楼主 |
发表于 2020-6-4 11:49:38
显示全部楼层
在install过程中,成功连接后,出现以下问题请问如何解决
11:40:14 ERROR : command terminated with error
11:40:15 ERROR : command terminated with error
11:40:17 ERROR : command terminated with error
11:40:20 ERROR : cuDNN on Target : [exec_command]: /bin/bash -c scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP.sh imcs@172.16.2.10:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no imcs@172.16.2.10 "~/tmp_NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP.sh"; [error]: exit status 1
11:40:20 ERROR : cuDNN on Target : [error]: dpkg install on target failed; [exec_command]: safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/libcudnn8_8.0.0.145-1+cuda10.2_arm64.deb" 5; sleep 5; ; [deb_path]: /home/imcs/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.145-1+cuda10.2_arm64.deb
11:40:20 ERROR : cuDNN on Target : command terminated with error
11:40:20 ERROR : cuDNN on Target : Install 'cuDNN on Target' failure, command < using adapter to install NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER to /home/imcs/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER > terminated with error.
11:40:41 ERROR : OpenCV on Target : [exec_command]: /bin/bash -c scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh imcs@172.16.2.10:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no imcs@172.16.2.10 "~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh"; [error]: exit status 1
11:40:41 ERROR : OpenCV on Target : [error]: dpkg install on target failed; [exec_command]: safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb" 5; sleep 5; ; [deb_path]: /home/imcs/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
11:40:41 ERROR : OpenCV on Target : command terminated with error
11:40:41 ERROR : OpenCV on Target : Install 'OpenCV on Target' failure, command < using adapter to install NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER to /home/imcs/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER > terminated with error.
11:40:41 ERROR : Unavailable components detected, please check log
11:40:41 ERROR : TensorRT on Target : TensorRT on Target Skipped. Due to its dependencies fail to install: cuDNN on Target,
11:40:41 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : NVIDIA Container Runtime with Docker integration (Beta) Skipped. Due to its dependencies fail to install: cuDNN on Target,
11:40:41 ERROR : Multimedia API : Multimedia API Skipped. Due to its dependencies fail to install: cuDNN on Target, |
