb70a
  63. [  825.758522]   CLM: 7.11.15 (2014-05-26 10:53:55)
  64. [  825.758522]   Chip: a9a6 Rev 1
  65. [  825.758556] [dhd] CFG80211-ERROR) wl_cfg80211_add_del_bss : 'bss 2' failed with -110
  66. [  825.758923] dhd_stop: Enter 68056973
  67. [  825.758969] dhd_wl_ioctl: returning as busstate=0
  68. [  825.759004] [dhd] CFG80211-ERROR) wl_cfg80211_clear_security : wsec clear failed
  69. [  825.759034] dhd_wl_ioctl: returning as busstate=0
  70. [  825.759061] [dhd] CFG80211-ERROR) wl_cfg80211_clear_security : auth clear failed
  71. [  825.759085] dhd_wl_ioctl: returning as busstate=0
  72. [  825.759104] [dhd] CFG80211-ERROR) wl_cfg80211_clear_security : wpa_auth clear failed
  73. [  825.759130] dhd_wl_ioctl: returning as busstate=0
  74. [  825.759164] [dhd] CFG80211-ERROR) wl_cfg80211_bss_isup : 'cfg bss -C 0' failed: -19
  75. [  825.759186] [dhd] CFG80211-ERROR) wl_cfg80211_bss_isup : NOTE: this ioctl error is normal when the BSS has not been created yet.
  76. [  825.759213] [dhd] CFG80211-ERROR) wl_notifier_change_state : wl_notifier_change_state : busstate is DHD_BUS_DOWN!
  77. [  825.759393] dhd_wl_ioctl: returning as busstate=0
  78. [  825.759423] [dhd] CFG80211-ERROR) wl_dongle_down : WLC_DOWN error (-19)
  79. [  825.759447] dhd_tcpack_suppress_set 352: already set to 0
  80. [  825.759535] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1
  81. [  825.759557] dhd_wl_ioctl: returning as busstate=0
  82. [  825.759598] dhd_dbg_detach_pkt_monitor, 2204
  83. [  825.759631] dhd_bus_devreset: == Power OFF ==
  84. [  825.759720] bcmsdh_oob_intr_unregister: Enter
  85. [  825.759809] dhd_txglom_enable: enable 0
  86. [  825.759830] dhd_bus_devreset:  WLAN OFF DONE
  87. [  825.759912] wifi_platform_set_power = 0
  88. [  825.759933] ======== PULL WL_REG_ON(-1) LOW! ========
  89. [  825.759951] [WLAN_RFKILL]: rockchip_wifi_power: 0
  90. [  825.759979] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
  91. [  825.759993] [dhd-wlan0] wl_android_wifi_off : out
  92. [  825.786308] dhd_stop: Exit
  93. [  825.786542] [dhd] CFG80211-ERROR) wl_cfg80211_hang : In : chip crash eventing, reason=0x8002
  94. [root@RV1126_RV1109:/]#
请问是什么问题导致的呢?   wifi是ap6236
GMT+8, 2026-7-13 08:04 , Processed in 0.072414 second(s), 20 queries .
